Alabama goes to toys for tots @windrock
Discussion in 'South East' started by tweakit88, Nov 16, 2018.
  1. Nov 26, 2018 at 1:28 PM
    #41
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Gotcha. That's the reason I'm sort of leaning towards CO2. Just gets colder the more you use it. And doesn't require power which is nice.
    stronghammer[QUOTED] likes this.
  2. Nov 26, 2018 at 1:32 PM
    #42
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Yeah but requires refilling which is annoying. I've always got power at the truck.
    tweakit88[OP] likes this.
  3. Nov 26, 2018 at 1:33 PM
    #43
    Jerneyman
    Wes
    Huntsville, AL
    There was that one time I lost power... Scarred me for life. Lol.
  4. Nov 26, 2018 at 1:59 PM
    #44
    tweakit88
    tweakit88 [OP] COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    I have a viar, Scotty has an arb, Jeff had an arb.
    stronghammer likes this.
  5. Nov 26, 2018 at 2:05 PM
    #45
    tweakit88
    Leroy IL
    Only the best.
    Damn i hate it when i answer a question that has already had a full conversation on it.
  6. Nov 26, 2018 at 2:34 PM
    #46
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Lol why do you not use the multi quote function and wait till you read everything to answer
  7. Nov 26, 2018 at 3:26 PM
    #47
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
  8. Nov 26, 2018 at 3:50 PM
    #48
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yes they have air, pressure washer and a store with a little bit of everything
  9. Nov 26, 2018 at 3:54 PM
    #49
    tweakit88
    Leroy IL
    Only the best.
  10. Nov 26, 2018 at 3:54 PM
    #50
    tweakit88
    Leroy IL
    Only the best.
    No clue how
  11. Nov 26, 2018 at 4:06 PM
    #51
    JBTacoma
    Jeff
    Cullman Alabama
    I have a C02 setup, I just need to get something to mount it in the bed. I keep telling myself that and I have had it almost a year.
    You can use air tools with it too
    https://www.youtube.com/watch?v=azuKtXF6f14
    My tank is suppose to be able to air up 40 33s in 30 seconds each, before refilling, tank has over 600 psi.
  12. Nov 26, 2018 at 4:11 PM
    #52
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Click multi quote. Then when you scroll down to the comment box there will be an option to "insert quotes" and it will put all quotes that you multi-quoted into it. Then at the end of each quote just type your response. I can show you in person if needed.
  13. Nov 26, 2018 at 4:19 PM
    #53
    tweakit88
    Leroy IL
    Only the best.
    Ill give it a shot next chance i get. By the way i just relized this will be the first time we have wheeled together since the first time i met you at stoney almost 2 years ago.
  14. Nov 26, 2018 at 4:20 PM
    #54
    tweakit88
    Leroy IL
    Only the best.
    Mount it while the trany is out
  15. Nov 26, 2018 at 4:20 PM
    #55
    JBTacoma
    Jeff
    Cullman Alabama
    Need to get a mount too
  16. Nov 26, 2018 at 4:21 PM
    #56
    tweakit88
    Leroy IL
    Only the best.
    Make one. You built a new engine mount bracket, how hard could it be :D:thumbsup:
  17. Nov 26, 2018 at 4:25 PM
    #57
    JBTacoma
    Jeff
    Cullman Alabama
    I think I may need to get something made to hold it, it has 600+ psi, It would become a rocket if it started bouncing around.
  18. Nov 26, 2018 at 4:29 PM
    #58
    tweakit88
    Leroy IL
    Only the best.
    Just send it Jeff :rofl::rofl::thumbsup:
  19. Nov 26, 2018 at 4:29 PM
    #59
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Haha very true!! Its been too long man.
  20. Nov 26, 2018 at 4:32 PM
    #60
    tweakit88
    Leroy IL
    Only the best.
    That it has. Should be a good time. Jeff is going to try and get me to run trail 21 or whatever it is lol. I would like to see it but i dont want to spend all day in it lol. Id like to see as much of the park as i can. Its a big place and i bet has a ton of cool trails.
