Alabama Off-road/ Mods/ Meets Thread
Discussion in 'South East' started by SuthrnTaco07, Apr 18, 2012.
  1. Mar 3, 2014 at 12:17 PM
    #4701
    whisk3ythrottle
    whisk3ythrottle Well-Known Member
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Front windows matched tint, weathertech front husky rear mats, K & N CAI, Borla cat-back exhaust, 265/70/17 Goodyear Wrangler Authorities, fog light anytime, 5100s up front set at 1.75" on stock coils,
    Not sure about the wheel spacer issue, but I would guess the 1.25 would be good. Then you may have to worry about the wheel grabbing the inner fender well when it is all the way into the wheel well. That depends on how much you offroad and how often your wheels will go that far into the wheel well.
    For the leveling kit, it depends on what kind of fabtech suspension set up you have. It sounds like you will just want to add a basic toytec spacer, not that I reccomend those, but those are the easiest unless you want to buy a new coilover set up. The only thing I would worry about is the UCAs if you haven't upgraded those yet with that much lift. If you do go with the spacer while running those 33s, then that will put a lot of stress on your stock suspension components. Just my .02. There will be some more experienced input coming from a lot of these guys.
  2. Mar 3, 2014 at 12:42 PM
    #4702
    BAMATACO12
    BAMATACO12 Well-Known Member
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    2.5' Fabtech Suspension lift. 285/75/16 Cooper STT's New headlights Surefire mount with Quick Fist Shrockworks bumper-3 wks out on delivery Light Force 240 Blitz arriving today
    Great! Thanks for the input. That will def get me started. Was hoping this would be a relatively easy fix....Well, easy on the billfold
  3. Mar 3, 2014 at 1:57 PM
    #4703
    Dwill817
    Dwill817 Well-Known Member
    Drew
    Alabama
    1981 Toyota Pickup 4x4
    Also it's $25 per truck to get in. It's an honor box system.
  4. Mar 3, 2014 at 5:27 PM
    #4704
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    Or a 1 inch body lift and wheel spacers, I can tell you now that regardless if you add wheel spacers they will still rub at full lock, just not as bad. Also doing this will cause some rubbing on the front bumper at the bottom, just trim that up some, and then hit the pinch weld with a hammer until flat. I did this before I put 35s on my 1st gen and it caused minor rub at full luck with little flex like pulling out of the driveway. Now with my 35 KM2s that are almost bald, they would technically be considered a 33 now because of how worn down they are, they rub at full lock but that is also a 11.5 inch tire with 1.5 inch wheel spacer.
  5. Mar 3, 2014 at 7:43 PM
    #4705
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    DONT ADD A SPACER ON TOP OF YOUR CURRENT LIFT! It will put unneeded stress on the frontend. The best thing you can do is get a different lift that will truly level out the truck, then get some UCA's. I might not be understanding you though. I know TacoFMS can shed some light on this subject.
    From my understanding, a spacer might not help the situation, you might need to get a different wheel with a different back spacing.
  6. Mar 3, 2014 at 11:43 PM
    #4706
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Ok... lifts 101. Unless you extend the bumpstops, put in UCA's and CV's that can handle the angles, you're not buying any less rub with more lift. Alex is correct that you need to clearance the wheel wells to get rid of rub. All the lift is doing is moving the tire out under a "normal" load. Any compression of the suspension is going to push the tire right back to where it will rub.
    There's a good reason that the most common lift on these trucks (1st and 2nd both) is 2-3" with 33's. Past that, you get into either non-trivial body work at least, or that PLUS lots of expensive drive line and susepnsion parts at most.
    I can also tell you, wheeling, if you lift the thing 3", you won't have much down travel, which, isn't exactly ideal.
    If you could reliably wheel 35's kinda hard on a Tacoma and fit them with not much lift, I think the ideal setup would be a 1.5" lift, and 35's. You'd get the same approach, breakover, and departure as a 2.5" lift on 33's, but with better suspension geometry and articulation and added axle clearance.
    I know Dave is running 35's, and I think there was some other kid in here who ran them over a year ago. There are issues though, potentially, if you get into the throttle too much.
  7. Mar 4, 2014 at 3:46 AM
    #4707
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    ^^ I have no complaints running 35's. But, I also had no problem stripping my wheel wells and taking a sledge hammer to them to make the tires fit. Also, my tires do rub the frame and full lock.
    I would avoid running 35's, if you plan to wheel, and don't want the hassle.
  8. Mar 4, 2014 at 8:22 AM
    #4708
    BAMATACO12
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    Thanks for the input guys. I'll have to admit, I'm a little more confused now. haha. I've only just begun to really learn about mods for my truck. I've always had a good idea what things were, but it became a whole new ballgame when I started adding them on. I would classify myself as a beginner with all of this.
    My lift is a Fabtech suspension lift. 2.5" (I realize I might get some shit for using them) and my tires are 33's. I suppose if I needed to run a better lift, I could, and sell the Fabtech. I guess I just need the best fix for rubbing my frame at full lock. I also rub the fender flare, but I can handle that no problem. I also wouldn't mind another 1-1.5" inch lift for what I have now. My Shrockworks bumper will be here in a couple weeks, I received my 240 Blitz over the weekend.
    I would like to start wheeling more often, but I'll most likely stick to the novice trails at first. (if there is such a thing)
    Thanks again guys- John the begginner.
  9. Mar 4, 2014 at 8:35 AM
    #4709
    Dwill817
    Drew
    Alabama
    Where you located John? I'm on my mobile so I can't see location.
  10. Mar 4, 2014 at 8:38 AM
    #4710
    BAMATACO12
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    I'm in Birmingham. Hoover area.
  11. Mar 4, 2014 at 8:48 AM
    #4711
    BamaToy1997
    Bill
    Navarre, FL
    No worries! If I can make it on the 29th, then I will let you know a couple of days ahead of time. At a minimum I will need to get the front gears installed.
    We all were noobs once with lifting the Tacoma. You will learn fast. Lots of good information from some experienced people here, that is for sure. All you gotta do is ask, like you have!
  12. Mar 4, 2014 at 11:14 AM
    #4712
    BAMATACO12
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    Thanks man! I def look forward to not being a noob! Definitely lucky to have y'all at TW for advice. I might be SOL if not. haha
  13. Mar 4, 2014 at 11:38 AM
    #4713
    xodeuce
    Alabama
    2004 UZJ100
    Someone with a first gen may have a better idea, but on a 2nd gen if that were the case, I'd say wheels with the correct offset, a hammer, and a grinder. Keep the 33's, and forget about more lift. That's going to be the quickest and most painless route. If you want more lift (>3") or bigger tires (35's), you're going to go down the rabbit hole a good bit further.
  14. Mar 5, 2014 at 5:19 AM
    #4714
    GATORTACO92
    Alex
    Hoover, Al
    i use to work at that NTB!!!!
  15. Mar 6, 2014 at 7:26 AM
    #4715
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Late reply but will let you know if they become available.
  16. Mar 6, 2014 at 2:50 PM
    #4716
    mac424205
    Mathew
    Chelsea
    Mounted and ready to go! :woot:
  17. Mar 6, 2014 at 2:59 PM
    #4717
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    :yay::yay:Glad to finally see them on!! No go beat em up! :D
  18. Mar 6, 2014 at 4:15 PM
    #4718
    mac424205
    Mathew
    Chelsea
    Gotta wait for time to do that! Lol
  19. Mar 7, 2014 at 8:38 AM
    #4719
    BamaToy1997
    Bill
    Navarre, FL
    Matt hard at work yesterday afternoon. My welder did a hell of a job!
  20. Mar 7, 2014 at 8:45 AM
    #4720
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    You are certified arent you Floor? thought I remembered you saying you were.
