Alabama Off-road/ Mods/ Meets Thread
Discussion in 'South East' started by SuthrnTaco07, Apr 18, 2012.
  1. Jun 19, 2012 at 11:36 AM
    #641
    MTNative
    MTNative Well-Known Member
    Looks like this may become my next best place to hang out for a weekend. :D
  2. Jun 19, 2012 at 12:01 PM
    #642
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yea that would be nice to look at
  3. Jun 20, 2012 at 10:53 AM
    #643
    MTNative
    May be going to Wooly's this Saturday. Anyone interested?
  4. Jun 20, 2012 at 11:44 AM
    #644
    BamaToy1997
    Bill
    Navarre, FL
  5. Jun 20, 2012 at 2:11 PM
    #645
    SuthrnTaco07
    SuthrnTaco07 [OP] Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
  6. Jun 20, 2012 at 9:42 PM
    #646
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    I am sure photos will be up after the Grand Opening.
  7. Jun 21, 2012 at 9:05 PM
    #647
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    DUH:smack::smack:
  8. Jun 22, 2012 at 3:20 PM
    #648
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Alright.. Anyone else!? What about you Josh(conrad)? It's kinda out your way.. Still closer for us but you have a winch.. I'll be Jeepin it real along with Paul but it would be great to see a couple Taco's out there!
    BTW.. Paul.. Sometime soon I want to put my suspension on my Jeep to see if it helps the ride any.. I also might try to retro fit an old shock for the front steering dampener..
  9. Jun 23, 2012 at 8:39 AM
    #649
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    Thats fine. Getting that front pinion nut off is still a priority. I think I need to go ahead and buy a new pinion nut. If its that hard to get off, it probably wouldn't be safe to put it back on anyways. I'll probably run into town today and get a new zerk and pinion nut.
    BTW, I wouldn't put a shock in as a stabilizer because:
    1) Different mounting methods
    2) Shocks are going to be more shot than the stabilizer
    3) Different length
    4) shocks will have a different damping rate than a stabilizer would
  10. Jun 25, 2012 at 6:10 AM
    #650
    BamaToy1997
    Bill
    Navarre, FL
    Well yeah, I am sure they will have them then. My point was that going for the actual grand opening is not something I want to try. Not to mention that a grand opening weekend, that place will probably be PACKED. Lots of trucks on a trial = lots more chance of some idiot doing something he shouldn't and hitting another truck. It has happened plenty.
    What is the problem you are having with the pinion nut? The nut is a low-tolerance clearance nut, so it will be tight going on and off the entire way for the most part. May I ask what you are pulling off the pinion nut for? I ask because there is a crush sleeve that is pretty much a one-time-use, though there are some limits. Also you have to be careful about retightening. Too loose and the gears can wobble at speed, but too tight and you thrash on the bearing races and bearings.
  11. Jun 25, 2012 at 6:22 AM
    #651
    FlawedXJ
    Paul
    NorAla
    It won't come off haha. I don't plan on reusing it once I remove it. I'm removing it because I have a bad pinion seal. I know the threads are supposed to deform the nut for safety, got a new one waiting to go on. The D30 in the XJ's use shims, not crush sleeves so I don't think I'll run into problems. As far as I can tell the new nut is the same as the old one so I'm going to torque it to factory specs and then compare the thread count. Is there anything else I might be looking over?
  12. Jun 25, 2012 at 10:29 AM
    #652
    FlawedXJ
    Paul
    NorAla
    hollytree offroad has added a bunch of pictures to their site.
  13. Jun 25, 2012 at 10:45 AM
    #653
    BamaToy1997
    Bill
    Navarre, FL
    What year is your XJ? I had a '99. Some models come with a crush sleeve for the front pinion, it depended on the manufacture. I will look up specs for you once I know the year.
  14. Jun 25, 2012 at 12:00 PM
    #654
    FlawedXJ
    Paul
    NorAla
  15. Jun 25, 2012 at 12:19 PM
    #655
    BamaToy1997
    Bill
    Navarre, FL
    Ahhh. Same as mine. I loved my '99! OK, that year used a selective shim. You shouldn't have anything to worry about on that one. It shows in my manuals that your torque on the nut should be between 220 and 350 lbft. Not sure why it is not a specific torque. I would suggest around 260?
  16. Jun 25, 2012 at 12:30 PM
    #656
    FlawedXJ
    Paul
    NorAla
    guess i'll be renting a torque wrench since mine only goes to 150. no wonder I can't get that thing off.
  17. Jun 25, 2012 at 12:49 PM
    #657
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    need a good impact to spin it off wink wink.
  18. Jun 25, 2012 at 1:28 PM
    #658
    FlawedXJ
    Paul
    NorAla
    well, I don't know anyone around here with a good air impact wrench
  19. Jun 25, 2012 at 1:53 PM
    #659
    TacoFMS
    Justin
    Louisa County, VA
    you got a good compressor? ive got a good impact for sale.
  20. Jun 25, 2012 at 6:52 PM
    #660
    FlawedXJ
    Paul
    NorAla
    Haha nope. To actually run an impact wrench well, you are looking at a pretty damn expensive compressor. Im gonna ask the guy who bought my truck if I can stop by and use his shop for about 20 minutes. Im sure he wouldn't mind
