Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jan 8, 2019 at 9:28 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Superbumps it is.
    stronghammer[QUOTED] likes this.
  2. Jan 8, 2019 at 10:05 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    here's the update.... check out my math at the end, technically i lowered my total amount by $3k + buying it back and now have a car that needs nothing other than oil changes and filters for another 110k miles oh and some $330 michelins from costco.
    i'm trying to make it to where having a wreck worked in my favor, i expect insurance to rise about 20% or so just guessing. Currently sitting around $1100 every 6 months with truck and car with 50/250 deductibles.
    https://www.tacomaworld.com/threads/arb-f-r-locked-kings-icon-bs-sport-build.486889/#post-14937849
  3. Jan 8, 2019 at 10:31 AM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    I used Wheelers kit with 99-07 Silverado factory replacement bumps from O’Reiley’s
  4. Jan 8, 2019 at 10:43 AM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    Hey wire gurus! Wiring up my replacement tag lights on the bumper. Correct me if I’m wrong. But the white wire with black stripe is the ground correct? Seeing it is the same in both lights? I know the run different wires to keep track of them so the green and blue should be the hot wires, correct?
  5. Jan 8, 2019 at 10:52 AM
    T4golfR
    T4golfR Golf dad > Soccer mom
    Allen
    HSV, Alabama
    08 T4R
    Golf club accommodation mods
    I would say yes. Mainly because I just replaced my foglights and white/black was ground for those. You can always grab a volt meter and do a quick check to be sure
    R4MBLN_YOTA[QUOTED] likes this.
  6. Jan 8, 2019 at 10:59 AM
    Jerneyman
    Wes
    Huntsville, AL
    How'd you mount those bumpstops?
  7. Jan 8, 2019 at 11:22 AM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    There is a little lip on the Wheeler plates that will catch the bump if it’s mounted on the stock bump contact point. Saved a boatload. I think the bumps were $50 Like this.
    Jerneyman[QUOTED] likes this.
  8. Jan 8, 2019 at 11:27 AM
    Jerneyman
    Wes
    Huntsville, AL
    Right on. I like that. I may go this route instead. I'm trying to do this U bolt flip so its compatible with the Chevy leaves I'll be swapping in hopefully in the near future.
  9. Jan 8, 2019 at 11:29 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  10. Jan 8, 2019 at 11:30 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I'm about to order rotors/pads/maybe calipers? for my 4runner. Recommendations?
  11. Jan 8, 2019 at 11:32 AM
    yota243
    E.J.
    north Alabama
  12. Jan 8, 2019 at 11:32 AM
    Jerneyman
    Wes
    Huntsville, AL
    Nope. None.
  13. Jan 8, 2019 at 11:33 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yota243[QUOTED] likes this.
  14. Jan 8, 2019 at 11:36 AM
    yota243
    E.J.
    north Alabama
    Yeah the stuff is way cheaper than anything else from my experience. I got read shocks for jess' rav4 for like $40 (for 2) shipped. And everything has lined up right for me so I say its ok
  15. Jan 8, 2019 at 11:37 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    do you have a recommendation on brand to avoid or to get?
    if you feel like searching with me it's a 1998 4Runner Limited 4WD with 16" wheels.
  16. Jan 8, 2019 at 11:50 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    just coast to stops from farther away!!
  17. Jan 8, 2019 at 11:51 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I keep seeing that AT&T commercial in my head...
    "if the brakes don't stop it something will"
  18. Jan 8, 2019 at 12:01 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
  19. Jan 8, 2019 at 12:07 PM
    yota243
    E.J.
    north Alabama
    I've always heard to steer clear of cheap drilled/slotted rotors but nothing other than that really. Ill take a look and see what I can find but that Amazon looks like it'll be a hard price to beat
  20. Jan 8, 2019 at 12:09 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    that's what I'm thinking, and I've heard of powerstop before and it has good reviews.
