airbag light
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, May 28, 2010.
  1. May 28, 2010 at 10:25 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    is it normal for my airbag light on my dash to stay on when i turn the airbag on or should it turn off?
  2. May 29, 2010 at 7:52 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    You're talking about the passenger airbag disable switch and the indicator light in that switch's assembly, right?
    If so - NO. The switch's indicator light should turn off when you turn the key to the 'on' (enable passenger airbag) position.
  3. May 29, 2010 at 10:06 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ya thats what im talking about and when i turn the airbag on the light doesnt go away on the dash
  4. Jun 21, 2010 at 12:15 PM
    TopTeke
    TopTeke Active Member
    Ventura, CA
    07 PreRunner 6spd. Access Cab
    Your airbag is potentially malfunctioning and will not deploy as long as that light is on. At my local dealership it costs $105 for diagnosis, and if any repair is actually necessary that goes toward the total.
    At least that's what they told me when mine went on. Still haven't fixed it..
