Airbag maintenance
Discussion in 'Suspension' started by skifishbum, Apr 13, 2022.
  1. Apr 13, 2022 at 9:28 PM
    skifishbum
    skifishbum [OP] Well-Known Member
    Reno, NV
    17 DCSB -> 22 DCLB
    How often do you need to inflate the bags to keep the minimum pressure? Is it a weekly thing to monitor?
    Planning suspension upgrades, thinking airbags might be the way. Don’t want to go down the path of lifting another tacoma again. Will have about 350-400 of constant weight in the bed.
    Don’t want to sign up for a lot of maintenance. Accidentally posted in camper shell forum.
  2. Apr 14, 2022 at 7:00 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Firestone says minimum 5psi all the time.
    Why not just install a new leaf pack? The least maintenance, better ride, and rear axle articulation with no maintenance.
  3. Apr 14, 2022 at 10:44 AM
    skifishbum
    Reno, NV
    17 DCSB -> 22 DCLB
    I would have to order a custom leaf pack. Believe all the available ones would give me a lift.
