Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 22, 2017 at 7:21 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    The advantage of Roth is tax free growth for retirement. All others are taxed when you remove during retirement based on a tax rate that is more than likely going to be much greater then than what it is now.
    Example - $100,000 in retirement account might be taxed at 25% now but when you retire it could be 35% and you get $65,000 of your $100,000.
  2. Dec 22, 2017 at 7:22 AM
    baldridge
    Bart
    Auburn, AL
    Roth IRA - individual retirement account. Think it’s just a different way of saying it.
  3. Dec 22, 2017 at 7:24 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    so at the point I'm at ----> employee match 6% and I contribute 7% to my 401k
    your suggestion is open a Roth? is that what Jeff was saying too?
    rmepilot likes this.
  4. Dec 22, 2017 at 7:27 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    well I think the point that jeff is making is the more pretax dollars come out of your check the less taxable amount of moneys you have. so say you make 40k a year but you have 10% going into a 401 and we will say another 10% for insurance and such that comes out pretax. instead of you being taxed 18% on 40k you may get yourself into a lower percentage tax bracket so 16% so now instead of paying 7200 in taxes you would pay 5120...
    it would be more accurate to say, since you are already putting 7% in and insurance wouldn't change that you may be in the 18% bracket but have 33200 worth of taxable income and that would be about 6k in taxes. my take away would be, if you can afford to up your pretax deductions enough to get you in a lower percentage tax bracket it is a win/win (less taxes now and when you retire), and if you can't it's a win/lose (less taxes when you retire and more now)
    stronghammer[QUOTED] likes this.
  5. Dec 22, 2017 at 7:28 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    The proper name is "Roth IRA". It functions as a personal 401K (more or less) but is not labeled "401K".
    If you have the spare cash, it is good to put as much as allowed into each fund. Otherwise, do what you comfortably can. Personally, I put a priority on the 401K - max that one first. Any extra, dump in the IRA.
    Remember - this is long-term savings. Don't look at the total every week - only check it annually. Be patient, live your life, and before you know it, aside from being old, you will have a nice nest egg saved up.
    rmepilot and stronghammer like this.
  6. Dec 22, 2017 at 7:29 AM
    baldridge
    Bart
    Auburn, AL
    Not sure what he was saying but, if all you have is a 401k I would diversify some. Find you a solid financial advisor and let them help you put together a plan. I found it was worth the yearly fee they charge. I currently have a Roth IRA, Traditional IRA and 401k. I just retired from my first 20 years of work so I will more than likely roll 401k into Traditional IRA to have in one spot.
  7. Dec 22, 2017 at 7:30 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    right, I can't put in enough to get to a lower tax bracket. so go towards a Roth at this point?
    at what point, though, is it waiting too long to start the Roth? I understand 401k is pre tax and that's the best option, but what is the "cutoff" per say that the advantage is to one or the other?
  8. Dec 22, 2017 at 7:32 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Those that did the ECGS bushing. Did you replace the seal when you installed the bushing? Or does it only need to be done if the axle is leaking?
  9. Dec 22, 2017 at 7:32 AM
    baldridge
    Bart
    Auburn, AL
    I agree that it helps now. The money you put into the 401k will be taxed at a rate that will not be determined until you get ready to retire which my bet would be much greater than now. Might actually cost you more if it is all in one spot.
    stronghammer likes this.
  10. Dec 22, 2017 at 7:33 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    what seal, the crush washer?
  11. Dec 22, 2017 at 7:35 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    401k invested now means less tax now so actually you are investing that tax money and getting interest on it until you retire and then it is taxed. Both are good to invest in,
  12. Dec 22, 2017 at 7:36 AM
    yota243
    E.J.
    north Alabama
    yes I would say if you were not on the bubble of a tax bracket if would behoove you to diversify your investment. I have also been told by many, to save until it hurts, and then save just a little more.
    I have a mutual fund that is the accumulation of my previous jobs' 401ks and also my wife's, but apparently they no longer do those or something and if I want to invest anymore independently I must start a new account to due so (the mutual fund is grandfathered in but there has been legislation now that, from my understanding, does not allow for those kinds of investments anymore something something something) I plan on rolling that into whatever I have too (assuming some sort of ira) and then taking what ever my annual raise is this year and putting maybe have of that direct deposit to that account. I'm also at 7% on my 401k and I may up that because I feel like I may be on the bubble but ill just have to play that by ear I guess haha
  13. Dec 22, 2017 at 7:39 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yeah I am currently waiting for 2 things to happen.
    1. my first paycheck after the bill is signed will show my tax change.
    2. mid January we have potential raises that will affect my paycheck, and I want to see how that is affected.
    these 2 things will decide how much I can put back compared to what I am now. the 7% I am doing is basically what I am comfortable at this point, so whatever my take home amount changes to be I plan to take that "extra" and put it elsewhere since I am comfortable now.
    baldridge likes this.
  14. Dec 22, 2017 at 7:40 AM
    baldridge
    Bart
    Auburn, AL
    Let’s all just say more than likely we will all be passing each other during our replacement shift as Wal-Mart greeters! LOL!
    stronghammer and yota243 like this.
  15. Dec 22, 2017 at 7:41 AM
    Scott B.
    Scott
    Georgia
    It is never too long to wait - start one when you have some cash. And if you don't have extra cash one year (say you buy a house) don't add anything. Your money is still there, earning interest. Add more when you can.
    The only hard and fast rule is to save when you can. And, starting early helps to earning a larger sum later in life.
  16. Dec 22, 2017 at 7:42 AM
    yota243
    E.J.
    north Alabama
    if all else fails, I know a place that offers 3 hots and a cot, plus a free gym and cable tv
    BarberRider, T4golfR and stronghammer like this.
  17. Dec 22, 2017 at 7:42 AM
    yota243
    E.J.
    north Alabama
    hey would could just build a time machine and go back like 5 years and invest it bitcoin
  18. Dec 22, 2017 at 7:45 AM
    yota243
    E.J.
    north Alabama
  19. Dec 22, 2017 at 7:59 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Financial talk is soooooo much better than “ohhh, I’m sooooo butthurt over a girl I met 2 months ago...” :boink: LC
    In other news, I just picked up a 7lb Rib Roast for Christmas dinner. :yay:
  20. Dec 22, 2017 at 8:03 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    lol I enjoy financial talk. I enjoy a good discussion period, but a lot of it isn't allowed on here.
    I texted dad about this stuff and wanting to discuss it when we got together for christmas and he got almost giddy with excitement. he and I are a lot alike..
