Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Sep 11, 2018 at 2:08 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    :hattip:Good early morning!
  2. Sep 11, 2018 at 2:17 AM
    BlackBeauty04
    BlackBeauty04 Well-Known Member
    Justin
    Lynchburg, VA.
    2004 SR5 / 2018 TRD PRO
  3. Sep 11, 2018 at 3:03 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
  4. Sep 11, 2018 at 3:05 AM
    BamaTaco56
    Trey
    Looks good! I like that lip that goes under the frame where it bolts up. Good thing to have for extra strength on impacts.
    Jerneyman[QUOTED] likes this.
  5. Sep 11, 2018 at 3:09 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup fellas
    medic2230 and baldridge[QUOTED] like this.
  6. Sep 11, 2018 at 4:04 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Pat
    pat's taco likes this.
  7. Sep 11, 2018 at 4:36 AM
    BamaTaco56
    Trey
    Scotty say what
    :der:
    stronghammer[QUOTED] likes this.
  8. Sep 11, 2018 at 4:37 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    yeah I can't cut this weekend, but the 22nd I was already planning to so I want to do a day trip that day
  9. Sep 11, 2018 at 4:41 AM
    T4golfR
    T4golfR Golf dad > Soccer mom
    Allen
    HSV, Alabama
    08 T4R
    Golf club accommodation mods
    Any local HSV'ers wanna give me a hand sometime soon? I need to fix my yota lean in the front left and hoping just cranking my driver side coilover up a bit will fix it.
    stronghammer likes this.
  10. Sep 11, 2018 at 4:56 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I'd crank the passenger side down, if possible. when you looking to do this?
  11. Sep 11, 2018 at 5:07 AM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    I am already at about 1" rake, which is fine, I just don't wanna get close to looking like the damn bro lean and have negative rake. I know I will eventually have to do what a lot of other T4Rs have done and re add the rear spacer on the driver side along with cranking my coilovers up or down. I measured a few days ago and I want to say I am at 39.5" front left, 40.5" front right, 41.5" rear left, and 42" rear right from ground to wheel well.
  12. Sep 11, 2018 at 5:17 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    gotcha ok, yeah if you are wanting to avoid rake then crank the driver side up is def the way to go. can you adjust while on the 4runner or you wanting to take it off?
  13. Sep 11, 2018 at 5:27 AM
    medic2230
    Murph
    Bama! Roll Tide
    Morning :wave:
    gixxerphil and pat's taco like this.
  14. Sep 11, 2018 at 5:33 AM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    Everything on my t4r site says you can do it while its on. My thought was to take my tire/wheel off, put a my vehicle on one jack stand and put my driver side LCA on another and crank it that way. It really shouldn't be a 2 man job and I should be able to knock it out in no more than an hour, but when it comes to something like this I like having another educated set of eyes.
  15. Sep 11, 2018 at 5:36 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    let me know when you're planning on it I might be able to come over and "supervise" with you. we cranked my passenger side down while on the truck to counter my lean. it's not too bad.
    T4golfR[QUOTED] likes this.
  16. Sep 11, 2018 at 5:40 AM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    My only worry with keeping everything on the vehicle and on the ground is stripping the holes where the spanner wrench goes in. I have 2 different spanner wrenches that came with my coilovers and one of them has basically a built in cheater bar so I'm hoping I can use it, crank it once or twice, throw the tire/wheel back on and be done!
  17. Sep 11, 2018 at 5:41 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yeah we almost blew on out on the top of my coil, but got it turned around where it's hidden from view haha! def gotta be careful. my issue iirc was the hose being in the way of accessing the holes.
  18. Sep 11, 2018 at 5:43 AM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    No resi's here:thumbsup:
  19. Sep 11, 2018 at 5:50 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    If she has no clue what her address is, she probably shouldn't be getting a credit card... js
    With that said, she should use her ACTUAL address.
    JKU3000 and medic2230 like this.
  20. Sep 11, 2018 at 5:50 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
