airlift 59561 w/ Headstrong progressive AAL
Discussion in 'Suspension' started by Gfunk123, Aug 26, 2018.
  1. Aug 26, 2018 at 8:13 AM
    Gfunk123
    Gfunk123 [OP] Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Does anyone know if this kit will work with the Hs progressive AAL? I've found this kit for $166. Just wondering.
    Or the ride rites
  2. Aug 30, 2018 at 4:30 PM
    Forshee47
    Forshee47 Well-Known Member
    Trent
    North Carolina
    2015 Off-road DCSB 4x4
    Since the aal sits under the stock setup there’s no height difference between the mounting points than on a stock setup so it should work just fine. Only problem I see would be if you have a u-bolt flip kit
  3. Sep 5, 2018 at 8:40 AM
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    AAL shouldn't change ride height like @Forshee47 said. I have the firestone airbags with the airlift 72000 controller and I love them for towing. The firestone bags bolt on/around the leafpack so you could probably just get longer bolts if the pack is too thick.
    I like the firestones because they go on top of the axle in place of the stock bump stop and don't create any extra torque on the leafs/axle.
