Airbags or Helper Springs
Discussion in 'New Members' started by 17XRTR, Sep 1, 2020.
  1. Sep 1, 2020 at 1:27 PM
    17XRTR
    17XRTR [OP] New Member
    Brantley
    2010 Silver Tacoma Pre-Runner TRD ORP
    I recently purchased a Polaris Ranger/14' Utility Trailer. I've been in the process the past couple months getting my truck back into shape (new tires, rear brake job, replaced faulty vapor charcoal canister, replaced 3 u-joints, replaced faulty left front hub, installed trailer brakes, etc). I wanted to get everything done (for peace of mind) before hunting season when I'll be towing the Ranger to my hunting camp and another camp I hunt with. I have no doubt in my mind that the Tacoma has the ability to tow the package (only 3500 lbs total), but I'm curious as to whether or not I should add towing airbags or helper springs to take some strain off the suspension. My truck is a 2010 with 148,000 miles but has been well maintained (every 3000 miles - oil changes, tire rotation/balances, fluid checks,air filter cleaned, etc). Thank you!
  2. Sep 1, 2020 at 2:12 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Bigdaddy4760 likes this.
  3. Sep 1, 2020 at 2:21 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome to TW! That will start an endless argument. It took me about a month of waffling between the pros and cons of helpers, airbags, bump cushions (like sumos or timbrens) and all the other magical products out there. Each person will swear that whatever product they are running is the absolute best for whatever reasons fit their lifestyle.
    Eventually I settled on the Roadmaster Active Suspension. It works for my trailer. I dont have to air up or down with each load like with airbags, but it is somewhat adjustable for those trips where I'm running a trailer and carrying a small load in the bed.
    Eventually I might ditch that and just do a rear suspension replace, but I have been happy with the roadmasters so far.
    Good luck on your search.
  4. Sep 1, 2020 at 2:31 PM
    PyroTaco
    PyroTaco Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    As said above, you'll get many different answers based upon the individuals experience and what worked best for their situation.
    For me personally I'm also running roadmasters set to the stiffest setting and sumo springs for added insurance. Now that being the case I know not to overload the truck, but if by some chance that happens there's a fair chance I'll be "OK" and muddle through the situation. Again, don't overload! That's what I personally find to work for my situation of having a ton of stuff in the bed (drawer system loaded to the gills) plus a fiberglass shell and an occasional trailer loaded down.
    -PyroTaco
  5. Sep 1, 2020 at 2:43 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW... I have Firestone Ride Rite air bags and compressor. I mounted the compressor switch on the dash under the steering wheel, easy to air up easy to air down.
    SpeySquatch and Black DOG Lila like this.
  6. Sep 1, 2020 at 2:50 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    My solution to sagging leafs under my trailer tongue load was Hellwig EZ-990 helper springs. Keeps truck level under load. No effect on ride quality running empty.
  7. Sep 1, 2020 at 2:53 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I regularly towed my Kawasaki Teryx4 on a 16 foot dual axle car hauler behind my 2011 TRD OR with OEM suspension. It handled the weight fine. It wasn't until I started hauling a lot of weight in the bed AND towing that my springs started getting unhappy. Do you know if you have the TSB springs (3 leaves and an overload) or original leaves (2 leaves and an overload)?
  8. Sep 1, 2020 at 4:12 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
    buckhuntin-tacoma likes this.
  9. Sep 1, 2020 at 4:20 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Neither, go with sumosprings much easier and won’t effect your ride when empty
  10. Sep 3, 2020 at 10:00 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  11. Nov 11, 2020 at 3:20 PM
    Dennis K
    Dennis K Member
    Dennis
    2020 TRD Sport
    I like this article. Noticed my 2020 TRD Sport LB was a bit saggy loaded up.
    YF_Ryan likes this.
