Airbag off options while off roading?
Discussion in 'Technical Chat' started by Jake.A, Jul 6, 2016.
  1. Jul 6, 2016 at 12:14 PM
    Jake.A
    Jake.A [OP] Well-Known Member
    California
    2014 Tacoma TRD Sport
    Tried google with no luck..just wondering if anyone on here has turned off their airbags while off roading? I dont really beat on my truck too much but I think I would prefer my airbags to be off just in case my foot stays on the gas a little too long :D
  2. Jul 11, 2016 at 2:07 AM
    BahiaTaco
    BahiaTaco Active Member
    Timo
    Los Angeles
    15 Prerunner SR5
    SnugTop Topper Ride Rite Bags Air Lift Compressor Yakima Roof Rack Skidplate Ultra Gauge Side steps TRD off-road wheels
    I don't think there is an easy way to disable all airbags. But you don't have to. It takes more than bumps from off-roading to activate them. It you have an airbag deploy, you (almost certainly) needed it to avoid serious injuries.
    Jake.A[OP] likes this.
  3. Jul 11, 2016 at 2:25 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    MSN88longbed and Jake.A[OP] like this.
  4. Jul 11, 2016 at 9:32 AM
    tgear.shead
    tgear.shead Well-Known Member
    Find and pull the airbag fuse. Cheap and easy.
    DaveInDenver and Jake.A[OP] like this.
  5. Jul 11, 2016 at 11:18 AM
    Jake.A
    California
    Thanks for the help/advice. I knew the rsca would disable the sides but wasn't sure if the rest would be disabled as well. I saw some YouTube vids of Tacos taking some jumps over some dunes and airbags went off when no other damages occurred to the truck..or that's what it seemed like at least. Will try to find that fuse to disable them
  6. May 13, 2021 at 7:48 PM
    hawaiidclb
    hawaiidclb Well-Known Member
    Maui, Hawaii
    08 Black DCLB 4x4
    Did you find a solution?
  7. May 13, 2021 at 7:55 PM
    Bishop84
    Bishop84 Well-Known Member
    Curtain air bags are the only ones that will blow with a false roll over. Press the RSCA and you're good.
