Airconditioning issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PugLife, Jun 18, 2015.
  1. Jun 18, 2015 at 3:23 PM
    PugLife
    PugLife [OP] Member
    So the wife was driving the tacoma today, when she got home she told me the air conditioning wasn't working. So I go and check it out and notice the air only will work on full power and none of the other settings are pushing air in at all. Anyone else ever have this issue? Or have any idea what it could be? Truck is a 2013 with 53000 on it.. any help is appreciated
  2. Jun 18, 2015 at 3:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Blower fan resistor. Easy and cheap fix. Utube it and vids will come up.
  3. Jun 18, 2015 at 9:33 PM
    PugLife
    PugLife [OP] Member
    ok awesome thank you very much..
  4. Jun 19, 2015 at 5:14 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Before you change the resistor, wiggle the connector and see if any speed other than high comes on. The pins in the connectors are known to get loose and eventually melt or burn. If it's just loose pins, a new resistor won't fix it. Remove the plug and inspect it for damage. If it just recently started having this issue, getting down in the connector with a cheap dental tool and respringing the connector pin will fix it. If the connector was loose and is now burnt, there is a replacement one available.
  5. Jun 19, 2015 at 5:21 PM
    PugLife
    PugLife [OP] Member
    Got it fixed, connector was still good.. just changed the resistor and they all work again.. thanks koditten
