Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jun 23, 2017 at 1:41 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Are you stacked on the power to your radio? If so, try disconnecting the other things that are connected.
    Is the ditch light bracket connected to the hood? If not, how does it tie to the truck? That will determine if you need the ground wire.
    On the mount side, you have the plastic washer the same as I do, so you should be good for isolating the ground on the mount. The bracket for the ditch light and the bracket for you antennae are both non painted and the bolt should be good for both. The bolt itself may not be getting a solid enough ground, so might check the underside of the bracket where the nut is and expose a little bare metal there. I'd pull the spring off while your at it just to take one more thing out of the equation.
  2. Jun 23, 2017 at 2:46 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    what's cps, I don't get on here much anymore since the new job. lol
    I could, since I'm on pc most of the day, just don't think about it much.
    ChadsPride likes this.
  3. Jun 23, 2017 at 2:47 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Crankshaft position sensor. New recall, had been wondering why you haven't been on lol
  4. Jun 23, 2017 at 2:59 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    shoot, let the thing detonate.. idc, what's the verdict or been happening to make them recall. catch me up lol
  5. Jun 23, 2017 at 3:30 PM
    chrisrocks300
    Brandon, MS
    I wouldn't ignore it, I'm taking mine in mid-july to get it checked out b/c I'm in the recall. It's mainly the Mexico trucks. Engines have been stalling when accelerating onto interstates and people have almost gotten hit
  6. Jun 23, 2017 at 3:47 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Thanks! I ended up just taking it to a CB shop because I wanted to get it "peaked and tuned" anyway. My problem was it was shorting out on the mount because I drilled a 3/8" hole which wasn't big enough for the lip on the plastic washer to fit inside. Oops. The SWR meter on the radio itself is pretty worthless. It still shows 2.3 on 40, under 1 on 1 and flips back and forth between those readings on 32. But his SWR meter was showing 1.3 on 1 and 1.5 on 40. He couldn't get it any better by messing with the screw on the antenna but said that was good to go.
    On the way home there was a high speed chase with about 8 cops and a bunch of accidents so I tested it out with the truckers and it seems good.
  7. Jun 23, 2017 at 3:49 PM
    chrisrocks300
    Brandon, MS
    High speed chase in the middle of tropical storm Cindy? How is that possible? The traffic on 280 was so bad today it took me an hour to go 4 miles
  8. Jun 23, 2017 at 3:53 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    I don't know I didn't see it I just saw all the cops flying northbound on 65. But from what the drivers were saying it flipped around exit 284
  9. Jun 23, 2017 at 3:55 PM
    chrisrocks300
    Brandon, MS
    That's crazy man, what cb shop did you go to? I might get them to see what they can do about getting my swr down
  10. Jun 23, 2017 at 3:59 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's just called CB shop. It's on the stony exit, next to the big truck stop. $18 to peak and tune. He said mine is putting out about 19 watts now. They check SWR for free and charged me $10 to drill out the mount and put a new washer on.
  11. Jun 23, 2017 at 4:00 PM
    chrisrocks300
    Brandon, MS
    The stony exit is pretty far..
  12. Jun 23, 2017 at 4:02 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    Yep exit 299. Would be better to stop by when you are up there for some reason. But the shop itself is good. There's one in pell city but it's mainly a trailer dealer, not sure of they peak and tune or whatnot but it might be worth giving them a call for something closer.
    chrisrocks300[QUOTED] likes this.
  13. Jun 23, 2017 at 4:29 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Final adventure of the trip...
    IMG_2974.jpg IMG_2976.jpg IMG_2977.jpg IMG_2983.jpg IMG_2985.jpg IMG_2987.jpg IMG_2989.jpg IMG_2981.jpg IMG_2979.jpg
    :eek:
  14. Jun 23, 2017 at 4:39 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Are u in nola? My sister is down there and just send me this and said it should be my next mod
  15. Jun 23, 2017 at 4:39 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    That place looks awesome
  16. Jun 23, 2017 at 4:54 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Diff breather done, @stronghammer youll be pleased to know that i no longer have mudflaps on the truck. All packed up, all things bought and ready. Expedition starts at 5 am in the morning. We will be pushing to hit the Mackinac Bridge by night fall. Then cross into the upper peninsula on sunday morning. I will put up pics and trip reports as i can for yall. Most of that stuff will be on instagram phoenixoverland is my instagram handle if yall want better pics and videos. Our first family expedition and im sure u can tell im stocked. :D:bananadance::bananadance:
  17. Jun 23, 2017 at 4:55 PM
    chrisrocks300
    Brandon, MS
    Where'd you run your breather to?
  18. Jun 23, 2017 at 4:55 PM
    tweakit88
    Leroy IL
    Only the best.
    Bed storage box.
    TheTacoma likes this.
  19. Jun 23, 2017 at 4:55 PM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    Bring me that pentagram donut brother!
  20. Jun 23, 2017 at 4:56 PM
    chrisrocks300
    Brandon, MS
    Good choice
