(Airbox No Longer Needed)
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by RattleTractor, Jan 24, 2020.
  1. Jan 24, 2020 at 11:50 AM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    02/03/20-
    I realized that I'd have to also deal with the intercooler overflow reservoir (aka a Nalgene bottle) and the straps that attach it to the side of the airbox (aka some Voile straps and rivets), so I went ahead with the Uphillshunter method and just replaced the deckplate assembly.
    Title says it all.
    I need a stock 5VZ airbox (aka "Air Cleaner Box") that hasn't had the deckplate mod done to it (i.e. intact). Mine has the mod done by the previous owner and did not come with a plate.
    I installed a dorkel this week so I'm just replacing the whole box with a fresh one. Yes, aftermarket ones are available from Low Range for $68 + ship, but I'm just seeing if anyone can beat that with a used OEM unit first.
    PM or post asking price + shipping to 05445. Will use PayPal for funds transfer.
    Thanks!
  2. Jan 24, 2020 at 11:52 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Why not just screw the lid on the deck plate, and be done with it?
    That's what I did :thumbsup:
    OG_Tacoma likes this.
  3. Jan 24, 2020 at 11:55 AM
    RattleTractor
    Harry
    VT
    I covered this in the first post...
  4. Jan 24, 2020 at 11:59 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  5. Jan 24, 2020 at 12:13 PM
    RattleTractor
    Harry
    VT
    Totally get it. I thought about it.
    But doesn't that somewhat defeat the secondary purpose of the dorkel by not sealing the intake completely? (Because we all know that the primary reason is because we like how they look...)
    At any rate, it's worth something to me to have an intact one at this point. But I also see your point too.
  6. Jan 24, 2020 at 12:18 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The deck plate should seal completely. There's a rubber oring in it. In your case, you didn't install the deck plate so if it were me, I'd re-seal around it with silicone. But the deck plate/lid is every bit as sealed as the air box.
    JTFisherman and OG_Tacoma like this.
  7. Feb 2, 2020 at 3:35 PM
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    I may have my original airbox I need to check my shop, but I'm in Canada so not sure on shipping cost.
  8. Feb 2, 2020 at 4:00 PM
    Bejabbers
    Shane
    I found my original air box no deckplate mod; however the top hose connector is damaged, I believe all you need is the bottom half of the airbox anyways. I will sell it for $30 USD + shipping
  9. Feb 3, 2020 at 11:50 AM
    RattleTractor
    Harry
    VT
    I'm all set over here. Thanks though!
  10. Feb 3, 2020 at 11:55 AM
    Bejabbers
    Shane
    Sounds good
