Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 31, 2018 at 4:29 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I do this with my kickouts but I have TL problems so having a pivot point on tighter areas really helps. The most used part of my slider though is the 2x2 square under the cab pinch that thing gets beat like a redheaded step child.
  2. Dec 31, 2018 at 4:40 AM
    medic2230
    Murph
    Bama! Roll Tide
  3. Dec 31, 2018 at 5:04 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    bc i got no mobtown stickers :pout:
    tweakit88[QUOTED] likes this.
  4. Dec 31, 2018 at 6:01 AM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    They are so naked looking without rear and front bumpers and sliders!
  5. Dec 31, 2018 at 6:47 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
  6. Dec 31, 2018 at 6:48 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    whitedlite[QUOTED] likes this.
  7. Dec 31, 2018 at 7:24 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    so, if my PS rack is leaking...then what? I'm watching videos now about this stuff.
  8. Dec 31, 2018 at 7:30 AM
    medic2230
    Murph
    Bama! Roll Tide
    Make it not leak?
  9. Dec 31, 2018 at 7:31 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I mean like...does the rack need replaced...I can only find people replacing bushings, not seals
  10. Dec 31, 2018 at 7:32 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    also...would this issue cause a "wobble" in my front end? at certain speeds my front drivers side wobbles like an SOB and I know it's not an unbalanced tire.
  11. Dec 31, 2018 at 7:41 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Plamsa Cutter will be in next Monday. I got it delivered to my brothers so I won't get to play with it for a while is only negative. :annoyed::spending:
    TheTacoma likes this.
  12. Dec 31, 2018 at 8:02 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    baldridge and medic2230 like this.
  13. Dec 31, 2018 at 8:06 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I can see how that would help but going up hills I wonder if it will push you to the side or make your wheels spin.
  14. Dec 31, 2018 at 8:21 AM
    JBTacoma
    Jeff
    Cullman Alabama
    I would not think the rack would cause a wobble. A wobble could be a warped tire, warped rim or wheel bearing.
    May be the same problem @InfernoChalupa had
    InfernoChalupa likes this.
  15. Dec 31, 2018 at 8:24 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I don't believe it is. It sort of comes and go's, not always an issue. At first I thought it was warped rotor, but it happens without the brakes. It usually only occurs above 45mph, and it's worse when I decelerate from say like 60 back down to 45.
  16. Dec 31, 2018 at 8:25 AM
    JBTacoma
    Jeff
    Cullman Alabama
  17. Dec 31, 2018 at 8:26 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
  18. Dec 31, 2018 at 8:27 AM
    JBTacoma
    Jeff
    Cullman Alabama
    If it is worse when you apply your brakes to slow down it could be in the brakes.
  19. Dec 31, 2018 at 8:27 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    no no, sorry didn't word that right. it's worse when I simply slow down, without the help of the brakes. meaning just letting off the gas.
  20. Dec 31, 2018 at 8:28 AM
    JBTacoma
    Jeff
    Cullman Alabama
    It is not easy to replace on either
