Airbags vs TSB
Discussion in 'Towing' started by canadiankid, Mar 5, 2009.
  1. Mar 5, 2009 at 7:24 PM
    canadiankid
    canadiankid [OP] Well-Known Member
    Langley BC Canada
    09 DC LB TRD SPORT
  2. Mar 6, 2009 at 6:37 AM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    i am looking on getting air bags also for load carrying and for towing. from the research i did and the people i talked to you should get the onboard air compressor to go with it. i will be putting mine on in the summer.
    go with the air bags, don't waste your money on the other quick fix add ons.
  3. Mar 6, 2009 at 7:30 AM
    ofrd4fun
    ofrd4fun Well-Known Member
    Vancouver BC
    05 DC 4x4
    FJ Cruiser wheels, air bags, 5100's @1.75, TC UCA's, bi-xenon HID's
    I put air bags on my truck within 3 months of buying it because the rear springs were way too soft even with nothing in the back. Then a couple of years later I got the TSB done. I still use the air bags often though. We're going camping this weekend (-5 C Oh what fun.....!!!) and with a couple of dirt bikes in the back as well whatever other things get tossed in AND our small travel trailer hooked up the air bags make the ride perfect. No onboard compressor. I have a bicycle hand pump I use when needed and they do not lose any air ever. Easy to install too.
    Cheers
  4. Mar 6, 2009 at 9:29 AM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    What kind do you have?
  5. Mar 6, 2009 at 11:46 AM
    ofrd4fun
    Vancouver BC
    05 DC 4x4
    I'll have to check but I think they were Ride Rite by Firestone. I made a small aluminum bracket that mounts to the right of the hitch that holds the two fill valves. I thought about an on-board compressor but the cost just wasn't worth it to me. It takes no time to inflate or deflate the bags because the volume of each is so small and even three years later I don't want a compressor. Plus, like I mentioned earlier, they do not lose ANY air.
    Cheers
  6. Mar 6, 2009 at 2:15 PM
    05silverTaco
    05silverTaco Well-Known Member
    Grants Pass, Oregon
    12 DCLB 4X4 TRD Sport
    Dodge Mirrors, Fog light switch, Always on Fog lights, Firestone Air Bags
    canadiankid,
    I have ride right by firestone their bolt on kit. There is two holes at the bottom outer portion of each side rear bumper that I put my valves in. Don't connect to a tee and have a single line as air transfers from one bag to the other around corners set up that way. So far I use the minimum air amount and with my trailer and the tsb springs no problem. I also have a W/D hitch e-2. I paid about 250.00 usd for my kit.
    vince
  7. Mar 6, 2009 at 5:33 PM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    So are these really easy to install? Do I need the TSB and the Airbags?
  8. Mar 9, 2009 at 8:06 AM
    05silverTaco
    Grants Pass, Oregon
    I did the tsb first and then installed the air bags. I didn't want the dealer to not do the tsb because the truck had airbags on it.
    I like the air bag adjustability for when I am towing.
    vince
    edit: Oh by the way I am a honda car mechanic and installed them at work. It is easy if you have the tools and a rack to lift the truck.
  9. Mar 9, 2009 at 3:34 PM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    Do you think that just the TSB or Airbags alone would be enough?
  10. Mar 9, 2009 at 4:30 PM
    05silverTaco
    Grants Pass, Oregon
    When towing a 5000-6000 lb trailer you have abour 12% tongue weight. Now over time it will weaken the springs. How much I don't know. When I first had the tsb done I already had purchased my airbags. I might not have done so so quickly if I would have tried towing before purchasing the air bags. I do like having them as added insurance.
    vince
  11. Mar 9, 2009 at 5:06 PM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
  12. Mar 20, 2009 at 11:20 PM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    So I got my RideRite Airbags and did the install. Still waiting to pull the trailer but they seem to do a good job. They were very easy to install. The only hard part was sawing through the bump stop (a reciprocating saw would help). I will post more after I tow with it.
  13. Mar 20, 2009 at 11:37 PM
    socal16
    socal16 Well-Known Member
    Diego
    las vegas nv
    08 trd offroad black 4x4!!!
    wheels and tires, k&n cold air intake, limo tint,bhlm,TRD seatcovers, OME lift
    im thinking of putting airbags too those of you who have them can you please post some pics???
  14. Mar 22, 2009 at 10:35 AM
    ofrd4fun
    Vancouver BC
    05 DC 4x4
    Sawing through the bump stop????? Huh!!!
  15. Mar 22, 2009 at 10:40 AM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    The bump stops that are on the top of the leaf pack held on by the U bolts. You have to saw it flush with the U bolts so the bottom bracket will sit on the U bolts.
  16. Mar 23, 2009 at 10:15 PM
    Tacoma Tom
    Tacoma Tom Well-Known Member
    Sunny Arizona
    07 DBL TRD
    Do you really need to saw the bump stops off, or can they be removed? sawing them off does not sound right?
  17. Mar 24, 2009 at 7:19 AM
    ofrd4fun
    Vancouver BC
    05 DC 4x4
    The bump stops are kind of important. Did you relocate them??? The airbags I put in sit just in front of the axle on top of the leaf springs.
  18. Mar 24, 2009 at 8:26 AM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    If you have airbags then you should never hit your bump stop making it useless. The ride Airbags sit right on top of the U bolts that holes the leaf pack onto the axle, so sawing or removing the bump-stop is mandatory. If you wanted to remove it you will have to take or at least loosen the U bolts. In the instructions it said to saw it flush so that is what I did. In my opinion leaving the bump-stop in place and just trimmed will give the airbag extra support as well.
  19. Mar 24, 2009 at 8:17 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Huh........ ya mine has the bumpstop in the middle of the u-bolts as well. If you need to take the bags off, no more bump stop. That kind of sucks. I think I like the airlift better, no bump stop removal. Think I will buy the airlift and check it out.
  20. Mar 25, 2009 at 8:48 AM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    I just liked the fact that my airbags were putting their pressure on my axle and not on the leafs. If I ever want to remove my airbags I am sure that I can get a new bump-stop or one from a wrecker for pretty cheap.
