Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jan 4, 2019 at 3:23 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Check the A/C, heater core drain if it stops up the water coming through the cowl vent will fill it up. Some of them are metal and some are plastic.
    This one is on my 03, I see you have a 03 so it may be the same.
    Also check to see if the trim peice on the door is installed properly. It can cause the weather stripping to deform and leak. Water will run down and across the kick panel and down the firewall.
    JKU3000[QUOTED] likes this.
  2. Jan 4, 2019 at 3:54 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    I will check tomorrow, should I invest in a can of Felx seal? Always wondered if it worked
  3. Jan 4, 2019 at 4:37 PM
    JBTacoma
    Jeff
    Cullman Alabama
    If the drain is stopped up it causes water to over flow, cleaning it out will fix it if that is what it is.
    You should be able to run something up through the drain to get out what ever is blocking it or use compressed air.
    If it is a seal it may be your windshield not really any other seal that I can think of at the top of the firewall.
    Don't use any kind of sealer in the drains.
  4. Jan 4, 2019 at 5:11 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    Haha you’re good. If I can’t find any Ilol wait on you
    stronghammer[QUOTED] likes this.
  5. Jan 4, 2019 at 5:24 PM
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    Hey all, got a set of TRD Pro shocks for sale in the Huntsville area.
    See this thread.
    R4MBLN_YOTA likes this.
  6. Jan 4, 2019 at 6:53 PM
    NTY18
    NTY18 Well-Known Member
    Can anyone recommend a shop/individual that can install my lift in the Birmingham Area. Assembled OME fronts, Headstrong AALs and OME shocks in the rear on a brand new truck. Fairly clean and easy. The trinity is getting the better of me right now. Work, school, and family.
    Weighing the option of waiting a month to install or having it done next week.
  7. Jan 4, 2019 at 6:58 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Brian talked about a meet in March here in Huntsville. Save quite a bit of money.
  8. Jan 4, 2019 at 8:19 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    We can get it installed for you without going to a shop
    Worst case, Stay away from the 2 big name stores in the Pelham area. The only one with someone that is knowledgeable is The off-road connection in fultondale, though the owner is a Jeep guy.
    TheTacoma likes this.
  9. Jan 4, 2019 at 9:16 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Still planning on going in the morning?
  10. Jan 4, 2019 at 11:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    If I'm seeing the picture right I had a similar leak coming from the grommet in the firewall. I used silicone caulk and it's been fine
  11. Jan 5, 2019 at 5:34 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    No work being done in huntsville. Everyone on TW all day! :rofl:
    pat's taco and rmepilot like this.
  12. Jan 5, 2019 at 6:57 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Shhhhh
    baldridge[QUOTED] likes this.
  13. Jan 5, 2019 at 8:46 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
  14. Jan 5, 2019 at 9:05 AM
    JBTacoma
    Jeff
    Cullman Alabama
  15. Jan 5, 2019 at 9:06 AM
    JBTacoma
    Jeff
    Cullman Alabama
  16. Jan 5, 2019 at 10:25 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Getting my TPMS light taken care of that happened right after leaving Hoover Toyota 2 weeks ago.
  17. Jan 5, 2019 at 11:53 AM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
    They are calling for almost a full week of no rain. Time for a bath. 20190105_090848.jpg 20190105_123809.jpg
  18. Jan 5, 2019 at 4:34 PM
    JBTacoma
    Jeff
    Cullman Alabama
  19. Jan 5, 2019 at 6:06 PM
    Cred92
    Cred92 PAID4MOD
    Caleb
    Jasper Al
    Indigo Ink Sport DCLB/White RC I4 5MT
    BLACK AND BLUE STUFF
    I did the same thing going through the car wash lol no pics tho
  20. Jan 5, 2019 at 10:13 PM
    JBTacoma
    Jeff
    Cullman Alabama
    R4MBLN_YOTA and SOS CONCEPTS like this.
