Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Nov 14, 2018 at 12:52 PM
    medic2230
    Murph
    Bama! Roll Tide
    Non balanced class load?
    gixxerphil likes this.
  2. Nov 14, 2018 at 12:54 PM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    https://m.youtube.com/watch?v=TS3oWlKz1mY
  3. Nov 14, 2018 at 1:00 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    can't blame long travel for him not having a CV, I'm not watching a 20 min video so maybe I'm missing details.
    He'd be in the same predicament even if he was standard travel, just slightly less expensive.
    TheTacoma likes this.
  4. Nov 14, 2018 at 1:02 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I've not seen another automotive forum as clean and well run as this one. Jeep has a couple, but they don't look good.
  5. Nov 14, 2018 at 1:03 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I think the biggest argument for staying with stock length CVs is parts availability. Granted, yes, having spare CVs on hand would have been the smart thing to do since they are custom but worst case scenario, you break all your spares too. Then you have to rely on a parts store to have it, which most likely they would.
    Long travel is still awesome though and I envy those who have it, just saying. But in the end, you got to pay to play and its going to cost more to run it.
    whitedlite[QUOTED] and TheTacoma like this.
  6. Nov 14, 2018 at 1:06 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    No. He could have just bought a replacement if it was stock travel. He needed the longer shaft off the long travel and the knuckle off the stock one.
  7. Nov 14, 2018 at 1:13 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    he was headed home, he could've pulled the CV apart and rode with one end in the Diff to hold oil in there and without the end going into the spindle.
    I'm unsure of how easily it is to get our CVs since I've never called a dealer or Oreilly's, I do see what you're saying, but this isn't a LT fault.
    This is an unprepared fault.
  8. Nov 14, 2018 at 1:21 PM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    Is CBI having a Black Friday sale?
  9. Nov 14, 2018 at 1:21 PM
    Jerneyman
    Wes
    Huntsville, AL
    Not sure how well that would work. CVs are built to work with both ends supported. Even disassembled, having the "plug" in the diff would cause an imbalance and most likely fail going down the road at 70mph. Then you've got a busted front diff due to oil starvation. Max had a long trip home, I think 1000 miles or so, and a cobbled together truck wasn't really an option.
    CVs are readily available at most parts houses. I was able to buy and pickup a replacement same day.
    The issue Max ran in to was that the extended axles had a different spline count than the non-OE replacement CVs found at the parts houses. So even with parts available for him to rebuild his CV, it wouldn't work due to the slight differences.
    Wouldn't have been an issue if A) he had a spare extended length CV or B) didn't have LT in the first place.
  10. Nov 14, 2018 at 1:30 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    instead of more armor buy more doors :boink:
  11. Nov 14, 2018 at 1:31 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    the snap ring "should" hold that CV plug in there, I know it was a damn pain to get my OEM axle out of the diff. I'm not going to argue if it would work, hope to never have to do this.
  12. Nov 14, 2018 at 1:35 PM
    Jerneyman
    Wes
    Huntsville, AL
    "should"
    The one I changed out pretty much fell out. Not to mention unnecessary wear on your needle bearings. But it could be a potential solution if you were in a pinch. Not sure I could trust it for 1000 miles though. I'd probably just pull both CVs, drain my diff fluid and tape up the ends if I had to go that far. Haha.
  13. Nov 14, 2018 at 1:59 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Obviously a lot to be said for just having stock CV setup. That said aside from Scotty's mishap no one else broke anything while we were at Moab and we pulled off a major repair job on Brian's U-joints in a parking lot. Seeing him hanging on that ledge he was going to push up did not look like a good idea. While I like the idea of a challenge to push the truck over a bigger obstacle you gotta balance that thought of what you gotta deal with if you break something. I prefer a good spotter that makes sure I am going to get where I am going with no repairs necessary (so says low, low).
    stronghammer likes this.
  14. Nov 14, 2018 at 2:16 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    yeah and my mishap was more like "how tf did that happen" lol. nobody carries spare spider gears around with them, and now that I have a locker, even disengaged, that should never happen again.
  15. Nov 14, 2018 at 2:52 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    TheTacoma[QUOTED] likes this.
  16. Nov 14, 2018 at 3:19 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    He should not have went without spares if it is a custom part.
    He could have pulled both CVs to get home and got a replacement when he got home.
    This is why I am glad to have locking hubs.
  17. Nov 14, 2018 at 4:35 PM
    TheTacoma
    Birmingham, AL
  18. Nov 14, 2018 at 4:41 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    @yota243 I made salmon with butter garlic sauce and asparagus and green beans and mashed potatoes, the adventure continues
  19. Nov 14, 2018 at 4:43 PM
    medic2230
    Murph
    Bama! Roll Tide
    Made dinner myself tonight.
    Meatloaf with mushroom gravy, fresh corn on the cob and buttermilk mashed taters.
    0AD4D797-2726-4639-BCA7-A72D1776980D.jpg 557F0A5E-8B58-475A-86B6-F933A329957F.jpg
  20. Nov 14, 2018 at 4:51 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Nice dude!
