Airing Down Tires
Discussion in 'Off-Roading & Trails' started by CollegeKevin, Apr 3, 2012.
  1. Apr 3, 2012 at 6:01 PM
    CollegeKevin
    CollegeKevin [OP] Well-Known Member
    Kevin
    Long Island
    What do you guys do to air down tires. I was thinking about purchasing something similar to Staun Tyre Deflators. First time I was out on the beach (last sunday) I did it the old fashioned way by pressing in the valve stem to release the air. Took me probably 15 minutes to do all 4 tires continually letting air out and checking. Im looking for an easier way.
  2. Apr 3, 2012 at 6:05 PM
    TacoRan
    TacoRan Well-Known Member
    I use a tire deflator kit from Trailhead. You have to spend a little time calibrating them but they work great. I think they were around $45 from Amazon.
  3. Apr 3, 2012 at 6:06 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    I don't think there is a better way to do it. Stick with the old fashion cheaper don't have to spend any mOney
  4. Apr 3, 2012 at 6:21 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i just hve the cheapo deflators. mine are screw on and they press downon the valve stem. mine were like 15 bux. ijust check the pressure with a gauge, doing two tires at a time. i can air down in about 4-5 mins
  5. Apr 3, 2012 at 6:27 PM
    CollegeKevin
    Kevin
    Long Island
    I like cheap, or home made, but I also like easy and fast. I was thinking maybe the ARB EZ Deflator http://www.amazon.com/ARB-ARB505-E-Z-Deflator/dp/B004LQCDOA/ref=sr_1_1?s=automotive&ie=UTF8&qid=1333502429&sr=1-1. $20 cheaper then the Iron Man Speedy http://www.4wd1.com/tyre-deflators.htm
  6. Apr 3, 2012 at 6:28 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    mine are teraflex
  7. Apr 3, 2012 at 6:31 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    I was looking at the arb one too anybody have any experience with it?
  8. Apr 3, 2012 at 6:44 PM
    CollegeKevin
    Kevin
    Long Island
  9. Apr 3, 2012 at 7:30 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    There's also a much less expensive version of the Trailhead deflators that just stay open forever till you remove them. You just keep walking around the truck checking the pressure until they reach the pressure you want.
    Cheap, fast, works great.
  10. Apr 3, 2012 at 7:39 PM
    CollegeKevin
    Kevin
    Long Island
    But you have to unscrew them to put your tire pressure gauge on them to keep checking current pressure, or you go by counting seconds which can vary by tire temperature and altitude. I did consider this alternative.
  11. Apr 3, 2012 at 8:38 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    No, you take the pressure THROUGH the deflator without removing it, while its running. It's easy.
    The pressure gauge pops onto the deflator in the same way as it does the schrader valve itself.
  12. Apr 3, 2012 at 8:42 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    I made my own for under 5 bucks. they are screw on and by the time i get the 4th one on i can start taking the first one off. Works well for me and the price was right. (note: i found the idea online and copied it)
  13. Apr 3, 2012 at 8:43 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    I simply use my knife.
  14. Apr 3, 2012 at 8:52 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    curry ez deflator
  15. Apr 4, 2012 at 5:14 AM
    CollegeKevin
    Kevin
    Long Island
    That's a good price
  16. Apr 4, 2012 at 5:22 AM
    TacoRan
    With mine you pre-set them to deflate to whatever psi you want. When you get to the beach and/or trail you just screw them in and they deflate to that pressure and stop. Don't have to check or anything. You could even drive with them on if you want. I go to Assateague Island on the beach and there are a ton of horse flys that eat you alive where you stop to air down. Its nice to throw on the deflators and get in the cab quick.
  17. Apr 4, 2012 at 7:55 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    umm valve stem remover??
    takes me 1 minute to air down all 4 tires and only cost me a dollar.
  18. Apr 4, 2012 at 10:00 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    ARB EZ Deflator: 35.50
    The unique patented design of the ARB E-Z Deflator allows the valve core to be removed to deflate the tire rapidly. An integrated sliding valve provides an accurate reading of the tire pressure while deflation is in process. The valve core is securely held within the sliding valve mechanism during deflation. Packaged in a canvas pouch, the ARB E-Z Deflator is the perfect addition to your recovery kit. Make sure you have a compressor or CO2 system to air up when you're done playing.
    ___________________________
    TRAILHEAD Automatic Tire Deflator Kit:
    5psi to 20psi Adjustable Set: 58.00
    15psi to 40psi Adjustable Set: 58.00
    TRAILHEAD Automatic Tire Deflators offer a quick and convenient way to air down. Simply screw them onto the tire stem and they do the rest. They automatically reduce the air pressure in a tire to a preset level and then stop, preventing any further loss of air from the tire. They will function properly whether your vehicle is stationary or traveling at speeds of 20 mph or less. The kit comes as pictured with 4 deflators. Available in red, blue or silver colors. Click here to visit the TRAILHEAD website for more info. Made in the USA, Lifetime Warranty.
  19. Apr 4, 2012 at 10:01 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I use the ARB EZ Deflator. Works very fast.
  20. Apr 5, 2012 at 3:19 PM
    NYCO
    NYCO ┌∩┐(ಠ_ಠ)┌∩┐
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    x2
    easy and cheaper than arb
