Airbag Warning Light and Seat Position Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MRBIG77, Apr 17, 2011.
  1. Apr 17, 2011 at 8:38 PM
    MRBIG77
    MRBIG77 [OP] Member
    Utah
    07 Double Cab TRD Sport
    I'm having issues with my air bag warning light coming on intermittently. It appears as though it is related to the position of the drivers seat. When I'm back all the way it comes on, when I scoot up it turns off. Any advice on fixing the position switch that is located on the right hand rail of the drivers seat? Anyone know where I might find a replacement sensor?
  2. Apr 17, 2011 at 8:41 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    sounds like a loose connection. Did you check the connections under the seat? I know there is a common problem with the airbag light. Try doing a search or just go to the dealer if you still have a warranty.
  3. Apr 17, 2011 at 8:44 PM
    MRBIG77
    MRBIG77 [OP] Member
    Utah
    No warranty (salvage title, i know crazy!) I checked all the connections, the only thing that seems to make a difference is the position of the seat. I'm afraid the dealer may be my only option since it involves the air bags.
