Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 28, 2018 at 9:27 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Nope, that was a capacitor from the compressor fan on my AC unit, paid 20$ to a site and the guy walked me through finding the problem, removing and replacing the capacitor. Worst part was when he told me I had to short that big mofo before I disconnected it. That took a few minutes of prayer and nut growing before I did. Biggest part of it was it was dead, so it didn’t do a damn thing, but you never know until you short it!
    rmepilot and medic2230[QUOTED] like this.
  2. Aug 28, 2018 at 9:28 PM
    coke can
    coke can Well-Known Member
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    You got the longer one I linked, or the short one? I'm still kind of nervous about mounting a magnet on my roof in case a branch catches it and drags it down the roof and ruins the paint or something...
    If you settle on a good spot that can work with a small plastic piece, lmk and I can print it fairly cheap. Just need the dimensions and I can model it up and print no problem.
  3. Aug 28, 2018 at 9:31 PM
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Yep, I have the f8hp as well.
    You have a link to that mount for the antenna? I'm kind of leaning toward the hood mount option over roof too, just so I don't have to worry about it getting swiped by a tree. I don't think the lost range will be missed that much.
    Edit: oh, maybe I'll use this. Should be able to run the cable through a rear cabin air vent or something, right?
    https://www.relentlessfabrication.com/collections/toyota/products/05-tacoma-bed-rail-mount-tab
    baldridge likes this.
  4. Aug 28, 2018 at 9:35 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    https://www.relentlessfabrication.com/collections/toyota/products/05-tacoma-hood-hinge-cb-aux-mount
    I couldn't figure out which side I wanted, so I bought both sides powder coated. There is a code for $10 off $50 orders. My order was $50 and some change. I don't know what the rules are for posting the discount, but I can PM you the code if wanted. This code came from Relentless Fab, I sent them a PM.
    baldridge and coke can[QUOTED] like this.
  5. Aug 28, 2018 at 9:37 PM
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
  6. Aug 28, 2018 at 9:38 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
  7. Aug 28, 2018 at 9:39 PM
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
  8. Aug 28, 2018 at 9:40 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I think I got the longer one you posted. I went in there and told them what I needed and bought what the smart dude recommended. I obliged and bought it. Lol.
    Can you print using a generic STEP file? Or is it specific to your machine? I’ve got solidworks on my system here at home.
  9. Aug 28, 2018 at 9:42 PM
    Jerneyman
    Wes
    Huntsville, AL
  10. Aug 28, 2018 at 9:54 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Same one
  11. Aug 28, 2018 at 9:56 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I'm hoping the ones I ordered specifically for AUX/CB will be what I need.
  12. Aug 28, 2018 at 9:57 PM
    Jerneyman
    Wes
    Huntsville, AL
    I’m sure you can make it work one way or another if not. It’s just a mounting bracket with a hole after all.
  13. Aug 28, 2018 at 9:59 PM
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    I'm not sure about the step file. I think not though. An stl is the easiest for me to print. That's what my slicer converts to gcode for the printer.
    I should be able to deal with pretty much anything fusion 360 can handle though.
  14. Aug 28, 2018 at 10:00 PM
    Jerneyman
    Wes
    Huntsville, AL
    Gotcha. I can save to a bunch of formats .stl is one I believe. What’s your printing capabilities with your machine?
  15. Aug 28, 2018 at 10:05 PM
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    25/21/21cm build volume. For a bracket, 0.3mm layer height is probably fine, but I should be able to go to 0.1 if necessary. Printing PETG plastic.
    Jerneyman[QUOTED] likes this.
  16. Aug 29, 2018 at 3:07 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Me likey
  17. Aug 29, 2018 at 3:15 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Mornin Trey
    medic2230 and pat's taco like this.
  18. Aug 29, 2018 at 3:46 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
  19. Aug 29, 2018 at 3:48 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Morn.
  20. Aug 29, 2018 at 3:49 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Bart
    Sup Justin
    baldridge[QUOTED] likes this.
