Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 20, 2017 at 9:04 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    I thought it was low speed, maybe I'm wrong who knows. It does what I need
  2. May 20, 2017 at 9:09 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Most of the places on my trip list are out west and in Michigan(most of the trails are whooped sand 2 tracts)
    Edit: and alaska
  3. May 20, 2017 at 9:14 PM
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    Nah another reason I didn't go icon. Ads was the only shock with both digressive and progressive dampening. Progressive on the compression and digressive on the rebound.
    rmepilot likes this.
  4. May 20, 2017 at 9:14 PM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    Dude I would love to go to Alaska.
  5. May 20, 2017 at 9:15 PM
    chrisrocks300
    Brandon, MS
    Go by skagway if you do, jaw dropping
  6. May 20, 2017 at 9:17 PM
    tweakit88
    Leroy IL
    Only the best.
    Once the utah trip is done in 2 years the alaska planning starts. Hoping in 5 -7 years from now. A full month of awesome
    Otis1382 and Sandytaco14[QUOTED] like this.
  7. May 20, 2017 at 9:26 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Aren't most shocks valve the opposite for the rebound?
  8. May 20, 2017 at 9:28 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Such as this basic illustration. It's been far too long since I researched suspension for dirt bikes. Lol
  9. May 20, 2017 at 9:34 PM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    What marie sent to Warren and what Warren sent to me, which I in turn asked her about to confirm.
    I find it helpful to provide a general comparison of the various coilovers so you can compare them side-by-side.
    The Kings come standard as a standard travel (they can be built at extended travel) and a reservoir and have optional compression adjustors. The come built with a 600 lb spring rate but can be built with a higher spring rate per your specifications. They have steel body and aluminum components. They have a progressive valving. They come preset to provide around 2.5" of lift on the 05-15's and around 1.5" on the 2016+ models. They can be adjusted to provide more or less lift depending on what suits your needs.
    Icon have stock coilovers that can be built with extended (requiring ucas) or standard travel with and without reservoir and compression adjustors. They come standard with a 650lb spring rate but can be upgraded to a 700lb spring for an additional fee. They have steel body and aluminum components. They have a digressive valving which some feel can provide a stiffer on-road ride quality, depending on terrain and speed. They come preset to provide around 2.5" of lift on the 05-15's and around 1.5" on the 2016+ models. They can be adjusted to provide more or less lift depending on what suits your needs.
    The Fox's have stock coilovers in standard travel or extended travel (requiring uca's) and they come with or without reservoirs and compression adjustors. They come standard with a 600lb spring rate. If you wanted a higher spring rate they would have to be sourced separately. They have steel body and aluminum components. They have a progressive valving which some feel can provide a plusher on-road ride quality, depending on terrain and speed. They come preset to provide around 2" of lift on the 05-15's and around 1" on the 2016+ models. They can be adjusted to provide more or less lift depending on what suits your needs however due to their design it is required to make the adjustments off of the vehicle and utilize a spring compressor to take the tension off of the collar.
    ADS utilizes similar components in their OE lines as they do their race lines so that is a nice benefit. ADS comes standard as a standard travel (they can be built at extended travel) and a reservoir and have optional compression adjustors. The come built with a 650 lb spring rate but can be built with a 700lb spring rate at no extra charge. They have steel body and aluminum components. Their OEM bolt in Tacoma coil-overs are digressively valved on the rebound side and run progressive valving on the compression. The main reason for this is to give you the stable ride for on road and less of the harshness when traveling off-road. They come preset to provide around 2.5" of lift on the 05-15's and around 1.5" on the 2016+ models. They can be adjusted to provide more or less lift depending on what suits your needs.
    Progressive vs Digressive:
    Progressive dampening progressively gets more firm as the shock shaft Velocity increases. Digressive shocks have more firm dampening at lower shaft velocity, and softer dampening at higher shaft speeds.
    Progressive rate CO's ride much softer on the street, and off road at speeds below 20 mph (depending on terrain), while the Digressive CO's give a more firm ride on the street, and at speeds below 20 mpg off road (once again, depending on terrain). Off road at speeds over 25 mph, the digressive shocks are great. You can re valve the digressive shocks to be a little softer in the "low speed" dampening, which gives a better on road ride, and still maintains the high speed dampening characteristics.
  10. May 20, 2017 at 9:36 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Images like this is also why when guys like us talk progressive and regressive dampening we really do not know what we are talking about or what all goes into valving and just going on from "what we read on the internet" all your aftermarket shock companies are great at what they do and no matter what flavor you choose it will do something better than the other guy and vice versa. It is impossible to have valving set up perfectly for every situation.
    In dirt bikes people take their time with papers for notes, oil amounts and weights, as well as nitrogen charge all while having a table of assorted shims.
    It's a pita why I pay factory connection who does free revalves till you hit the sweet spot for your terrain, style, and ability.
    Google suspension bible.
  11. May 20, 2017 at 9:38 PM
    chrisrocks300
    Brandon, MS
    Stop with your physics
  12. May 20, 2017 at 9:39 PM
    tweakit88
    Leroy IL
    Only the best.
    :eek:. Thats alot of good info right there.
  13. May 20, 2017 at 9:40 PM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    I don't claim whatsoever to be a suspension engineer. Nor to understand the physics to a point to validate my brand over another. I simply know ads put a lot of time into making the on road ride quality amazing, with great off road capabilites.
    Otis1382 and rmepilot like this.
  14. May 20, 2017 at 9:40 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    We need a side shot of all shocks cut open and you'd be surprised how similar most are.
  15. May 20, 2017 at 9:41 PM
    chrisrocks300
    Brandon, MS
    You first haha
  16. May 20, 2017 at 9:42 PM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    I think I just got a brain boner.
  17. May 20, 2017 at 9:43 PM
    h.zack801
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    Could probably get some from a distributor on ones that came back from warranty or something if you tell them you're going to cut them up for a science project or something.
  18. May 20, 2017 at 9:43 PM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    Just like most supercars/HyperCars. The higher level of performance you go, the less differentiation there can be.
  19. May 20, 2017 at 9:44 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    See if headstrong sent you that then they're pushing ads, probably bigger profits though just speculation.
    "Ads uses similar components in oe shocks as race shocks" blah blah.
    Taken straight from king
    Built with the same quality of materials and precise tolerances found on our high end race shocks our OEM upgrade kits enable you to experience the famous King ride quality on your daily driver or prerunner.
    Built with race winning design features our kits come complete
    nagorb likes this.
  20. May 20, 2017 at 9:45 PM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    I know I was thankful @Otis1382 sent it to me. I was going ads because of the group buy truthfully. This just reaffirmed, and made my decision even more validated.
    Otis1382 likes this.
