Airbox cracked...MAF contaminated?
Discussion in '1st Gen. Tacomas (1995-2004)' started by T@com@Steve, Sep 12, 2015.
  1. Sep 12, 2015 at 6:11 AM
    T@com@Steve
    T@com@Steve [OP] Well-Known Member
    Sarasota, Florida
    15 4x4 DCLB
    Patched headliner, loud rack, too much shit in the bed
    I noticed the other day that my airbox has finally failed. What led me to this discovery is that my MAF is acting funny. I have ordered a new airbox and taped up the joint where the tube meets the box. When I replace my box do I clean the MAF? I have heard mixed success with doing this? Also who knows how long I have been sucking dust into the motor. Is there a risk of the injectors clogging?
  2. Sep 12, 2015 at 8:03 AM
    LetsTacoboutit
    LetsTacoboutit Well-Known Member
    SEÑOR MEMBER
    Tejas
    4x4 TRD 6cyl
    yada, yada, yada
    I would clean the MAF.
    Also I would recommend to repair the air box in the future with Spectre parts and add the Spectre MAF holder. There is a write up: Mine broke a couple of years ago right at the joint. Caused the engine to race and had unplanned acceleration. I had to stand on the brake and shift to neutral. The second time it happened the engine would die at a full stop or at less than 500rpm. Each time it broke I had previously done some high speed beach running and bottomed out hard numerous times. No problems since new suspension.
  3. Sep 12, 2015 at 8:04 AM
    LetsTacoboutit
    SEÑOR MEMBER
    Tejas
    4x4 TRD 6cyl
    yada, yada, yada
    Also, duct tape makes a great temp repair.
  4. Sep 12, 2015 at 10:43 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I like that idea I will have to get me one of those .
    I have had great luck With the plastic weld I converted the old style MAF to the new style cutting a broken air box apart and using the plastic weld
    Pretty hard to get air into your injectors from the air intake
  5. Sep 12, 2015 at 12:07 PM
    T@com@Steve
    Sarasota, Florida
    15 4x4 DCLB
    Thanks! Wish I had made this post before I ordered the new box. It is on it's way. Oh...well. That looks like it will last forever.
