Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jan 19, 2017 at 8:37 AM
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    if something happens to your truck would you buy another tacoma? if the answer is yes then bolt on
  2. Jan 19, 2017 at 8:38 AM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    Could you elaborate a little bit on that? Was kind of deliberating between bolt-on and weld-on myself.
  3. Jan 19, 2017 at 8:43 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    he means if you total your truck but the sliders survive would you get another tacoma? because then you'd be able to just unbolt and re use those.
  4. Jan 19, 2017 at 8:46 AM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    exactly what i meant
  5. Jan 19, 2017 at 8:47 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I personally would probably go 4runner, plus I just like the added strength of weld on.
  6. Jan 19, 2017 at 8:48 AM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    I see. Shit, $500 sliders on a totaled truck ain't worth it to use bolt ons huh? Most of the time you can reason with the insurance folks to take all the aftermarket stuff off right? Just take a cutting wheel or a torch out there...
    yota243 likes this.
  7. Jan 19, 2017 at 8:50 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    that's kinda my thought, to be able to cut them off if you want them...but I don't really know and hope I never come into that situation.
  8. Jan 19, 2017 at 8:53 AM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    but if you have them as bolt ons then they are much easier to remove and re install
  9. Jan 19, 2017 at 8:55 AM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    True. I'm curious as to the structural integrity of the bolted connection for bolt on sliders. I mean a 3/4" heat treated bolt is a tough sum bitch. So is the only advantage to welding the price difference?
  10. Jan 19, 2017 at 8:59 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    and weight and if you have access to a welder
    h.zack801[QUOTED] likes this.
  11. Jan 19, 2017 at 9:48 AM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    Sounds good! Tuesday or Wednesday work best for me as one person in my department is off on Monday.
    TheTacoma[QUOTED] likes this.
  12. Jan 19, 2017 at 10:08 AM
    O906
    O906 Well-Known Member
    Or just stop hording the entire state up there! I say we meet up down south and make a weekend out of it! We could all camp on DI.
  13. Jan 19, 2017 at 10:48 AM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I bought bolt on sliders because if you have a frame problem (rust) then toyota will not replace the frame of you've welded anything to it.
    h.zack801 likes this.
  14. Jan 19, 2017 at 11:23 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Winch!!! Thanks Oliver for the recommendation on this one. Can't wait to get it mounted up.
  15. Jan 19, 2017 at 11:26 AM
    Otis1382
    Otis1382 Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    Bolt on @Mobtown Offroad !:thumbsup:. Took a little longer than expected but great looking! Powder coated at pablo's in trussville for about 120 I think. Good work on both of them
    Mobtown Offroad and dcoursler like this.
  16. Jan 19, 2017 at 12:26 PM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    There generally is not a drastic price difference. I Have bolt on and have lifted the truck with them, drug my truck across them. I have installed weld on sliders as well i prefer bolt on for a number of reasons as dave said that if there is ever a frame recall or any issue that is due to a manufacturer defect then i want bolt on. There is not structural difference the structural side of it is does it have a plate that wraps all the way around the frame a "U" shaped bracket or is it just tubing welded to the frame? The only thing that i will weld to my frame possibly i say possibly because it may never happen is a between the frame rail shock mount to run extended shocks at a better angle! Bottom line its your money not mine and your truck not mine so do what you want. But coming from a guy who owns a tacoma that is my DD accidents happen shit happens you cannot forsee the future but make a good investment that way if you had to remove it all you could do so easily not a torch and a damn cutoff wheel then have to refurb your sliders to make them work on another vehicle.
    Davtopgun[OP] likes this.
  17. Jan 19, 2017 at 1:08 PM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
  18. Jan 19, 2017 at 1:23 PM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    :burnrubber:
  19. Jan 19, 2017 at 1:33 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    nice signature...
    rmepilot likes this.
  20. Jan 19, 2017 at 1:35 PM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    Thanks man, some weird smurf-fetish MF'er posted that earlier today
    stronghammer[QUOTED] likes this.
