Airbag / sealbelt light stuck on, code B1650, after bouncing around in the passenger seat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by longboi, Nov 16, 2024.
  1. Nov 16, 2024 at 3:57 PM
    longboi
    longboi [OP] Well-Known Member
    Denver, CO
    2021 - SR5 - Double Cab - Long Bed - Barcelona Red
    Anyone know what might be the issue here? Or how to get this diagnosed / fixed?
    Friend bouncing / kicking around in passenger seat, seatbelt and airbag light came on and stay on.
    Tried disconnecting battery for a few hours, re-seating / disconnecting wires near sensor underneath passenger seat (yellow, gray, black), clearing codes, none of it works and the two lights stay on (airbag and flashing seatbelt light).
    Any tips? All I can find is dis-consensus online around (re-calibrate, replace sensor, etc). I don't want to dump 1k into this. Really want a good set of steps to diag this properly.
  2. Nov 16, 2024 at 4:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Need to see what codes are in the Occupant Classification ECU but my hunch would be either the zero point for the weight sensors got screwed up or one of the sensors was damaged.
    longboi[OP] likes this.
  3. Nov 16, 2024 at 4:21 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I think the ”bouncing / kicking” friend would be the one fixing this problem.
    Tacosha, TacoManOne, Barsoom and 4 others like this.
  4. Nov 16, 2024 at 4:40 PM
    longboi
    Denver, CO
    Any links / guides on how to check those codes?
  5. Nov 16, 2024 at 4:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Has to be checked with a scan tool that can access all systems.
    longboi[QUOTED][OP] likes this.
  6. Nov 17, 2024 at 4:15 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    by chance, is there any video of said friend having this episode/tantrum? I’m curious of what kind of behavior actually caused the sensor to fail,,, IF it is the sensor.
  7. Nov 17, 2024 at 4:26 AM
    Tacoma Mike
    Southern Maine
    Seat is out of calibration.
    Needs to be recalibrated.
    Keep offender in the back seat.
    Saw this all the time.
    Large people would set this off too…
    Make sure nothing is under the seat also
    longboi[OP] and RustyGreen like this.
  8. Nov 17, 2024 at 5:49 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Why? I suspect it was a female friend bouncing around and OP was IN on the bounce.
    Weight of two people probably broke the sensor(s).
  9. Nov 17, 2024 at 5:59 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Lol! I think we have a winner.
  10. Nov 17, 2024 at 6:05 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I agree and I thought this from the beginning but OP didn’t disclose so I assumed he had a friend that had a break down.
    Barsoom[QUOTED] likes this.
  11. Nov 17, 2024 at 6:16 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, we need clarification to what exactly happened?
    Barsoom likes this.
  12. Nov 18, 2024 at 6:26 AM
    Barsoom
    NW GA OTP
    And they always disappear, leaving us frustrated. No resolution, no story climax.
    Chew and t0p_d0g like this.
  13. Nov 20, 2024 at 7:59 PM
    longboi
    Denver, CO
    Enjoy your headcannon, it's better than the real thing ;)
  14. Nov 20, 2024 at 7:59 PM
    longboi
    Denver, CO
    Sorry I've been snowboarding and got the flu
  15. Nov 21, 2024 at 5:21 AM
    Barsoom
    NW GA OTP
    Is that what they call it nowadays?
  16. Jan 4, 2025 at 6:46 AM
    Rayh53
    Rayh53 New Member
    Ray
    2020 Off Road
    De-chromed
    Same thing here with the SRS light. Cause was an oversized passenger. Tried the battery disconnect, reseating the connectors. Borrowed a scanner (Innova 3100rs). Code B1650 would reset then immediately trip.
    Calibration makes sense. Imagine the empty seat sensor not returning to zero once the passenger gets out or is pushed past full scale. I guess this is a shop task.
  17. Jan 4, 2025 at 7:05 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Unfortunately OP never reported back to his findings. I think you are right about recalibration if that doesn’t work then sensor replacement.
  18. Jan 4, 2025 at 4:51 PM
    Barsoom
    NW GA OTP
    Moral of the story is to turn off your truck, if you get a lap dance in a Taco.
    t0p_d0g[QUOTED] likes this.
  19. Jan 4, 2025 at 6:47 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Offenders like this one better to keep off-board, or transport in the box, packed in restraining shirt and tied-up to platform.
    Re-calibration of the system required, anyways.
