Airflow America! The only snorkel made FOR OUR TRUCKS!!
Discussion in 'Overland Alaska' started by benbacher, Jan 28, 2014.
  1. Jul 29, 2014 at 4:12 PM
    #221
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    What ever it is, I welcome the increase in MPG's
  2. Jul 30, 2014 at 8:08 AM
    #222
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Rus I saw you talining me to denali last friday ;)
  3. Jul 30, 2014 at 10:05 AM
    #223
    ruslanus
    Rus
    Wasilla, AK
    No way! were you on your truck? I didn't see you
  4. Jul 31, 2014 at 8:21 AM
    #224
    benbacher
    Anchorage, AK
    Dang who did I text?! You were behind me for a while, i had a cvt tent in the bed of a stock taco.
  5. Aug 1, 2014 at 6:38 AM
    #225
    ruslanus
    Rus
    Wasilla, AK
    You definitely didn't text me, lol. My in-laws were visiting from California, I was taking them to Denali. I remember seeing a few Tacos on the way up there, none of them looked familiar :)
  6. Aug 1, 2014 at 1:22 PM
    #226
    benbacher
    Anchorage, AK
    Yeah, was in my dads 05' stock white access cab with a rtt in the bed. I pulled off at a gas station before healy and you passed me then
  7. Aug 13, 2014 at 10:53 PM
    #227
    skygear
    skygear                    
    Didn't realize you had your own section now.
    I NEED one of these for my truck. Sliders too ;):spy:
  8. Aug 14, 2014 at 7:40 AM
    #228
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Got my snorkel installed I thought it might look a little to much for the size of the ram but damn this thing looks bad ass on my truck I am glad I went with Airflow it is made for our trucks looks like a Tacoma should look bad ass man.
  9. Aug 14, 2014 at 9:07 AM
    #229
    skygear
    skygear                    
    :jellydance: FU! Where's the pics?
  10. Aug 14, 2014 at 9:08 AM
    #230
    Large
    Large Red
    What pics do you want
  11. Aug 14, 2014 at 9:12 AM
    #231
    skygear
    skygear                    
    Damn, Large, you too!?
    Install pics? Installed pics?
    It looks like they are using the corrugated gutter plastic piece. Liked the cleaner parts that Cruiser outfitter sells. Anyone use a piece of aluminum or other smooth surfaced piping?
    Know where to get BLACK Hose clamps? Saw them offered in the past/ forgot where though/
  12. Aug 14, 2014 at 9:17 AM
    #232
    Large
    Large Red
    Tried to go pro the whole install, battery died a few minutes in to it :facepalm: I did get the wholesawing of my fender lol. Install was straight forward, instructions were clear enough. My only gripe would be the fitment of the pillar bracket and that I only got 1 (and there are holes on the snorkel neck for 2), and you have to bend the bracket to get it to fit. I ended up removing mine and putting silicone in the holes I drilled until I fab up my own pillar bracket. I would also cut off some of the flexible ducting so you are not cramming everything in the fender well. Other than that it's a nice setup. I used a 1/4" drill bit in the fenders for the bolts (some tolerance from the paper template) and it worked good, also wear eye protection when hole-sawing the fender. If I think of any more tips I will post them up.
  13. Aug 14, 2014 at 9:19 AM
    #233
    Large
    Large Red
    Also use silicone on every fitting connection, every screw and around the body (between the fender and snorkel). ALSO bebur the hole you make with the holesaw and use some anti rust stuff (I used primer and applied it with cotton swabs).
  14. Aug 14, 2014 at 9:35 AM
    #234
    skygear
    skygear                    
    Good to know. I normally use protection/ primer/ de burr / etc.
    Wonder if the flex tubing was intentional, or lack of additional R&D, not that I really care that much. For the extra money they command vs the Safari, just was expecting a much cleaner solution.
  15. Aug 14, 2014 at 9:38 AM
    #235
    Large
    Large Red
    I would also put a small dab of loctite on the screws / bolts. I will say if I could go back and do it all over (and I still might) I would remove the entire fender.
  16. Aug 14, 2014 at 9:39 AM
    #236
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
  17. Aug 14, 2014 at 9:41 AM
    #237
    skygear
    skygear                    
    Fugit, just get some GLASS!
  18. Aug 14, 2014 at 9:47 AM
    #238
    la0d0g
    running for the hills
    For crawling not hauling
    I got mine here
  19. Aug 14, 2014 at 9:50 AM
    #239
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    ^same
  20. Aug 14, 2014 at 9:54 AM
    #240
    skygear
    skygear                    
    Excellent. Needed that intel .
