Airing up tires
Discussion in 'Recovery' started by amals, Dec 8, 2018.
  1. Dec 8, 2018 at 12:44 PM
    amals
    amals [OP] Active Member
    Missouri
    1996 Xtra-cab LE 2.7L 4 cyl. 4WD 5MT
    Hello, all.
    I've seen the thread on Viair compressors and it made me wonder about other ways to do it. One person mentioned a scuba tank. I have a small AC pancake air compressor. Is there a reliable and safe device to hook up to your battery that converts the car battery's DC power to AC power that is sufficient to run my compressor? If so, why would one not use something like that rather than a DC compressor like the Viair? It would also give you AC electric for other plug-in devices. My little Porter Cable does just fine for airing up tires when I plug it in at home and carry it out to the car/truck. A converter seems like a no-brainer. What am I missing?
  2. Dec 8, 2018 at 12:48 PM
    svdude
    svdude Well-Known Member
    jonathan
    Depending on the power requirements of your compressor you can buy a power inverter. Odds are if you found one powerful enough it won't be worth the cost.
    Best way to air up tires is with a co2 tank. A scuba tank is just compressed air (more or less), so you have a high pressure in the dive tank but not much volume. Co2 is a liquid when compressed and expands into a gas so you get more volume of air per tank and you get more tire fills.
  3. Dec 8, 2018 at 1:34 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Power vs weight.
    You cound get a largenough inverter 2k Watts, it’ll be cost ~200$ and require 1/0 awg wireing. Then you can carry a heavy pancake compressor. Or you can install somthing like an arb twin that runs on 12v and will match or beat a small 120v compressor for 1/3 the space weight and haste.
    Scuba tank style wound be a powertank. A good option but you have to make sure the tank is full enough, and what if you end up helping a few people. You might not have enough wire for everyone. And don’t forget about having to go to the store to get it filled every so often.
  4. Dec 8, 2018 at 4:50 PM
    amals
    Missouri
    I think I see where this is going. There is such a thing, but not cost, weight, or space efficient. So I guess I'll buy the Viair I've been looking at. Thanks.
  5. Dec 9, 2018 at 7:04 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I get CO2 tanks filled free. I had a CO2 regulator that didn't cost anything.
    That said, it's going to someone else. CO2 tanks are relatively heavy, awkward to haul and take up space I'd rather use for camping gear, etc...
    Swapping to VIAIR 400P. 30lbs + less weight. 1/2 the space required.
    CO2 works, albeit not nearly as handy as I though. And again, mine was free. VIAIR compressor will be "free"....(Christmas bonus from work)
  6. Dec 14, 2018 at 6:41 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Love my co2 tanks. Have had them for years. Portable, so you can help a buddy at the bottom of the hill without having to back down. High pressure so you can blow beads back on rims.
    svdude and koditten like this.
  7. Dec 15, 2018 at 7:41 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    20lb CO2 tanks are much heavier than a compressor.
  8. Dec 15, 2018 at 7:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    So what?
    The tank is solid mounted. The hose is moved from wheel to wheel. It weights little.
    Lots less failure points to worry about.
    svdude likes this.
  9. Dec 15, 2018 at 8:43 PM
    svdude
    jonathan
    Plus, a co2 tank is instant high pressure. Refill for $20 once every half dozen trips. Easy peasy.
    Air compressors are good too but still way slower than co2.
  10. Dec 15, 2018 at 8:49 PM
    koditten
    Kirk
    Central Michigan
    In addition, guys like me with bad knees, want those tires aired up as quick as possible.
  11. Dec 15, 2018 at 9:11 PM
    Harvo
    20lb? Holy crap. My biggest was 10. Now I have 2 fivers. They are no bigger than an extinguisher and they will fill 35 inch tires from 8psi to 28psi for several trips.
    Remember... co2 is liquid in the tank. It expands tremendously when released to gas.
