Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jul 13, 2018 at 5:41 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    X2
    I need to tune mine
  2. Jul 13, 2018 at 5:48 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    8 more hours boys and in through with this week
  3. Jul 13, 2018 at 5:52 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Your effective antenna length is only the part of the antenna that is above the roof line.
    Any metal next to the antenna will absorb signal, effectively shortening the antenna.
    BamaTaco56[QUOTED] likes this.
  4. Jul 13, 2018 at 6:03 AM
    BamaTaco56
    Trey
    I originally got a 2" so I could leave it on the truck and have it fit in and out of the garage. Then had plans to get a 4 foot one for trail use. However, the 2" performed pretty well on the trail in a group of 10ish trucks so i think ill leave it for now.
    Eventually, I will mount a 4 foot antenna on my bed stiffener. Decided I don't want one that big on the hood hinge where my antenna is currently mounted.
  5. Jul 13, 2018 at 6:06 AM
    medic2230
    Murph
    Bama! Roll Tide
    They did mine a few months ago. $275 to dig and pump. Then we found out the bright asses that bought the house originally had planted two huge trees on top of the septic tank. I had already cut them both down but the stumps were still there. When they got the stumps out of the way and got it uncovered someone back then had drove over the tank and messed up the lids. So then they had to put extensions and new caps on both cleanouts. All in all for all that and removing 2 stumps it was $575. Feel like that was a pretty good deal overall.
    baldridge likes this.
  6. Jul 13, 2018 at 6:13 AM
    medic2230
    Murph
    Bama! Roll Tide
    That’s the tune part not the peak part. Unless with the 520’s you can’t peak them. They will put out more power than rated easily.
  7. Jul 13, 2018 at 6:15 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    275 digging how deep.. that's cheap. like i said mine was 3.5' deep
  8. Jul 13, 2018 at 6:17 AM
    medic2230
    Murph
    Bama! Roll Tide
    About 18”. They quoted it without seeing it. Base price was $250-275 to dig and clean out.
  9. Jul 13, 2018 at 6:23 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yeah if you use your CB on the road getting it peaked can help range but I only use mine off-roading so factory range is more than enough.
  10. Jul 13, 2018 at 7:29 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    anyone want an RCI skid plate? I can't remember who punctured a tank and wanted it.
  11. Jul 13, 2018 at 8:11 AM
    Scott B.
    Scott
    Georgia
    I get that. My Dad made a shorter whip for his roof-mounted K40 antenna, so it would fit in the garage. He just swapped it out for a longer one for our trips when he needed greater range. I always intended to do the same, but just use the 4' whip.
    Also, the more centered the antenna is on your truck, the more omni-directional your transmit/receive pattern will be. Since the truck is the ground plane, the mass of metal affects the signal - where more mass is, there is more signal. Mounting on the rear will send the majority of your signal forward. Yes, you can still communicate with people behind you, but you will get more distance going forward.
    whitedlite likes this.
  12. Jul 13, 2018 at 8:12 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Yeah I had my 33 peaked tuned years ago like 2004 at Dodge City exit 299 in cullman. LC had his done also recently and was happy iirc.
    medic2230[QUOTED] likes this.
  13. Jul 13, 2018 at 8:14 AM
    BamaTaco56
    Trey
  14. Jul 13, 2018 at 8:15 AM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    I got one that installs out of the way and has enough power. Link
    Scroll down the page a bit. Note that I screwed up and cut out too much of the lower console (clearly seen where the tape is under the CB).
    jmaack[QUOTED] likes this.
  15. Jul 13, 2018 at 8:23 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    If anyone would like a complete 2018 SEC football schedule magnet for their refrigerator PM me your address and I will get one mailed out to you. I’m mailing them out first thing Next week.
    jmaack and stronghammer like this.
  16. Jul 13, 2018 at 10:15 AM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    Been updating my CB today cause I’m tired of the magnetic antenna getting knocked off. I made a bracket and installed the 4’er I’ve had for months. I Still need a longer UHF cable. I can’t decide where to mount the radio. Not crazy about drilling mounting holes and splicing into a power wire. Keeping it in the console gives me power and it’s removable.82F2941D-A569-42A4-88DB-3F0EEF58CD09.jpg 4612331E-DF1D-412E-9F64-581590442D6B.jpg 1D5AAB83-A80C-4D9E-BC85-2511194D9653.jpg 8EFE1FC0-AD12-436C-9A46-5F6E097C44B7.jpg
  17. Jul 13, 2018 at 11:42 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    did you ever put the magnet antenna on your hood? I thought that would be ideal to not get knocked off.
    jmaack likes this.
  18. Jul 13, 2018 at 12:00 PM
    BamaTaco56
    Trey
    Jacksonville looking good right now
  19. Jul 13, 2018 at 12:05 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    Right in the middle of the hood seemed to be the best place but it still got knocked off a few times. It was annoying to have it in my line of sight too.
  20. Jul 13, 2018 at 12:40 PM
    baldridge
    Bart
    Auburn, AL
    A coworker told me my truck reminded her of the Back to the Future truck and that she liked it. :D
