AISIN Clutch kit help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diirt, Sep 12, 2016.
  1. Sep 12, 2016 at 10:13 AM
    Diirt
    Diirt [OP] Member
    Nor Cal
    2005 Tacoma 4.0
  2. Sep 21, 2016 at 9:55 AM
    Kanween
    Kanween Olympic Lawn Dartest
    Keith
    2017 TRD Sport, Barcelona Red, M/T
    A home made bed topper/rack thing that actually works really well
    I have been trying to answer the exact same question for weeks now! I have a 2005 6speed, 4.0L, 4x4 as well. I called a few places and CKT055 does NOT superceed to CKT057, which means something is different, but nobody seems to know what the difference is. Does anyone know what changed in the transmissions along the years, if anything? If I can't get an answer before I order, I'm just going to order the CKT057 because it's cheaper.
    I heard there was something with either the slave cylinder or release bearing spacing on early trucks which caused a squeak/squeal as it barely contacted the clutch cover plate/pressure plate. Could it be related to that?
    Also, the slave cylinder is a different question. I see plenty of pictures of slave cylinders that apparently fit my truck, but I took a picture of mine, and it doesn't look the same. Mine has the bleeder coming off the aft end at a bit of an angle. There are some like that, but some that have the bleeder perpendicular to the line (pointing towards the drivers door). Any clarification on that? I was just going to buy one that looked the same since they're all the same money and probably the same quality.
    Thanks
  3. Sep 21, 2016 at 12:15 PM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I like to save money also. Buy the best clutch you can afford. Lots of work to replace so go hi quality also get the flywheel cut. Good luck let us know how you make out. Pictures would be nice
  4. Oct 12, 2016 at 2:27 PM
    Diirt
    Diirt [OP] Member
    Nor Cal
    2005 Tacoma 4.0
    So after a little more digging I found this handy Aisin parts database http://partcat.com/aisin. I read that the 057 supersedes the 055, so Im going to order one up. Hopefully it works out! Kanween did you end up buying one?
    ARCHIVE likes this.
  5. Oct 14, 2016 at 7:45 AM
    Kanween
    Keith
  6. Oct 14, 2016 at 8:05 AM
    gearcruncher
    Canadain bumper technician
  7. Oct 14, 2016 at 8:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Oct 14, 2016 at 12:12 PM
    Kanween
    Keith
    When people talk about "the fix" for these clutches, what exactly needs to be fixed?? Mine functions fine.
