Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 30, 2018 at 10:39 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I haven't replaced mine, but my issues is I need a longer hitch now. the one I have (now on my T4R) when it "dropped" it hit the bumper so it wouldn't work. need one that extends out farther before it drops.
    you saw how tall my truck sits (taller than most unfortunately), and I would assume I'd need about a 6" drop. a 3" is what I had previously and it's just not enough at the height I'm at now, I'd bet it would be fine for yours though.
    Jerneyman[QUOTED] likes this.
  2. Aug 30, 2018 at 10:42 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Yeah, I remember how yours was built. My hitch sits about 1 inch from flush with the 4x4 square tube that's the main body of the bumper so mine doesn't need any extension luckily, just more drop. Its going to be substantially higher. I've got the bottom of my bumper flush with the frame rails. Without the spare, I can sit up straight under my truck bed. Lol.
    stronghammer[QUOTED] likes this.
  3. Aug 30, 2018 at 10:45 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    welcome to the club man. like doing the downward dog yoga pose, ass up, head down. you'll really just need to measure and see, or see if harbor freight will let you walk one outside and see how it works. you may need 6" drop as well.
  4. Aug 30, 2018 at 10:49 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have an 8" drop, which is OK for most.
    A 10" drop is probably a better choice, if you are buying one instead of using what you have.
    This is with a Pelfrybilt bumper and 3+ inches of lift.
  5. Aug 30, 2018 at 10:49 AM
    Jerneyman
    Wes
    Huntsville, AL
    Probably should just measure where I'm at with my 2 inch drop hitch and just go from there. But that makes too much sense. Haha.
    I'm finally going to cut my fenders tomorrow. Then its figuring out the design for the wings and all the other miscellaneous crap I have to mount. Probably going to be running it unpainted on Sunday at Choccolocco.
  6. Aug 30, 2018 at 10:50 AM
    coke can
    coke can Well-Known Member
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Glad to hear he's doing better!
  7. Aug 30, 2018 at 10:50 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    dang that's a huge drop!
  8. Aug 30, 2018 at 10:51 AM
    Jerneyman
    Wes
    Huntsville, AL
    THATS WHAT SHE SAID
    I'm a child.
  9. Aug 30, 2018 at 11:01 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    I have seen several people using an 8" drop with my bumper (SOS Concepts).
  10. Aug 30, 2018 at 11:02 AM
    BamaTaco56
    Trey
    :woot:
    Glad he is doing better.
  11. Aug 30, 2018 at 11:02 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    what kind of lifts are these people running?!
    Jerneyman likes this.
  12. Aug 30, 2018 at 11:03 AM
    BamaTaco56
    Trey
    Dakars
    Think about how much higher the hitch receiver sets in these bumpers vs stock
  13. Aug 30, 2018 at 11:03 AM
    Jerneyman
    Wes
    Huntsville, AL
    Where does your hitch sit in relation to the frame rails of the truck? Mine is dead center with the frame rails height wise.
  14. Aug 30, 2018 at 11:04 AM
    BamaTaco56
    Trey
    Mine would be about dead center as well.
  15. Aug 30, 2018 at 11:05 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    That's what I've got too, they aren't adding that many inches of lift. then take into account a few inches for relocation.
    trailers are ok sitting at a slight upper angle....better than tongue down...
  16. Aug 30, 2018 at 11:05 AM
    Jerneyman
    Wes
    Huntsville, AL
    Ok. I'll probably just order an 8 inch drop then. Seems 10 inch drops are quite a bit more scarce anyway.
  17. Aug 30, 2018 at 11:07 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I use a 8 but 10 would be better
  18. Aug 30, 2018 at 11:08 AM
    Scott B.
    Scott
    Georgia
    Yes, but level is better than tongue up.
    A good idea. If you a really low trailer, you may need to get a second drop.
  19. Aug 30, 2018 at 11:10 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I guess I've only hauled trailers that have decent size tires themselves, I also am not planning to haul with my Tacoma again.
    I wouldn't be going over 6 personally.
  20. Aug 30, 2018 at 11:10 AM
    Jerneyman
    Wes
    Huntsville, AL
    Hmm. I'll just have to take a look at the trailer I normally tow and measure everything. Probably be my best bet deciding between the two. My truck isn't ever going to get shorter so....
