Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Apr 29, 2017 at 5:33 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Excellent choice. Perfect for your truck.
  2. Apr 29, 2017 at 5:50 AM
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Oh Snap. I like that look.
    Thunder Fist[QUOTED] likes this.
  3. Apr 29, 2017 at 6:23 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    It completely changed the look of the truck.
    LadyRed[QUOTED] likes this.
  4. Apr 29, 2017 at 6:50 AM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    Cb wired up and finished, ditch lights are finally wired up and working (5 months later), and rewired 3rd brake light to camper shell.
    to do list:
    reinstall prinsu
    paint sliders/install
    clamshell bushing
    tires balance/alignment
    Truck will then be completely ready for Moab.
  5. Apr 29, 2017 at 11:23 AM
    pottsie
    pottsie Well-Known Member
    Dale
    Huntsville, Al
    2009 Green Tacoma TRD Access Cab
    My truck just started getting a bad vibration between 30-40 and if I let off the gas it stop. Any ideas???
    TacoLean likes this.
  6. Apr 29, 2017 at 12:24 PM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    everywhere I go..
    h.zack801 likes this.
  7. Apr 29, 2017 at 12:34 PM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Where do you feel the vibration from?
  8. Apr 29, 2017 at 1:02 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Sounds like it
  9. Apr 29, 2017 at 1:34 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    How much weight have y'all had in your bed. Just hauled 1 cubic yard of soil and it was bottomed out.
  10. Apr 29, 2017 at 1:35 PM
    Davtopgun
    David
    Central Alabama
    The stock rear springs suck hard.
  11. Apr 29, 2017 at 1:36 PM
    BamaTaco56
    Trey
    All the more reason to justify a lift I reckon.
  12. Apr 29, 2017 at 2:04 PM
    kuhndawg
    kuhndawg Well-Known Member
    Bob
    Alabama
    2017 Tacoma TRD Off Road
    Missed out on the ride today but instead I did almost the next best thing
    The hulk, gunney and guns
  13. Apr 29, 2017 at 3:28 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    So I started hearing a creaking sound from the right front. Today I discovered that the lower control arm bushings need to be replaced. I figure I need to replace both sides when I do it. Also, need to replace the coils and shocks all the way around. I'm hoping you guys can give me some good advice on what type of bushings I need to use? What coils and shocks?
    I currently have the rear spring recall done, helper springs and timbienes on the rear. Also, running rancho quick lift rs9000 shocks front and rear. They have been good for me and what I have used my truck for. I use my truck for work and carry 400-450 lbs. in the bed regularly and as much as 700-800 lbs. at times. So reliablity and durablilty are important to me. I have over 250,000 miles on most of the suspension.
    Thank you guys for your help.
  14. Apr 29, 2017 at 3:31 PM
    POOLGUY
    JEFF
    ALABAMA
    I've had as much as 900 lbs. in the bed and pulling 1100 lbs. on a trailer at the same time.
  15. Apr 29, 2017 at 3:38 PM
    Davtopgun
    David
    Central Alabama
    I don't know much about the bushings as I haven't done mine yet. I would look into OEM or possibly poly bushings are available if you can find a company that makes them. I need to do that too.
    As for shocks and coils, if you're at stock height, I would find someone who lifted their truck and buy the stock suspension for cheap off of them.
  16. Apr 29, 2017 at 3:45 PM
    POOLGUY
    JEFF
    ALABAMA
    Thanks Dave! I think Crom might have gotten some poly ones. I'll check his thread.
    Davtopgun[QUOTED][OP] likes this.
  17. Apr 29, 2017 at 3:46 PM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
  18. Apr 29, 2017 at 3:51 PM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
  19. Apr 29, 2017 at 4:02 PM
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    I let You ride too brooooooo
  20. Apr 29, 2017 at 4:03 PM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    You did. It was like I was being whored around out there. lol
