Airing Down Tires On 4x4 Roads
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arcpass, Dec 31, 2017.
  1. Jan 2, 2018 at 7:18 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I haven’t lost a bead yet either, and never aired down past 30psi. Got a new compressor so I will have to try doing more next time I’m out. Thanks!
    JoeCOVA[QUOTED] likes this.
  2. Jan 2, 2018 at 7:32 AM
    Dissent86
    Dissent86 Well-Known Member
    Ben
    2016 trd offroad Tacoma.
    Ratchet strap and good compressor will do the trick most of the time, if that doesn't work you can use the starting fluid trick. I have set a few beads on my rock crawlers with the method. https://m.youtube.com/watch?v=t0emi48dx_4
    Jeremy4x4, kbp810 and Bigfsur like this.
  3. Jan 2, 2018 at 7:34 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    KO2 E rated 285 tires run at 40 psi on the road and 15 psi when off roading.
    No one has mentioned this yet that I've read but airing down too low can cause the tire side walls to heat up and with the extra stresses causing delamination of the plys possible leading to premature failure or decrease tire longevity.
    I personality wouldn't air down below 30 if you are caring any type of speeds above 20 mph but others might have experience where its fine. Food for thought!
    Adrianc0143 likes this.
  4. Jan 2, 2018 at 6:43 PM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    Thanks to all who replied with what their doing - experience is the best teacher. I will be getting a better air system, and have ratchet straps so I feel more confident now.
  5. Nov 19, 2018 at 10:54 PM
    Marcoma91
    Marcoma91 Well-Known Member
    Marc
    Los Angeles
    2002 Tacoma PreRunner Dbl Cab. Bilstien 5100, OME 883, AAL, 265/75 R16
    Anyone have experience airing down only the rear in a 2wd? I’m thinking this would be beneficial in sand. Just randomly though about it.
  6. Nov 19, 2018 at 11:19 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Airing down allows for a larger foot print which will increase traction . My old Jeep Rock Crawler my highway pressure was 25psi and trail pressure 11-15psi . For running on sand I would drop down to under 10lbs
  7. Nov 19, 2018 at 11:21 PM
    eon_blue
    Azusa, CA
    Be careful running under 10psi even in sand...I was in the dunes last weekend and a buddy popped a bead on his 33" ko2s coming down a slope. I usually run 12 in the sand and 15 on rocks, someone's under 10 in sand if I need to get unstuck but I'll air up a little pretty soon afterward
  8. Nov 19, 2018 at 11:23 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I never had an issue popping a bead in the Sand !!
  9. Nov 19, 2018 at 11:25 PM
    eon_blue
    Azusa, CA
    It was the first time I'd seen it happen myself but it wasn't fun trying to reseat the bead in the deep sand lol. We ended up using a ratchet strap and air compressor to put it back on and it worked like a charm
  10. Nov 19, 2018 at 11:28 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I used dirt track bead sealant to glue the bead to the rim !!
    TS7xTaco and eon_blue[QUOTED] like this.
  11. Nov 20, 2018 at 12:05 AM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Say your TPMS is set to light up at 25psi or below. If you air down below 25psi I would think so?
    15psi on dirt roads makes going over little potholes and bumps a lot smoother. We have done up to 35mph if not more but less than 50mph in 4wd, stock size tires on 1st gen and 3rd gen. I wouldn’t go below 15psi unless doing some extreme rock obstacles.
    A portable tire compressor is a must if you go off road and air down your tires. I have the Viair 400P and it works great. Takes some time when you do 3 trucks though :)
    Since this is an old thread I doubt OP is active much...
    Califor2A and tonered like this.
  12. Nov 20, 2018 at 5:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've been really happy with 20psi but still am getting comfortable with what the sidewall can take. I've spooned a lot of motorcycle tires but don't look forward to doing that on a trail with a truck.
    With that, we got to see someone set two beads using starter fluid this past weekend. Pretty freaking epic and easy.
    I'm not certain how happy the tire sensor would be with either that pressure or heat spike.
  13. Nov 20, 2018 at 6:04 AM
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    You guys "airing down to 30 to 35" are wild!! Kidding aside, I run 30 to 35 daily, and air down to 12 to 15 when crawling around. I keep it at about 18 to 20 when on rough ass roads for any extended period of time. Keep in mind the load range, and how YOUR tires act at different pressures as all tires are different. The width of the tire against the width of the wheel, will yield different minimums. A wide tire on a narrower wheel will hold a bead better than the opposite... There are lots of things to consider.
    Califor2A, cbrcolin, hiPSI and 3 others like this.
  14. Nov 20, 2018 at 6:07 AM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    20 on washboard roads for me
    tonered likes this.
  15. Nov 20, 2018 at 6:13 AM
    #35
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    They didn’t want to trigger their TPMS :)
    TS7xTaco[QUOTED] likes this.
  16. Nov 20, 2018 at 6:14 AM
    #36
    Jeff@ExE
    Jeff@ExE Well-Known Member
    Jeff
    2016 Toyota Tacoma
    A Lot
    we usually will air down as soon as we hit dirt; around 15-17 for most FS roads that we will be on for any long periods of time; most of our FS roads are potholed pretty bad, this makes the ride much more tolerable and easier on the truck. For trails anywhere from 10psi or down to 4 in deep snow.
  17. Nov 21, 2018 at 1:20 PM
    #37
    eon_blue
    Azusa, CA
    lol yeah, 30 or 35 isn't airing down at all...that's normal tire pressure. 15psi is the sweet spot for me, but with e-rated tires the sidewall barely starts to flex at that point. I think the lowest I'd be comfortable using is 12 on a trail, maybe a tad less in sand.
    TS7xTaco[QUOTED] and tonered like this.
  18. Nov 22, 2018 at 6:12 PM
    #38
    FreeVillains
    FreeVillains Well-Known Member
    Ashburn, VA
    2018 Super White TRD Off-Road DCSB Tech/Prem Pkg
    No issues doing 3 trucks with a duty cycle of 33%? No over heating? Looking into picking up a 400P automatic.
  19. Nov 22, 2018 at 6:50 PM
    #39
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Air down to 18-20 psi. That way, you still have one shot left when you get stuck and can air down to 12-15 psi to maybe get out. Always have a plan B.
  20. Nov 22, 2018 at 6:51 PM
    #40
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    There’s a lot of bullshit info in here fellas.
    Califor2A and mynewtoy like this.
