airing down questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MelonPitch, Mar 9, 2019.
  1. Mar 9, 2019 at 1:31 AM
    MelonPitch
    MelonPitch [OP] Active Member
    2019 Tacoma TRD-OR DCLB
  2. Mar 9, 2019 at 1:40 AM
    s.e.charles
    s.e.charles Well-Known Member
  3. Mar 9, 2019 at 2:00 AM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    I have that kit and I love it. Super solid set up. ARB also makes a portable kit that comes in a box if you don't want to bolt it in your truck.
    As far as airing down, I took mine wheeling (with stock tires) and I think I aired down to 15 psi. Felt ok, I liked it.
    I'd say start at 20 - 24 psi and see how you like it. That's what I did and went down from there.
  4. Mar 9, 2019 at 4:36 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
  5. Mar 9, 2019 at 4:52 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    That kit is great. The deflator that is included in that kit makes airing down much more enjoyable. ARB makes top quality products. I typically air down to 12 PSI and a kit like this will make your life much easier.
  6. Mar 9, 2019 at 4:58 AM
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
  7. Mar 9, 2019 at 8:27 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I don’t have the same compressor but I do use the air up and air down kits.
    I’ve aired the stock tires down to about 12 and that’s about the extent of my comfort level.
    How much you air down really depends on the terrain you are doing and how you are driving.
    Don’t be afraid to throw a bead. It happens, just throw your spare on.
  8. Mar 9, 2019 at 2:19 PM
    s.e.charles
  9. Mar 9, 2019 at 3:54 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    That kit is really good. If you want something a little more starter, the Viair 88p is a really good portable compressor that hooks to your battery, and that will save you on the on board ARB compressor and air hose kit.
    Whatever compressor you get, definitely get the ARB deflator, a lot of people skimp on the deflating stuff, and it's a huge pain to spend 5+ minutes airing down one tire when you want to get going. The ARB deflator captures and removes the stem core, rather than just depressing it, which allows for much faster air evacuation.
    Sterling_vH111 likes this.
  10. Mar 9, 2019 at 4:05 PM
    s.e.charles
    and remember most compressors draw enough power to keep your engine running while using them.
  11. Mar 9, 2019 at 4:12 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    As others have said, that’s a very high quality kit, nothing wrong with that.
    You could save probably 50% and go with 3 essentials.
    - Viair compressor or other inflator with battery cables (I have a smittybuilt, works fine for my 33” tires)
    - A tire deflator that pulles the valve stem core out
    - a simple accurate press on gauge for checking pressures when airing back up (defators are a bit time consuming)
    Probably get all three for about $150 with good quality items.
    Arrieta578 likes this.
  12. Mar 9, 2019 at 4:15 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Like everyone said, that kit is top notch. Buy once, cry once right.
    That said, I have used a set of Trailhead deflators ($55) (screw them on and forget about them..they stop at their set PSI) and a $45 MV50 compressor for about 6 years now. No problems at all. Total that is about $100 in gear.
  13. Mar 9, 2019 at 4:29 PM
    MelonPitch
    Okay based off what everyone is saying I think I am going to save my self some money and go with a cheaper setup.
  14. Mar 9, 2019 at 4:33 PM
    ferntr33
    ferntr33 Well-Known Member
    I wouldn’t bother with automatic deflators. I used the ARB deflator and my buddy used a car key and a digital tire gauge and he was about 5 seconds slower than mine. My point being we have small tires so by he time you screw it on and move to next tire it will be done. Save your money on a better compressor. My buddy has harbor freight compressor and it takes him about 15 min to air up. It takes me about 45 sec a tire. I have dual ARB. Once I add the air tank I assume it will be a smidge faster.
    If I were to do it again I might mess with the idea of getting two VIAR compressors and run them to a small tank. If you look at dual ARB it’s literally two singles put together.
    tonered and Taco_Craig like this.
  15. Mar 9, 2019 at 4:34 PM
    Amchuge
    Amchuge Well-Known Member
    2018 Tacoma trd pro
    Is there anything wrong with just using the tire pressure cap to deflate the tire
  16. Mar 9, 2019 at 4:36 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    As great as that kit is its not portable so you have to be willing to bolt that in etc.
    The tire deflator is great to have . Can get a cheaper portable compressor that will work fine.
    I have a viair 400-p
  17. Mar 9, 2019 at 4:39 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I don't believe anyone who says just pressing the stem is as fast as a core capturing deflator. I have wheeled with tons of guys who just use an inflator with a button, or a key, or whatever they have to deflate, and often I'm done the whole truck when they're just moving on to tire #2.
    jokercykoe likes this.
  18. Mar 9, 2019 at 5:17 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I have a cheaper knock-off tire deflator, and it seems to be of reasonable quality ($20-$30). I've used the ARB and it was nice, too. To be honest, most of time I just use the button on the side of my pressure gauge. The deflator is more of a nice-to-have thing.
    The compressor is way more important. Get a beefy one. I have a Viair (440p) and I like it, but everyone has a favorite brand. Just get one that pushes a lot of air.
  19. Mar 9, 2019 at 8:30 PM
    erok81
    erok81 Well-Known Member
    Imposter
    100% that. After using a deflator like that there is nothing else.
    When I had regular wheels I’d usually go down to 15. No issues ever.
  20. Mar 9, 2019 at 9:21 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I've been eying this indeflate thing, but I don't buy that it is at all worth the hefty price tag.
