Alabama Off-road/ Mods/ Meets Thread
Discussion in 'South East' started by SuthrnTaco07, Apr 18, 2012.
  1. Apr 10, 2014 at 2:30 PM
    #5001
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Mine was done by Toyota dealership although no one there had done one with the UCA's they were able to figure it out fairly easily (I did provide them the paperwork for my Icons). It rides great with no drift or abnormal tire wear. Could other shops do that? Depends, and before I had Toyota do them I checked with National Tire and Battery which has very well maintained shop and equipment. Manager said no one had done them there and kind of left me wondering as he was not very forthcoming and certainly didn't seem eager for the business. I would call and ask a few places to see if anyone has experience doing them and if they have someone who knows what they are doing go with them.
  2. Apr 10, 2014 at 2:45 PM
    #5002
    BamaToy1997
    Bill
    Navarre, FL
    It depends on the lift, and how well it is designed. When you lift a truck you throw off the normal tilt angles of the camber, and how much it can be adjusted. In SOME cases (not all of course) this makes matching the correct alignment numbers impossible to reach, because the lower control arm can't be brought to the correct placement. I know that when I was doing alignments at Sears we had a few trucks that just wouldn't get to spec, even when the cams were at their max. We would have to install aftermarket alignment cam stops and grind off the factory ones. Some lifts though are well designed, and the truck was in great shape before hand, making aligning it simple and easy.
    So what do you all think of my modified dash trim panels? I sent them to a guy on here to get a carbon-fibre hydrographics done. Got the switch panel, AC plate, radio trim, cupholder, and cluster trim all done.
    What ya think?
  3. Apr 10, 2014 at 4:36 PM
    #5003
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Your icon uca's are not adjustable, so in essence it is a standard alignment.
    With light racing uca's and I believe built rights as well it doesn't matter one bit on the lift. The uca's are adjustable in both caster and camber so if you can't get it into proper numbers off your tabs you have about 2 to 3 times the amount of adjustment still to play with in the UCA itself. Which is why some shops have difficulties in doing an alignment with them and everyone asks where to get it done. Because if the UCAS are off from the start then the tech has to not only work with the trucks angles but also the UCAS angles that they are introducing. The paperwork comes I to play because it has instructions on how to set the UCAS to zero. So you can try from the start to get desirable numbers out of solely the trucks alignment cams.
    Hopefully that makes sense to you on why the light racing ones can make an alignment a bit more difficult.
  4. Apr 10, 2014 at 5:24 PM
    #5004
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    Makes sense to me! That's a hard thing to do in words. I have to see something to know how to do it right. Maybe that's why I'm good in the..... :rolleyes: let's not get ahead of ourselves here
  5. Apr 10, 2014 at 8:24 PM
    #5005
    BamaToy1997
    Bill
    Navarre, FL
    I was fully aware of it. Hence my indicating that depending on the design of the lift, some are easy to adjust, and others more difficult. I wasn't calling out any specific brand of course, just lifts in general. Some don't have adjustable uppers, and those are mostly a pain to align.
  6. Apr 11, 2014 at 3:23 AM
    #5006
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Nice and clean
  7. Apr 11, 2014 at 9:52 AM
    #5007
    mac424205
    Mathew
    Chelsea
    Hey Jeff. Saw you Wednesday in Pelham. I was in Kerri's case.
  8. Apr 11, 2014 at 10:06 AM
    #5008
    mac424205
    Mathew
    Chelsea
    That's why we buy adjustable uca's. :smack:
  9. Apr 11, 2014 at 10:20 AM
    #5009
    BamaToy1997
    Bill
    Navarre, FL
    ok. maybe I am lost here then. I realize all of YOU buy adjustable UCAs, but not EVERYONE does.
  10. Apr 11, 2014 at 11:00 AM
    #5010
    mac424205
    Mathew
    Chelsea
    Well, we do! :D that's all that matters!
  11. Apr 12, 2014 at 5:59 AM
    #5011
    POOLGUY
    JEFF
    ALABAMA
    Must have been in the morning. How's the 4runner coming along? Saw the sliders, anything else?
  12. Apr 12, 2014 at 10:18 AM
    #5012
    mac424205
    Mathew
    Chelsea
    Nothing right now. Full skids are my next purchase.
  13. Apr 13, 2014 at 1:30 PM
    #5013
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    well...i just renewed my tag....on top of that i have to replace my windshield when i get back to:(
  14. Apr 13, 2014 at 6:31 PM
    #5014
    mac424205
    Mathew
    Chelsea
    Alex, pay for that out of pocket. It is cheaper, in the long run, than using your insurance. They will say it won't cost anything for you to do that but your rates will go up. I did that in the grey honda and my rates went up $60 a month.
  15. Apr 13, 2014 at 6:32 PM
    #5015
    mac424205
    Mathew
    Chelsea
    Actually, I ordered two sets of pod led lights for the front.
  16. Apr 14, 2014 at 12:57 PM
    #5016
    GATORTACO92
    Alex
    Hoover, Al
    Makes sense but 400 dollars is something I don't have right now..... I won't have it till I come down in June. I'm going to look for quotes when I get back back home. I know a guy in another squadron that works at a body and mechanical shop as well.
  17. Apr 14, 2014 at 3:44 PM
    #5017
    mac424205
    Mathew
    Chelsea
    Does it have to be replaced? If it's a chip, can it not be filled? I'm just curious. It might have a crack all the way across the windshield. Idk. Lol
  18. Apr 14, 2014 at 3:52 PM
    #5018
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    [​IMG] homemade lift mod. Coil springs and such 2.5" of rear lift before anything settles.[​IMG] free too, nothin but time and a few 7018 rods and leftover rattle can black.
  19. Apr 14, 2014 at 4:44 PM
    #5019
    GATORTACO92
    Alex
    Hoover, Al
    Ya it has to be replaced. It spread from the center center to the driver side edge in 2 days.... I don't think that lift is exactly..... Safe is it?
  20. Apr 14, 2014 at 4:51 PM
    #5020
    yota243
    E.J.
    north Alabama
    The weakest point is the stock u bolt. Ive actually been running one with no lift as a test for 6 months or so and it didnt move
