[CLOSED] Airflow Snorkel Group Buy #3
Discussion in 'Automotive Group Buys' started by tcBob, Aug 5, 2016.
Thread Status:
Not open for further replies.
  1. Aug 5, 2016 at 11:56 AM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    New Airflow Snorkel Group Buy for 2nd Gen Tacomas (2005-2015)!
    PRICING
    On airflowsnorkels.com they're sold for $495
    Group buy price: $335
    HOW TO ORDER:
    Click this link to message me (tcBob)
    HOW LONG WILL THIS PRICING LAST:
    Until the few that are left are sold
    Keeps scrolling down for pics of the snorkel installed :thumbsup:
    Snorkel Science:
    1.0 Introduction
    We, at Airflow Vector, design Snorkels that not only improve the operation of vehicles in wet or dusty environment but that are also esthetically pleasing
    2.0 Generalities
    Generally, vehicles are designed to operate as the best compromise between power, fuel economy and costs. In the specific area of air supply, engines are often starved of air. Air is sucked hard from a little vent under the bonnet or the mud guard to provide enough volume to mix with the fuel.
    To make an analogy, it is like trying to scuba dive with a very long non- pressurized hose connected to the surface. It does take much depth before running out of air. This is because the size of the hose is too small, and / or there is not enough pressure outside to push the air down. This is an example of a net vacuum system; the lungs do not have enough power to counteract the pressure deficiency. For an engine, a similar thing happens and it requires energy to suck the air inside the fuel mixing system.
    However, the improvements don’t stop there and we want to expand on another point which is often omitted: it is the amelioration of the vehicle performance and fuel economy. These benefits are obtained by the careful development of our Airflow Cold Air Induction System (ACAIS). This document explains how it operates.
    In scuba diving, the issue can be solved by carrying a compressed air tank on the back or using a compressor on a ship to push the air down the hose. This permits reaching greater depth without lacking air. This newer arrangement has become a net compression system.
    Understanding this issue, we designed our ACAIS to operate as a net compression system.
    3.0 Description of the parts comprising the ACAIS
    ACAIS comprises several parts, each one calculated to provide more air than the minimum necessary ensuring that the air supply remains a net compression system all the way to the engine. The parts are from top to bottom:
    A snorkel tube· A connection system to the air box (combination of hoses)
    3.1 The Air Ram
    A hat (we call it an Air Ram)
    The Air ram is designed to provide the largest possible air intake while avoiding deflections. Its face is slightly leaning forward to scope as much air as possible. Its internal contour is modeled on a parabolic shape to create both a compression effect and a spinning effect.
    The spinning effect creates a centrifugal force which causes the large contaminants (insects, large dust particles, water droplets, etc...) that have entered the Air Ram to fall in the bulged cavity around the snorkel
    intake. The four slots cut at the base of the Air Ram are the exhausts for these contaminants. The particles get trapped in the recesses and are ejected by the air pressure. The excess air is then pushed violently (we like to say “rammed”) inside the snorkel body.
    Because of the intrinsic aerodynamic characteristics of our Air Ram, turning it in the opposite of the direction of travel will cancel the pressure necessary for proper particle separation, thus removing its effectiveness. In extreme situations generated by high speed, it may create a trailing vacuum that could cause irreversible engine damage!
    3.2 The Snorkel body
    The Snorkel body is divided in three sections, the Air Ram connection tube which follows the contour of the “A” pillar section of the wind screen; the plenum chamber, which is secured to the guard and finally the intake section which penetrate inside the motor cavity. Each section plays a role in air speed and pressure.
    The Air Ram connection tube receives violently swirling air from the Air Ram.
    Its function is the slowing down the swirls and to deliver calmer air to the plenum chamber.
    The plenum chamber is an oversized reservoir of air. The calm air it stores is compressed and ready to be pushed inside the engine on demand. The plenum chamber continuously buffers the demand. The intake section allows the air to be directed through the connection system.
    3.3 The connection system
    The connection hose supplied by our company is known as TRP duct. It is the connection system can comprise several parts depending where the air box is located. In most case the Snorkel intake section is connected to the air box via a hose.
    made out of long lasting rubber impervious to chemical and reinforced by a metallic skeleton. The skeleton is critical to ensure that the hose keeps the same shape in all conditions. While it suffers a little from friction losses, it is preferable than collapsing under negative pressure and randomly restricting the air intake as it happens with some other non-reinforced connections.
    Once the engine computer management system has worked out the frictions losses; it will adjust itself and deal with them. However, if the air becomes restricted randomly by the loss of volume in the hose connection, it is unable to adjust in time to cater for these situations. The tuning would then become inadequate.
    4.0 Conclusion
    By fitting an ACAIS, you should notice quite a lot of improvement to the behaviour of your vehicle.
    · Improved air flow to engine intake
    · Improved output in both torque and horse power
    · Improved engine response
    · Decrease in turbo lag
    · Lessening of emissions
    · Lessening of air deflection by the air ram
    · Higher degree of air separation
    · Higher air flow inside the snorkel body
    Our ACAIS is calculated to provide a minimum 200% of free air to the inlet as base load. All these advantages result from Cold Air Induction
    System being a net COMPRESSION system. It is unlike other manufacturers that supply net VACUUM systems. With ACAIS, the crossing of water is a BONUS!
    Here is an Airflow on an 2008 Tacoma:
    12657766_10208570966222183_3781017411669438325_o.jpg Screen Shot 2016-01-31 at 10.04.34 PM.jpg Screen Shot 2016-01-15 at 10.07.40 PM.jpg IMG_1573.jpg IMG_2210-1.jpg image-2 copy-1.jpg IMG_1519.jpg
    Here is an Airflow on a 2013 Tacoma (custom fit with McNeil Fiberglass):
    IMG_7607.jpg IMG_7880.jpg IMG_7900.jpg IMG_7892.jpg IMG_7893.jpg IMG_8218.jpg
    https://youtu.be/HFHlAj3w5qI
  2. Feb 10, 2017 at 8:47 AM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    Wish I had the money for one right now...stop teasing me @tcBob :annoyed:
  3. Feb 10, 2017 at 9:01 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Bump cuz Bob is the man
    mbmack1, Vanguard, uurx and 5 others like this.
  4. Feb 10, 2017 at 9:07 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    If I wasn't such a Mall Crawling Poser I would.
  5. Feb 10, 2017 at 9:11 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  6. Feb 10, 2017 at 9:28 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    But does it work on McNeil glass? ;-)
    Blackout14 likes this.
  7. Feb 10, 2017 at 9:33 AM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    It fits anything with a little :sawzall:
    Blackout14 and PottMatter like this.
  8. Feb 10, 2017 at 9:37 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Will it fit a 3rd Gen?
  9. Feb 10, 2017 at 9:45 AM
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Have they announced anything for the 3rd gens?
  10. Feb 10, 2017 at 9:57 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Gen 2 only?
  11. Feb 10, 2017 at 9:57 AM
    tcBob
    Bob
    Yep
  12. Feb 10, 2017 at 10:00 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  13. Feb 10, 2017 at 12:01 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    How many are you sitting on @tcBob?
  14. Feb 10, 2017 at 12:19 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    :eek:
  15. Feb 10, 2017 at 12:25 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Hell, I've watched all the others, might as well watch this one too.
    mbmack1, Drainbung, uurx and 2 others like this.
  16. Feb 10, 2017 at 1:39 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Hmmm. Think it'd be cool to do one some day.... but they stick out so damn far... $335 isn't too bad though.
    Wonder what my local shop would charge to install. Not cutting my own truck...
  17. Feb 10, 2017 at 1:46 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    bump a reputable member and honest seller
    I've been very happy with my airflow in my 2012, call it placebo affect but the truck seemed smoother for a second there, it really doesn't stick out terribly in my eyes
  18. Feb 10, 2017 at 2:29 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Ordered... Thanks TcBob
  19. Feb 10, 2017 at 7:25 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    My thoughts too.
    Kyitty[QUOTED] and Blackout14 like this.
  20. Feb 10, 2017 at 8:16 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Oh man, kinda want.
    Tatts521, fatfurious2 and uurx like this.
Thread Status:
