Airbag light
Discussion in '1st Gen. Tacomas (1995-2004)' started by newertoy, Oct 22, 2015.
  1. Oct 22, 2015 at 3:16 PM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Hi All-the airbag light just came on today.What are some first checks? Common problems.
    Is the spiral connector the most likely culprit?
    I did see that there was a recall on the 2005 and later models.
    my truck is 2003 extra cab.
  2. Oct 22, 2015 at 3:28 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  3. Oct 22, 2015 at 8:03 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Mine did that and it was the airbag computer module that went out. Had to pay 100 for the dealership to put it on the computer
  4. Oct 23, 2015 at 8:12 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Thanks for the reply--lets see if anyone else has had the same difficulty--Is it the module in the center bottom of the dashboard??
  5. Oct 23, 2015 at 8:20 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    The connector under the drivers seat can cause airbag light issues, but I think it will just blink if that it the problem.
  6. Oct 23, 2015 at 8:21 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Exactly.... I put a new clockspring in but didn't fix the problem. Its very rarely the airbag sensors in the front of the truck.
  7. Oct 23, 2015 at 8:22 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Thanks-that was my first check--yes-read it blinks! Mine is steady ON
  8. Oct 23, 2015 at 9:22 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
  9. Oct 23, 2015 at 1:07 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Thanks for all the replies--will try to find the defect this weekend!!
