airing down questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MelonPitch, Mar 9, 2019.
  1. Mar 9, 2019 at 9:39 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
  2. Mar 9, 2019 at 9:48 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Trust me. I put it off for a long time because of that. I used someone’s at one point. Granted up until I’d use a stick or small rock and a tire gauge. So that might have something do with how impressed I was. :rofl:
  3. Mar 9, 2019 at 9:51 PM
    svdude
    svdude Well-Known Member
    jonathan
    Nah, hit the tire with your air compressor and pull the tire to the side of the lost bead. It will catch and the bead will reseat at about 30-40 psi. If you have high pressure air (co2), reseating a bead is easier. No need for a spare unless you puncture a tire.
    JoeCOVA[QUOTED] likes this.
  4. Mar 9, 2019 at 9:53 PM
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    I have a $35 smittybilt rapid deflator and a $30 harbor freight compressor that hooks the 12v outlet. The compressor is slow and I don’t think it would pump a tire bigger than a 31 but it gets the job done.
  5. Mar 9, 2019 at 9:59 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I meant this thing: https://www.metaltech4x4.com/indeflate-tire-deflator-inflator/
    erok81[QUOTED] likes this.
  6. Mar 9, 2019 at 10:01 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Also, need to be careful if you are getting a cheap compressor, as a lot of them have really poor duty cycle, and will result in upwards of an hour to bring all four tires up to pressure depending on how low you deflate them. For example, some cheaper compressors have like a 10-15 minutes on, 10-15 minutes off duty cycle, meaning you can inflate maybe one tire in 20-30 minutes.
  7. Mar 9, 2019 at 10:09 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    No way in hell am I running that high of PSI to set a bead. That PSI exceeds some tire ratings to include my own and the fastest way to an injury.
    But I agree attempted inflation could do the trick, gotta love OBA. Admittedly it took like 5psi to set my beads.
  8. Mar 9, 2019 at 10:10 PM
    erok81
    Imposter
  9. Mar 9, 2019 at 10:13 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Why spend the money on a deflator? You get a inflator with a gauge and leave it disconnected from the air. Press the handle in to drop PSI and then let off and it will give you a reading. Continue until desired PSI.
    Unless you wanna look sweet because ou have all these gadgets and like blowing money on stupid stuff...
    MFTAF13 likes this.
  10. Mar 9, 2019 at 10:14 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Hey @MelonPitch now that you know what compressor you want to buy for inflation, let’s talk about those Wrangler tires of yours... are you going to be driving with them on beach sand or rocks? o_O
    friendlywithbears likes this.
  11. Mar 9, 2019 at 10:14 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I just use starting fluid on the tire bead much easier to reset the bead
  12. Mar 9, 2019 at 10:16 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah, I could see how it would be awesome for deflating, but not totally sold on inflation benefit. I'm actually not sure whether my dual compressor is limited by the throughput of the single hose, so maybe it would actually work...lot of money for a setup though!
  13. Mar 9, 2019 at 10:17 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    I've been looking into a power tank. I'm just trying to find a spot to mount it. A lot faster than a compressor, and you don't have to worry about it failing on you with your tires at 15 psi, but you have to refill periodically.
  14. Mar 9, 2019 at 10:23 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I stopped rock crawling in 1999 and all we used for onboard air was converted AC compressors to air up tires if a tire popped a bead it was quickly reseated using starting fluid
    OnHartung'sRoad likes this.
  15. Mar 9, 2019 at 10:23 PM
    #35
    svdude
    jonathan
    I could be off on the pressure to seat the bead, however I highly doubtful 40 pounds will exceed any manufacturer rating. Once the bead is set, reduce the pressure before driving on it. Either way, whatever pressure is required for you to seat the bead is the same pressure the guys at the tire shop will need to set the bead. Only difference is they use a lube when they seat the bead. People have been seating beads on the trail for years without issues, I have done it as well.
    As for pressures, I have been wheeling at about 10-12 psi for several years and only recently lost a bead. I think I would have lost that bead even at 15 psi as well.
    Taco_Craig and JoeCOVA[QUOTED] like this.
  16. Mar 9, 2019 at 10:32 PM
    #36
    erok81
    Imposter
    40psi?
    Removing the valve core makes it a hell of a lot faster going from 30 to15.
  17. Mar 9, 2019 at 10:48 PM
    #37
    OnHartung'sRoad
    I like the cinch strap rebeading method, used it successfully twice on friends’ trucks.
  18. Mar 9, 2019 at 10:52 PM
    #38
    OnHartung'sRoad
    @MelonPitch - I was serious about that question about tires though, if you are airing down on sand that’s fine, but several of us here have had flats running the stock Kevlars on rocky roads that were not that bad, even two on the same trip like me, just a suggestion that maybe you should get better tires if doing that before thinking about airing the Wranglers down. I wouldn’t worry about it if beach driving, though- they will be fine for that.
  19. Mar 9, 2019 at 11:14 PM
    #39
    MelonPitch
    MelonPitch [OP] Active Member
    2019 Tacoma TRD-OR DCLB
    Think it would be a mix, I believe most of the trails closest to me are on the sandy side.
  20. Mar 9, 2019 at 11:15 PM
    #40
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You can do that as well, but that’s an extra tool to carry doing it with the inflator doesn’t take that much longer. And no risk of potentially losing one and being screwed in the middle of no where if you don’t have another. Although I guess you could take the one out of your spare if needed.
