Airbox Broken
Discussion in '1st Gen. Tacomas (1995-2004)' started by bawilson21, Jun 26, 2010.
  1. Jun 26, 2010 at 11:43 AM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    And this is the second time! The first time I noticed it on a trip from Tucson to San Antonio and fixed it with some Gorilla glue when I got back. Now its happened again and I dont feel like dropping insane amount of money on purchasing a new Air Box. I'd rather spend that money on Mods or Crap from REI. Im looking for something stronger then Gorilla Glue. Something that can hold up to the heat under the engine and the vibrations and violent shaking of not slowing down when going over speed bumps, or offroading.
    Any Ideas?
    On another note, The color of my truck is really gay and I want to paint it. Anyone in Tucson know of good shops where you can get the most bang for your buck?
  2. Jun 26, 2010 at 12:28 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Can you fit some kind of screws to join the tube and the air-box together. Then put some kind of Sensor Safe Sealent or Silicone between the gap
  3. Jun 26, 2010 at 12:33 PM
    747 function > form
    1st Gen.
    Hmmm...never seen that before. Sounds like this will keep happening...you may want to incorporate a sleeve of some sort for more "slack" between the airbox and tube. Just my 2¢.
  4. Jun 26, 2010 at 12:38 PM
    bawilson21
    Bryan
    WA
    I never thought about screwing the tube and airbox together, you might be on to something there
  5. Jun 26, 2010 at 1:04 PM
    tacoman101
    scott
    vermont
    Possibly some small Self Tapping Screws? :notsure:
  6. Jun 26, 2010 at 1:10 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    sensor safe silicon sealant. used it for the deck plate mod and it holds up perfectly. but it looks like you have a good excuse to buy a CAI
  7. Jun 26, 2010 at 8:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I've never seen nor heard of this happening before........... :rain:
  8. Jun 26, 2010 at 8:46 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    JB Weld.
    Available in the Paint Department of your local Home Depot.
    Good Luck!;)
  9. Feb 21, 2011 at 8:49 AM
    bawilson21
    Bryan
    WA
    So I've been sporting Duct tape because I've been lazy. I've just applied several strips of duct tape to hold the arm in place to the airbox. So far, no problems but it looks tacky and the ducttape is bound to give up sooner or later. I'm going to run to Lowes and buy some plastic Epoxy. It looks to to be the best type of glue and is often used in automotic and aviation industries. The glue is both quick bonding and super strong/durable. Its also water repellent and will create a good seal. I dont think this stuff is sensor safe though so I'm going to remove the MAF sensor while this thing sets. I'll be sure to apply this very liberally creating a very thick seal around the edges. I'll also probably leave it out for a couple of days and carpool to work or ride my bike to allow any kind of vapors from the glue to dissapaite. Finally. I'll reinforce with Black duct tape so it can fully bond and set to the material a couple of days longer once installed and coupled back to the intake. That's probably not neccessary but whatever. Looks like the Epoxy will work much better then Gorrilla glue in this application. Thought about using some sort of super glue that would melt and bond plastics together but it seems like harder plastics shed the melted plastic away, making it useless.
    I'll be sure to repost the results after a couple of weeks/months to let anyone with the same problem know how it worked out.
  10. Feb 21, 2011 at 8:53 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This right here is some of the strongest best shit you'll EVER use. This should be in everyone's tool box.
  11. Feb 21, 2011 at 8:06 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    same thing happen to me but it does give me an ecuse to buy cai....:)
  12. Feb 21, 2011 at 8:15 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Seriously-how TF do you break the airbox? It's moving with the rest of the truck...sorry I just don't get it.
  13. Feb 21, 2011 at 8:16 PM
    00yotasr5
    lee
    merced, ca
    got dusty and mud....
  14. Feb 21, 2011 at 8:19 PM
    bawilson21
    Bryan
    WA
    Ha! I was wondering the same thing. I havent a clue. Perhaps When I put it the Air box back after doing the Deckplate mode, I handled it too tough in just the wrong spot, but the thing is, It didn't break til several months later.
  15. Mar 5, 2011 at 10:13 PM
    Kelsey
    Kelsey Camping Lover
    Jasper, Alabama
    2004 Doublecab TRD 2WD
    K&N, Redline Differential Fluid
    I'm assuming you replaced the first one with a dealer part? To save some money and maybe get a better unit, find a Dorman part: http://www.dormanproducts.com/p-1894-258-504.aspx?pymmeid=7969727.
    Dorman, when engineering an aftermarket replacement part, will beef up problem areas to eliminate recurring problems. Most auto parts stores have access to Dorman, and you can probably get one off Ebay or Amazon.
