Airing down tires.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDTaco13, Feb 18, 2018.
  1. Feb 18, 2018 at 7:37 PM
    TRDTaco13
    TRDTaco13 [OP] Well-Known Member
    Avelardo
    2017 Dark grey Toyota Tacoma TRD off-road.
    So today I took my new 3rd gen off roading. I’m new to it so I didn’t air down. I’m pretty sure I should’ve. What do you guys use for airing down and airing back up? And how low should I go? Sorry for my ignorance.
    Foxtato likes this.
  2. Feb 18, 2018 at 7:40 PM
    Foxtato
    Foxtato Well-Known Member
    Puyallup, WA
    2011 Tacoma 4x4
    I've done plenty of trails without airing down and didn't have any issues. However, when you air down, the ride becomes a little softer and you can roll over rocks and such with (less) worry about causing a puncture. Also increases traction since you now have a wider area.
    For airing down, you can use a standard tire pressure gauge. For airing up, I bought a simple little compressor from Costco for like $30. There are some other good portable air compressors out there for < $100, I'm sure lots of folks have recommendations. When you feel like dipping into your pocketbook a bit more, you can look into the on-board air compressors like ARB, but they are substantially more expensive (and rugged).
  3. Feb 18, 2018 at 7:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Are you looking for the rules for airing down?
    TRDTaco13[OP] likes this.
  4. Feb 18, 2018 at 7:44 PM
    tcjacado
    tcjacado Well-Known Member
    Standard air down pressure is 20 to 25
    You can go as low as 12 to 15 but risk popping the bead on the tire (meaning it's not punctured just off the rim) and pain to reseal the bead.
    Drunken Chewbacca and Foxtato like this.
  5. Feb 18, 2018 at 7:45 PM
    TRDTaco13
    Avelardo
    Thank you, i didn’t know much about it but your response helped me learning more about it. I think I’ll be airing down just to be in the safe side.
    Foxtato[QUOTED] likes this.
  6. Feb 18, 2018 at 7:45 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Airing down on rocky terrain also helps quite a bit from jarring your suspension as well as traction.
    Even on loose chunky gravel, it will feel like your in a caddy.
    Foxtato and TRDTaco13[OP] like this.
  7. Feb 18, 2018 at 7:46 PM
    Foxtato
    Puyallup, WA
    2011 Tacoma 4x4
    Like @JaCado said above, airing down to ~25psi is a safe bet. Anything below 20 and it can get a bit hairy IMO. Lots of videos and information on airing down though; YouTube is a great resource!
    tcjacado likes this.
  8. Feb 18, 2018 at 7:47 PM
    TRDTaco13
    Avelardo
    Some of these guys already have me the info I need. Just wondering what kind of portable compressor to go for.
    hiPSI[QUOTED] likes this.
  9. Feb 18, 2018 at 7:47 PM
    tcjacado
  10. Feb 18, 2018 at 7:48 PM
    Foxtato
    Puyallup, WA
    2011 Tacoma 4x4
  11. Feb 18, 2018 at 7:49 PM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I use a VIAR portable 12v compressor. A few to choose from. Works great.
  12. Feb 18, 2018 at 7:49 PM
    Matic
    Tricky Dick
    Easley, SC
  13. Feb 18, 2018 at 7:49 PM
    TRDTaco13
    Avelardo
  14. Feb 18, 2018 at 7:50 PM
    Matic
    Tricky Dick
    Easley, SC
    JimboAnz likes this.
  15. Feb 18, 2018 at 7:50 PM
    Foxtato
    Puyallup, WA
    2011 Tacoma 4x4
    Matic[QUOTED] and tcjacado like this.
  16. Feb 18, 2018 at 7:51 PM
    tcjacado
    just find a way to push the valve stem down to let air out.... stick, rock, etc...and a tire gauge to judge when to stop.
    TRDTaco13[QUOTED][OP] likes this.
  17. Feb 18, 2018 at 7:53 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    I am very particular when airing back up. I like using a mix containing 78% nitrogen.
  18. Feb 18, 2018 at 7:55 PM
    Matic
    Tricky Dick
    Easley, SC
    I have one of the arb tools that pulls the stem out for quickly releasing air. Used it once and it shot the stem about 7 feet somewhere off in the gravel.
    Took me an hour to find it. lol. I just use a stick or small rock till I can get some practice using it. :)
    m603holden likes this.
  19. Feb 18, 2018 at 7:55 PM
    tcjacado
    He's a rookie:smack:
    DubfromGA and Ackrite[QUOTED] like this.
  20. Feb 18, 2018 at 7:57 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
