Airing down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spudboy82, Jun 20, 2019.
  1. Jun 20, 2019 at 11:07 AM
    spudboy82
    spudboy82 [OP] Weekend Warrior looking forward to Utah getaways!
    Sean
    Logan, Ut
    Blazin Blue DCLB
    2017
    Hey guys question I’m doing a trip this weekend with the wife and kid so it’s going to be mostly fire service roads so nothing crazy I’m still running stock tires on my trd sport should I air down and if so to what PSI would you recommend thanks for the help
  2. Jun 20, 2019 at 11:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It will make it much nicer for your fam. Also, washboard is 100% better aired down.
    20psi gives a nice soft sidewall and no worries as long as you don't do anything really crazy. I've seen folks do interesting stuff with 10psi and no problems.
    hiPSI and El_Rocinante like this.
  3. Jun 20, 2019 at 11:11 AM
    Tacospike
    Two Trucks
    Idk if you need to for that. Depends on the terrain.
  4. Jun 20, 2019 at 11:11 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you have a real portable compressor (e.g., ViAir xxx)? When you air down you will also need to air up.
    Logging/fire service roads, airing down is not necessary unless you get stuck.
    YMMV.
    tonered, hiPSI and SR-71A like this.
  5. Jun 20, 2019 at 11:14 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Not to harp on them, well OK, yes I am. I’ve had a blowout and flat with the Kevlars off road. Be really careful where you are using them - don’t spin them, even accidentally, and don’t drive near sticks.
    tonered likes this.
  6. Jun 20, 2019 at 11:28 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    I don’t know much about the tires on Sports. The few I’ve seen don’t look very trail ready.
    All I can say is air down and avoid big rocks.
    PS - hope you have a portable compressor that connects to the battery; anything that connects to the lighter is pretty much worthless.
    Have fun and good luck.
  7. Jun 20, 2019 at 11:40 AM
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    tires on the Sports ain't great. air down and be familiar with getting your spare down/ mounted. i know fire roads aren't the most difficult, but you'd be surprised what could pop up if they aren't maintained.
  8. Jun 20, 2019 at 11:59 AM
    cdroberts85
    cdroberts85 Member
    Southern California
    '18 TACO DCSB 4x4 SPORT
    I've been on fire roads and some rocky areas without airing down on stocks without issue, but you never know. Probably better safe than sorry
  9. Jun 20, 2019 at 12:02 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Depends on your tires and terrain, generally speaking - if it's mostly forest roads and light trails, airing down isn't necessary imo, but does make things easier on your vehicle, passengers, and will give you more surface area.
    On P rated tires, going down to the low 20's is fine. Just be sure you have a method of airing back up, assuming you won't be near a gas or service station.
    To give you an example, I have the stock OR wrangler tires and usually do not need to air down for (most likely) similar terrain - I have not experienced issues so far. Granted, the tires are still new. That said, the AT tires on OR vs Sport trims are generally better off of pavement.
    One last thing to note - it is a good idea to consider bringing basic recovery gear with you, which would mainly consist of a good shovel and recovery boards. Those items, as well as airing down, should get you out of most light situations.
    Have fun dude!
    MJTH and tonered like this.
  10. Jun 20, 2019 at 12:03 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I like to go down to around 20 PSI even for just washboarded roads it will give you better control and a smoother ride. Super aired up tires and too much speed on those roads and you can get sideways.
    tonered likes this.
  11. Jun 20, 2019 at 12:04 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Lol... depends on the fire roads.
    Pictures all taken on fire roads in the last couple weeks.
    May not be "necessary" but certainly advisable.
    Red18Taco707 and tonered like this.
  12. Jun 20, 2019 at 12:09 PM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Yeah what these guys said. Airing down will make it a smoother ride. When I didn’t have a compressor I would go down from 22-25 psi.
    Now I have KO2s and a compressor. Last trip I went down to 10-12 psi :bananadead: but I was going really slow over rocks and stuff.
    tonered likes this.
