airing down questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MelonPitch, Mar 9, 2019.
  1. Mar 10, 2019 at 12:04 AM
    #41
    erok81
    erok81 Well-Known Member
    Imposter
    The arb one screws onto the valve stem, removes the core, then you screw it back on. Unless you blatantly ignore the instructions you aren’t losing anything.
  2. Mar 10, 2019 at 12:40 AM
    #42
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    A CO2 tank is definitely the way to go. Not necessarily the Power Tank brand though.
    Power tanks ARE pretty, but they are also expensive. I bought a 20# tank from my local welding supply dealer for about 1/4 the price of a power tank. AND they, or any other welding supplier will swap it out for a refilled one anytime I need it.
    Getting one of those PRETTY tanks refilled can be a hassle. Many places won't do them at all.
    I bought the same regulator that Power Tank sells from a different supplier for about 1/4 also.
    Now for the reasons to go with CO2:
    1. Faster air up. From start to finish, I can air up all 4 265/75R15 tires on my Colorado from 15 psi to 32 psi in less than 5 minutes. No onboard air compressor that I know of can come close to matching that.
    2. Can operate high volume air tools, such as an impact wrench with it.
    Yeah, the tank needs to be refilled. But not as often as some would think. I use mine a good bit and only have it refilled every couple of years.
    Safely note: A CO2 tank can be transported laying on its side, but absolutely MUST be standing upright to use it.
  3. Mar 10, 2019 at 1:00 AM
    #43
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
  4. Mar 10, 2019 at 1:11 AM
    #44
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  5. Mar 10, 2019 at 1:15 AM
    #45
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
    I use an OLD Oasis kit for airing down and it simply works. I Test it with good old shade tree mechanic stuff but it works.
    Airing UP has never been an issue.
  6. Mar 10, 2019 at 1:46 PM
    #46
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Just don’t spin them on rocks, you’ll be fine.
  7. Mar 10, 2019 at 1:52 PM
    #47
    ferntr33
    ferntr33 Well-Known Member
    I agree until you factor in screwing ARB deflator then unscrewing valve stem then rescrewing valve stem and unscrewing deflator. 4X Also stock tires don’t hold that much air. That being said I have 285/75r16 and buddy has 275/70r17 and we went from 32psi to 20psi. I’m just saying I was surprised. I still use my ARB though.
    Airing down larger tires is a completely different story. This info is meant for OP. Invest money in system to inflate tires before deflating tires. If I wasn’t going to be running F/R air lockers I might have built a c02 system.
    Taco_Craig likes this.
  8. Mar 10, 2019 at 4:01 PM
    #48
    David K
    I got the deflators as a gift and used them a few times... I actually don't think they save much time over just going to each tire and using a small tool or pen cap to depress the valve and deflate. Maybe 2-3 minutes per tire to drop from 34 psi to 18 psi (my first go-to pressure for deep sand driving on my Hankook Dyna-Pro tires). The BFGs the truck came with floated at 15 psi max but 12 was better. All Terrain TAs and mud terrain style tires need to be down to 10 psi before they will float on sand.
    Fear not down to 8 psi if needed... but do not drive fast, hit the brakes, or turn sharply when deflated!
