Airing Down Tires On 4x4 Roads
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arcpass, Dec 31, 2017.
  1. Nov 22, 2018 at 6:52 PM
    #41
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I run 5, no beadlocks. Haven’t blown a bead yet.
    mynewtoy likes this.
  2. Nov 22, 2018 at 6:59 PM
    #42
    Skymaster
    Skymaster Well-Known Member
    Atwater CA
    TRD OR, White DCSB
    I run E rated ST MAXX. 42-45 psi on the road and air down to 12-15 for wheeling in the Sierra Nevada’s. Never popped a bead and I have seen these tires deform in ways I have never thought possible.
  3. Nov 22, 2018 at 7:02 PM
    #43
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    I have run 8 psi for several 3 day trips never blew a bead. That’s a mix of forest service roads to mud to rocky hills. No bead locks.
  4. Nov 22, 2018 at 7:41 PM
    #44
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    No overheating and we did 3 trucks back to back, all at 15psi. This was at higher elevation too so maybe that’s why it took longer than usual. It was also around 60 degrees too so not sure if that helped in cooling. I’m happy with the 400p :). Comes in a handy carrying case too.
  5. Nov 22, 2018 at 7:50 PM
    #45
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    All the trails I run I go down to 15-18psi.
    Depending on ambient temp and how much weight I've got whether loaded for camping or just day run.
    TPMS comes on but goes off once back up.
    It's not just for reducing puncture, better foot print, more traction, tends to mold to rocks and softens the ride.
    Mostly rocky terrain.
    I used to run higher out of fear of popping bead but no issues yet besides one time which was more from a rock pushing the sidewall and being at 10psi.
    I will say at 15 it's a huge difference from 25. After about 25psi every 2 psi you drop you'll notice a difference.
    285 70 17, duratrac 8 ply no bead lock
  6. Nov 22, 2018 at 8:20 PM
    #46
    cbrcolin
    cbrcolin Well-Known Member
    Colin
    THOUSAND PALMS, CA
    19 QUICKSAND 7545
    NONE YET
    A lot of things to consider, not just PSI but load, speed, temperature, just because you did not see deformity to your tire does not mean it was not damaged.
    Low PSI at very slow speeds is ok, but at higher speeds will definitely damage sidewalls. also very low PSI will reduce ground clearance.
