Airing down at mid speed
Discussion in 'Wheels & Tires' started by Jrobertson, May 30, 2016.
  1. May 30, 2016 at 1:16 PM
    Jrobertson
    Jrobertson [OP] Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    Hello all.
    The type of off roading I do here in Vegas is mostly long trails. Often times I can do 30-40 on my stock suspension. Once my fox coilovers are in I would imagine I would be doing that speed a lot more. Often the speed drops to 2-15 mph for areas with boulders and steep climbs etc. running stock all retain tired now 265-75r16. I aired them down to about 15psi while out and about. Is that a good PSI for the range of speeds I am looking at? Do I have a risk of loosing a bead at those speeds and ties pressure? What would you recommend.
  2. May 30, 2016 at 1:21 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    I usually air down 25psi front and 20psi rear and I wouldn't go faster than 40mph. :notsure: Anyone wanna chime in
    Jrobertson[OP] likes this.
  3. May 30, 2016 at 1:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've read somewhere that airing down on stock tires can cause issues due to a weak sidewall. Something to research. As far as the pressure, as long as you don't make any sharp turns you should be fine. I run at 20 psi though.
  4. May 30, 2016 at 1:37 PM
    Jrobertson
    James
    Stock. For now.
    Yeah I'm not going down to like 7-8psi like some on other tires. Finding a corolation to airing down to help prevent punctures in the desert. Compared to being able to maintain some speed seems hard to come bu
  5. Jun 4, 2016 at 9:45 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I've run my tires for fairly long periods at 16psi over all sorts of terrain at speeds of up to 50mph. I wouldn't recommend doing this on gravel or pavement for extended periods though.
  6. Jun 4, 2016 at 9:49 AM
    eon_blue
    Azusa, CA
    I always go down to 20 psi for the type of trails you're talking about, we have the same ones out here in socal. I've never had any issues, and the last trail (Mille Jeep trail) was very rocky.
