Ajmogen's Hypermiling Tacoma
Discussion in '3rd Gen. Builds (2016-2023)' started by ajmogen, Apr 25, 2018.
  1. Apr 25, 2018 at 5:38 PM
    ajmogen
    ajmogen [OP] Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Current
    4/15/2016
    4/20/2018
    9/11/2018
    Vehicle: 2016 Off Road MT
    Wheels & Tires:
    255-85R16 Mastercraft Courser
    SCS SR8 16 black
    265-70-17 Nokian Rotiva AT
    4runner Pro wheels
    265-70-16 Nokian Hakkapeliitta SUV
    Stock Wheels
    Performance Mods: Stickers under the hood
    Accumulator Delete
    OVTune V2.0 Super FOB 87
    JLT oil separator
    K&N Cabin Air Filter
    Front Suspension:
    Bilstein 6112
    JBA Heavy Duty UCA's
    ECGS Bushing
    Wheelers Bump Stops
    Removed Bilstein 5100
    OME 887
    Rear Suspension:
    Fox 2.0
    Deaver U402 stage 2 BAMF Shackles
    Archive Ubolt Flip
    Extended Brake Lines
    Removed Bilstein 5100 Extended Travel Shocks
    OME 96R Pack Removed 9/6/2022 Leaf rubbing on OEM shackle
    Wheelers Super Bumps
    Lights: Caliraised LED 50" Lightbar
    Caliraised LED amber fog lights
    Caliraised LED Side Shooters
    Caliraised LED Reverse Pods
    Exterior:
    ARE MX Shell for winter
    Softopper for summer
    Prinsu Cab Rack
    AJM Fab Shell Rack
    Gear Tech Customs Splash Guards
    BAMF grill removed (for now)
    SR grill assembly
    Armor: Mobtown Sliders
    Mobtown skids
    RCI LCA skids
    SOS Front Bumper w/ full hoops
    SOS Concepts HC rear bumper w/ swingout and bed protection
    SOS Concepts Bed Stiffeners
    Interior:Husky Floor Mats
    Electrical and Comms:
    Blue Sea Fuse Box
    Uniden Pro520XL
    4' Firestick
    Kicker speakers
    SDHQ Battery Terminal Kit
    Misc: Redline Tuning Hood Struts
    Hondo Garage phone mount, wire management and radio knobs
    Fumoto F-103N (cut off N)
    Maglight 2D with mount on driver's seat
    Rear diff breather mod w/K&N filter run behind driver side brake light
    Viair 300P
    80mil Door sound deadening
    Speed Bleeders
    Badland 12000lb winch
  2. Apr 25, 2018 at 5:38 PM
    ajmogen
    Aaron
    Wisconsin
    Maintenance:
    4/15/2016 5K dealer service Smart Motors
    Tire rotation
    X/X/2016 5k
    Oil change
    X/X/2016 10k dealer service Smart Motors
    Oil change
    Tire rotation
    LCA plugs installed
    X/X/2016
    Rear diff fluid change Amsoil
    6/23/2017 15k
    oil change Mobile 1
    Tire rotation
    8/4/2017 16k Cooper ST Maxx 255-85R16 Weber Tire
    1/7/2018 20k
    Oil change Mobile 1
    Tire rotation
    4/14/2018 23k
    Suspension upgrade
    6/29/2018
    Repair rear driver side window guide
    7/26/2018
    Replace rear brake lines
    Install rear Speed Bleeders
    Bleed brakes ( Toyota DOT3)
    8/12/2018
    Remove sway bar
    8/20/2018 25000
    Oil change Mobil 1
    Rotate tires
    Lube U joints
    Replace front differential gear oil
    10/9/2018
    Parking Brake Stuck. Bang with BFH and roll in reverse to free. (22 degrees and 1175 miles from home)
    11/ 16/2018 30116
    Oil Change Mobile 1
    Rotate tires
    Lube U joints
    Clean and lube rear brakes
    Replace Air Filter
    11/17/2018
    Wax & Fluid Film
    3/21/2019
    SR8 install Weber Tire
    Discovered crack in my grill surround. Start search for replacement.
    4/5/2019
    SR grill purchased and installed
    Brakes feel hard. Order brake pads.
    4/11/2019
    Replace brake pads. Install front Speed Bleeders. Flush brake fluid.
    6/8/2019 34442
    Oil change Castrol Edge**
    Rotate tires
    Lube
    Check suspension components torque
    9/12/2019 39999
    Oil change Castrol 0W-20
    Inspection
    11/3/19
    Fluid Film
    11/16/2019
    Accumulator Delete, clutch fluid flush
    12/1/2019
    ECU flash to 04B13
    12/3/2019
    OVTune 1.05 FOB
    12/25/2019 41595
    Replace battery. True start 24F
    H9 headlight
    3/8/2020
    OVTune 2.0 Super FOB 87
    6/25/2020
    JLT Oil separator installed
    7/6/2020
    K&N Cabin air filter installed
    9/27/2020
    Wash n' Wax Meguiar's Ultimate Synthetic Wax
    Install hard shell
    10/4/2020 45024
    Oil change Castrol 0-20
    Lube chassis
    Inspect brakes
    Clean/inspect frame
    11/29/2020
    Fluid Film
    1/1/2020
    Reflash OVT 2.0/04b13
    Reset LVs
    4/1/2021 47300
    Mastercraft Courser
    255-85R16
    4/13/2021 47340
    04B14
    4/18/2021 47347
    2.0 Super FOB flash
    4/23/2021
    New battery again. Free from Toyota
    4/24/2021
    TPMS sensors installed in stock w+t
    5/8/2021
    Powerstop Drum Kit Installed
    6/13/2021 48005
    Amsoil severe gear 75-90 f+r differential
    Amsoil MT transmission
    Oil change Castrol 0-20 HM
    Lube everything
    8/15/2021 51900
    Replace coolant
    Clean K&N cabin air filter
    9/4/2021 52148
    Oil Change Castrol 0-20 HM
    9/17/2021 55K
    Engine idle surging, stalling at stoplights, CEL. Oil catch can uninstalled itself. Replace/reset MIL
    12/19/2021 56100
    Nokian Hakkapeliitta R3 SUV Installed
    3/26/2022 59106
    Nokian Rotiva AT 265 70 17 Installed
    4/2/2022 59298
    Replace Crankshaft Position Sensor
    4/17/2022
    Replace parking brake cable
    Clean and adjust rear brakes
    Lube driveshaft and UCAs
    Install 255s for upcoming trip
    Install ditch light antenna mount and tune antenna
    4/23/2022 59538
    6/21/2022 60896
    Change spark plugs
    Clean throttle body
    7/10/2022 61000
    Steering fluid service drain and fill. Valvoline ATF Dextron 3.
    8/21/2022
    Replace power steering reservoir.
    Replace clutch fluid.
    9/6/2022
    Install Deaver U402 Stage 2 leaf springs
    BAMF shackle
    11/13/2022
    Fluid Film
    Install Hakkapeliittas
    11/24/2022
    AP carrier bearing drop
    12/2/2022
    Toytech 3 degree axle shims. Driveline vibration gone.
    3/19/2023
    64967
    Oil and Lube
    LR parking brake bracket came loose. Reinstall.
    Clean and lube front brake pins. Nearly seized.
    Install summer tires.
    Top off PS fluid. About an ounce low.
    Empty catch can. Lots of fuel in there.
    Remember to check LF wheel resistance when spinning.
    3/25/2023
    64970
    Transfer case fluid change.
    Toyota 75W
    7/3/2023
    65xxx
    Coolant drain and fill.
    Raptor Liner rear bumper.
    9/15/2023
    69310
    2 stage paint correction +Adam's Graphine Ceramic
    Replace Engine Air Filter
    11/11/2023
    69888
    Woolwax
    Oil change Castrol 0W-20HM
    Chevron fuel system cleaner
    3/23/2024
    Wiper blade inserts.
    4/7/2024
    73000
    Suspension upgrade 6112/Fox2.0
    Replace JBA Ball joints
    Archive Garage Ubolt kit
    6/9/2024
    73105
    Oil + filter Castrol 0W-20HM
    10/26/2024
    77996
    Woolwax
    4/26/2025
    81238
    Oil + filter. Toyota 0W-20
    bigmw and GQ7227 like this.
  3. Apr 25, 2018 at 5:38 PM
    ajmogen
    Aaron
    Wisconsin
    Corolla Maintenance:
    2022/29/11
    1277
    Break in oil+filter change.
    Toyota 0w-16
    2023/9/15
    5002
    Oil change Mobile 1 0W-16, Rotate tires, Techron fuel system cleaner
    2024/3/29
    6321
    Oil change Toyota 0w-16
    10/26/2024
    10104
    Oil change Mobile1 0w-16
    4/26/2025
    12160
    Oil +filter Toyota 0w-16
    Rotate tires
    Techron
  4. Apr 25, 2018 at 5:38 PM
    ajmogen
    Aaron
    Wisconsin
    Platform
    Hoist
    Relay box and switches
    Shackle mount
    Mobtown sliders
    mcharfauros and Kuntrykid like this.
  5. Apr 26, 2018 at 8:58 AM
    ajmogen
    Aaron
    Wisconsin
    Dog: Maynard
    Bird: Abe
    Other dog: Walter (RIP Buddy 2/26/2022)
    New dog: Payton
  6. Jul 26, 2018 at 2:40 PM
    ajmogen
    Aaron
    Wisconsin
    Experiencing rear driver window loose condition and rattle when shutting the door (especially with the window down). Visited my local dealer for warranty fix. They couldn't fit me in so I ordered speakers and took my doors apart, and found the rubber window guide laying in the bottom of the door. Pushed it back in place, installed 80mil sound deadening and Kicker speakers.
  7. Jul 26, 2018 at 2:42 PM
    ajmogen
    Aaron
    Wisconsin
    Extended brake lines and rear Speed Bleeders installed today
    PUPS41 and doorsidedown like this.
  8. Jul 26, 2018 at 7:56 PM
    PUPS41
    PUPS41 Well-Known Member
    17 DCLBOR
    Icon's all around, Deavers, Falken, Methods
    Nice looking rig! How long are your extended brake lines? Looks like you have a good amount of travel in the rear.
  9. Jul 26, 2018 at 8:16 PM
    ajmogen
    Aaron
    Wisconsin
    Thanks! They are 24" from Headstrong
    www.headstrongoffroad.com/store/p127/24"_SS_Extended_Length_Rear_Brake_Lines_%28PAIR%29_-_05__Tacoma.html
  10. Jul 26, 2018 at 8:46 PM
    PUPS41
    17 DCLBOR
    Thank you. Much appreciated.
  11. Aug 4, 2018 at 3:48 PM
    ajmogen
    Aaron
    Wisconsin
    Tube bumper planning
    No tube bender yet , so this project will start it's life as a hidden winch. 1/4" plate frame with 3"angle for bracing.
    Cardboard layout
    Framework laid out. I'll test fit this weekend and tack it together next week. I'm going to have to start considering weight reduction in this design.
    quis23, BEAR_KNIFE_FIGHT and prest14 like this.
  12. Aug 18, 2018 at 4:09 PM
    ajmogen
    Aaron
    Wisconsin
    Drove a T4R OR today. It's a nice wagon.
    BEAR_KNIFE_FIGHT likes this.
  13. Aug 28, 2018 at 2:23 PM
    ajmogen
    Aaron
    Wisconsin
    Winch mount tacked together, fits like a glove.
  14. Sep 8, 2018 at 9:30 AM
    ajmogen
    Aaron
    Wisconsin
    Winch mount progress
    mcharfauros and BEAR_KNIFE_FIGHT like this.
  15. Sep 8, 2018 at 9:33 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    BEEFY tow points. That looks really good. Are you planning on keeping the stock bumper for now? I should grab mine from the shop so we can chop it up [at least the front black part] so yours remains intact, if you are so inclined.
    ajmogen[QUOTED][OP] likes this.
  16. Sep 8, 2018 at 9:35 AM
    ajmogen
    Aaron
    Wisconsin
    Yea, I was all for chopping, but got a little gun shy. I might take you up on that offer
  17. Sep 8, 2018 at 9:36 AM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    For sure. I'll see if I can go pick it up sometime soon.
  18. Sep 9, 2018 at 5:02 PM
    ajmogen
    Aaron
    Wisconsin
    Finished welding winch mount
  19. Sep 9, 2018 at 5:05 PM
    ajmogen
    Aaron
    Wisconsin
    Added bracing to transmission skid and painted skids
  20. Sep 10, 2018 at 12:39 PM
    ajmogen
    Aaron
    Wisconsin
    Trimmed a little plastic off of the lower bumper to make room for the winch
