Airing up the spare
Discussion in 'Wheels & Tires' started by sawdust, Dec 28, 2007.
  1. Dec 30, 2007 at 7:00 AM
    #41
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    That's a good idea! I used those when I had to work on my house to meet inspection before we could buy it. Electricity wasn't hooked up when we started, and didn't want to run the bill up before we owned it when there were several lights we couldn't turn off. So I'd hang two of those lights over the bed to see while loading the trucks and kill the breakers in the house.
    Now, I'll probably just turn these on... :D
    th_DSCF1256_dc097777fc127b267ffb337ea7212aaf82208a6f.jpgth_DSCF1255_7e3e58b038197a06e9b65ebb9fb1348ff465de3c.jpgth_DSCF1254_db298dcc46d19bd6203075324c946c34e7ed2fb2.jpg
    Shared with Flock - The Social Web Browser
    http://flock.com
  2. Jan 1, 2008 at 8:35 PM
    #42
    sawdust
    sawdust [OP] Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    Now that's useful info. After waffling based upon the discussion here, I'm back to my original idea. I'm off to do some searching.
  3. Jan 2, 2008 at 9:01 AM
    #43
    sawdust
    Frisco, TX
    I just found something that looks perfect. It's specifically for spare tires. I need to crawl back under the truck to make sure 36 inches is a good length.
    If anyone else is interested it seems "tire valve extension" is the magic search term to use. Adding "flexible" sometimes help narrow down the search.
  4. Jan 2, 2008 at 11:35 AM
    #44
    danusa
    danusa Well-Known Member
    I like the Steamlight Stinger. There is an LED version out now, but this will do.
  5. Jan 8, 2008 at 3:29 PM
    #45
    sawdust
    Frisco, TX
    I just found a cheaper alternative to extend the spare tire valve stem and wanted to document it here. $6 (then that again in shipping)
  6. Aug 8, 2008 at 8:46 PM
    #46
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    If you attach an extension air pressure hose onto the spare tire, the metal screw that compresses the valve in the stem will trigger the remote air pressure sensor inside the tire and send a signal to the dash, thus your remote air pressure sensor will ALWAYS be on.
  7. Aug 9, 2008 at 1:15 PM
    #47
    sawdust
    Frisco, TX
    I've had it on for a few months now and that has not been a problem. Thanks for posting though.
  8. Aug 9, 2008 at 6:35 PM
    #48
    Imrubicon
    Imrubicon Wife thinks I am done Modding truck
    Texas
    08 Access 4X4 SR5
    Shhh! the wife thinks I dont do mods on trucks anymore
    I have the double sided airchuck like you would use for duallys and it works just fine on the stock rim spare .I reach around wit hone hand to hold it in place and still the chuck through teh stiock rim wordks real easy.
  9. Jun 6, 2009 at 6:50 AM
    #49
    Mon Leb
    Mon Leb Well-Known Member
    St-Jean-sur-Richelieu, Quebec, Canada
    2009 4X4 SR5-TRD Sport
    How do you "readjust the sensors to a ridiculously low psi"?:confused:
  10. Jun 6, 2009 at 7:09 AM
    #50
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Flip tire over and attach stainless braided air hose, and route hose through trailer light electrical panel under bumper. You will never have to get under the truck to check your spare tire pressure, or fill it, again. Like this:
  11. Sep 24, 2012 at 3:42 PM
    #51
    Sargechris
    Sargechris Well-Known Member
    Oceanside, CA
    13 DCLB 4x4 TRD Sport/Tow Pyrite Mica
    BFG AT KO 265/70R17 Tires, SnugTop Sport Hi Liner, Yakima Racks / Load Warrior, WeatherTech Floor Liners, BedRug/BedMat
    Flipped my spare over today.. No problem at all on my '13...
    Now I can check the air pressure without dropping the spare! :D
    Easiest MOD there is?? :laugh:
    (It must be that Toyota wants to prevent scratching the front of the wheel when it is dropped to the ground)....
  12. Sep 24, 2012 at 3:48 PM
    #52
    Manwithoutaplan
    ID
    damn that is well played
  13. Jan 21, 2013 at 10:11 AM
    #53
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Finally did it :broccoli::rasta::amen:
  14. Jan 21, 2013 at 10:14 AM
    #54
    waheed
    Waheed
    Vancouver
    VERY nice :bowdown:
  15. Jan 21, 2013 at 10:17 AM
    #55
    waheed
    Waheed
    Vancouver
    Did yaa do it dude, was 36" long enough to go to the trailer plug in area:typing:
  16. Jan 9, 2014 at 7:09 PM
    #56
    Trail Cat
    Trail Cat Well-Known Member
    Florida to NC
    2013 TRD Sport 4x4
    Bull Bar - TRD Exhaust - Predator Side Steps - Alarm - Anytime On Fog Lights mod - OBD UltraGauge II - LED Dome & Map Lights - LED Aux BackUp Lights - LED DRL - Gate Keeper mod - TRD bed Cup Holder & Bottle Opener - Center Console Lock mod - WeatherTech Mats - Kicker Hideaway - Rear Door Speakers - Spare Tire Extension Valve mod - Tail gate 3rd Brake Light Bar - Proline Wheels - Rear Diff Breather mod (left rear tail light area) - "Florida Tacoma's" sticker - BFG A/T KO2 tires -
  17. Jan 10, 2014 at 12:11 AM
    #57
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Spare Tire Mod is done when you do the rear differential breather mod!
    My new 2005 had the valve stem pointed down (correctly). My new 2010 (same exact tire) had the stem up... It is flipped down now, and that was 3 1/2 years ago and NO ISSUES!
  18. Jan 10, 2014 at 9:51 AM
    #58
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    What's TPMS ? :stirthepot:
  19. Jan 10, 2014 at 4:01 PM
    #59
    Trail Cat
    Florida to NC
    2013 TRD Sport 4x4
    TPMS is Tire Pressure Monitor System.
    It warns you when any one of your tires including your spare tire has low tire pressure
  20. Jan 11, 2014 at 7:56 PM
    #60
    Gregman
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Sorry, I've never been very good at sarcasm.
