AirFlow Snorkel Group Buy!! [CLOSED]
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mahaloTaco, Mar 26, 2016.
Thread Status:
Not open for further replies.
  1. Apr 1, 2016 at 3:17 PM
    #141
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Here is the FJ Cruiser Air Cleaner. You can find these for varying prices around the net and some people sell them on fj forums for some reason.
    Basically the it forces dust to the outside and air in the middle. The dust simply falls via gravity into the discharge valve and you have to occasionally pinch a rubber piece to let the captured dust fall out.
    Additionally, donaldson makes a variety of air cleaners for just about any application. You can browse their site and see all the options. These guys make filters for industrial equipment that sees an insane amount of dust. They tend to cost more but I think all of them include an additional filter. Probably overkill for most applications unless your truck lives in dust.
    mahaloTaco[OP] likes this.
  2. Apr 1, 2016 at 7:02 PM
    #142
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    So it essentially does the same thing as the top mount prefilter except inline? Could allow for more airflow theoretically as more can enter the system if that's the case.
    If you come across anything from Donaldson in terms of model/part #'s would appreciate it.
  3. Apr 1, 2016 at 7:21 PM
    #143
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I have, ill post them tomorrow.
    mahaloTaco[OP] and tacoma16 like this.
  4. Apr 1, 2016 at 7:34 PM
    #144
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    I will have to look into one of these prefilters. I want to keep my engine as safe as possible.
    BabyTaco likes this.
  5. Apr 1, 2016 at 7:39 PM
    #145
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    I'm not worried about a prefilter...there are a lot of people showing a normal factory intake filter and then one with a snorkel attached and the snorkel setup came out cleaner
  6. Apr 1, 2016 at 7:50 PM
    #146
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
  7. Apr 1, 2016 at 7:59 PM
    #147
    BabyTaco
    Wyoming
    2011 RC Tacoma
    A lot of guys run 35s without any changes to their air box and never have troubles. But I just got done paying $3500 for an engine rebuild because dust entered my engine. I'd rather be protected.
    slodc4[QUOTED] likes this.
  8. Apr 1, 2016 at 8:04 PM
    #148
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    With the stock filter intact? I've never seen an engine fail from actual air dust contamination without more to the story than a dirty filter.
  9. Apr 1, 2016 at 8:27 PM
    #149
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I think because he added 35's that he cut his fenders, flares, and removed the splash gaurd to fit the 35's this exposes the intake and allows dust and water to be sucked right in. Most that do this re route the intake to avoid this , by means of a snorkel or cold air Intake. But I'm just guessing
    mahaloTaco[OP] and slodc4 like this.
  10. Apr 1, 2016 at 8:34 PM
    #150
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah that makes sense. It's the water that's the real problem. Once the filters wet it begins to fail and let dust by. Then good bye engine.
  11. Apr 1, 2016 at 8:51 PM
    #151
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Yeah, I ran a afe drop in for a short period but otherwise stock filter. And yep the fender liner was cut, but then replaced after finding out I was sucking in dirt. That stopped the mud chunks not dust. There was a lot of weird things about the engine when we tore it down but there was a ton of dirt in the intake. Regardless, I had a bunch of people saying that its not a big deal because they have been sucking mud with no problems.
    Not arguing that it is probably not needed but if I can minimize the dust at all, I will.
    slodc4 likes this.
  12. Apr 1, 2016 at 8:52 PM
    #152
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    I'm in for one for a 2012!
    mahaloTaco[OP] and Jrahn0822 like this.
  13. Apr 1, 2016 at 9:01 PM
    #153
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Did you remove the secondary filter in the air filter box.the one before the ma's air flow sensor. I know I have seen some people do this and always thought that was a bad idea.
  14. Apr 1, 2016 at 9:04 PM
    #154
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah. Just keep in mind every joint and exposed port, like on an in line precleaner, is another point for water and dirt to get sucked in. If it's before the MAF you'll never know until it's too late so seal those joints as best as possible :).
  15. Apr 2, 2016 at 10:56 AM
    #155
    rhc0930
    rhc0930 Well-Known Member
    Houston
    14' TRD Sport 4x4
    3 Inch Lift 33 Inch Tires Subs Tint
    :rofl:Put me on the list. This is how you know I'm young, dumb, and have too much money!:bananadead:
  16. Apr 2, 2016 at 11:00 AM
    #156
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    I want in! Requesting to be on the list :yes:
  17. Apr 2, 2016 at 1:20 PM
    #157
    EODwick
    EODwick Fire In The Hole!
    Ed
    Box Elder, SD
    2013 TRD Sport
    Stuff I Think Makes it Better
    I'm in, if still open
  18. Apr 2, 2016 at 1:21 PM
    #158
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Hasn't even started :laugh:
    mahaloTaco[OP] and Acerwin like this.
  19. Apr 2, 2016 at 3:20 PM
    #159
    bski22
    Rob
    Toyota
    Better to be early than late. Fact
    mahaloTaco[OP] and BabyTaco like this.
  20. Apr 3, 2016 at 12:42 AM
    #160
    mahaloTaco
    mahaloTaco [OP] TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Done:thumbsup:
    Thanks for the interest guys.
    Help spread the word so we can get an even lower price:hattip:
    Enjoy the Video!
    https://www.youtube.com/watch?v=j7gZ28Msa8g
    bski22[QUOTED] likes this.
Thread Status:
