Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 19, 2018 at 1:04 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Need some tubing bent? Could make you some killer shock hoops for that SAS. :wink:
    whitedlite likes this.
  2. Dec 19, 2018 at 1:07 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    lol. I gotta figure those things out at some point. Seems like a tube bender will be a good investment in the future.
    I may draw up some measurements and buy the pre-bent steel to weld up a swing-out from you as a first project. It'll be down the road and a stronger welder before I tackle a SAS build, it is just the main reason i want to learn to weld.
  3. Dec 19, 2018 at 1:13 PM
    Jerneyman
    Wes
    Huntsville, AL
    That would be a great first project. I can just sell you the tubing at cost for me plus a small cut and bend fee. Wouldn't be much.
    And yeah, a tube bender is an awesome thing. Opens up loads of options as far as stuff to build for your truck and even building a full cage. IMO, the only way to affordably own a buggy is to build it yourself with as little outsourcing as possible.
    InfernoChalupa and TheTacoma like this.
  4. Dec 19, 2018 at 1:14 PM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    o_O:pray:
  5. Dec 19, 2018 at 1:14 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    if you're getting a 210 amp i would think it's strong enough for any automotive welding you want to do.
    it's the amount of welding time or duty cycle that could hurt, but that won't be a problem if only welding for yourself
  6. Dec 19, 2018 at 1:16 PM
    BamaTaco56
    Trey
    Starting with the 140. Telling myself that i will upgrade to the 210 if I can pay off the 140 by building random crap (Grills and tables) to sell.
    Jerneyman likes this.
  7. Dec 19, 2018 at 1:17 PM
    Jerneyman
    Wes
    Huntsville, AL
    Meh, welding with a 210 on 220 volts on anything automotive related will run the machine at about its mid range. Should have anywhere from 80 to 100 percent duty cycle welding 3/16. and all your tubing is going to be 1/8. My welder is capable of running welds on 3/8 at 40 percent if I remember right.
    whitedlite[QUOTED] likes this.
  8. Dec 19, 2018 at 1:18 PM
    BamaTaco56
    Trey
    Maybe one day......
    TheTacoma[QUOTED] likes this.
  9. Dec 19, 2018 at 1:21 PM
    Jerneyman
    Wes
    Huntsville, AL
    I can definitely make a set of those. If I'm seeing it right, its a plate with a tube mounting level with the ground, right?
  10. Dec 19, 2018 at 1:25 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    It's a beautiful thing.
  11. Dec 19, 2018 at 1:27 PM
    Jerneyman
    Wes
    Huntsville, AL
    Gotcha, well when you get around to it, just send me some pictures of where you'll be mounting it. I'll need a shot lined up directly with the vertical, angled support to get the angle measurement and then the hole spacing and width of the vertical support that it'll mount to. Should be able to build it from that.
  12. Dec 19, 2018 at 1:29 PM
    TheTacoma
    Birmingham, AL
    Look what I found today :lalala:
  13. Dec 19, 2018 at 1:29 PM
    BamaTaco56
    Trey
    hey, nice cooler!
    InfernoChalupa likes this.
  14. Dec 19, 2018 at 1:32 PM
    Jerneyman
    Wes
    Huntsville, AL
    Gotcha. Ignore my PM. Lol.
  15. Dec 19, 2018 at 1:32 PM
    BamaTaco56
    Trey
    You got me beat on the price by a little bit. But yep!
  16. Dec 19, 2018 at 1:36 PM
    TheTacoma
    Birmingham, AL
    How big is this cooler?!:eek:
  17. Dec 19, 2018 at 1:47 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
  18. Dec 19, 2018 at 1:58 PM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    @BamaTaco56 I think Miller makes a welding machine that is convertible between 110 and 220 single phase
    TheTacoma and Jerneyman like this.
  19. Dec 19, 2018 at 1:59 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
  20. Dec 19, 2018 at 1:59 PM
    Jerneyman
    Wes
    Huntsville, AL
    Miller and Hobart. Never used mine on 110, but all I'd have to do is put the 110 plug on the end and plug it in the wall. Automatically detects the change in voltage. Same as the Miller.
