Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jan 31, 2019 at 9:35 AM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    I don't ever like to cut my pipe back too far. Maybe 6" or so. Anymore can cause the exhaust gasses to get trapped under the truck when you aren't moving and make its way into the cab.
  2. Jan 31, 2019 at 9:35 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    King, Fox, Icon, ADS, etc are all going to be a very similar ride if setup properly. Some of those mentioned leak and have poor customer service, so they are not praised as much as the others.
    rmepilot likes this.
  3. Jan 31, 2019 at 9:35 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    for coilovers pick your favorite color, and of course bilsteins will do anything you want to do.
    just make sure you order your front springs somewhat heavy if you ever want to add a winch or bumper.
    InfernoChalupa and BamaTaco56 like this.
  4. Jan 31, 2019 at 9:36 AM
    BamaTaco56
    Trey
    Haha. Said the exact same thing in a very different way
    whitedlite[QUOTED] likes this.
  5. Jan 31, 2019 at 9:44 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Dobinsons MRR. Remote resi, adjustable, smooth as hell, and can get front coilovers and rear shocks for just about the same price as what the others cost for just the front. I wheel hard and i like them. I thought about upgrading them but i cant beat them for what i have into them. They have been great.
  6. Jan 31, 2019 at 9:46 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    my decision to run kings came from the fact i got the whole setup super duper cheap.
    @InfernoChalupa, scour the used market for months and when someone posts some coilovers for sale jump on them.
    my first suspension part bought was fox coilovers I paid 800 then sold them for 1000 a month later when my package deal for kings, leafs, and bumps came up.
    InfernoChalupa likes this.
  7. Jan 31, 2019 at 9:46 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Sounds like there are some knowledgeable folks in here.
    @BamaTaco56 @whitedlite and others, how does ADS compare to King/Fox/Icon etc in relation to Progressive/Linear/Digressive?
    If I have my facts straight, King and Fox as a whole are more Linear/Progressive right outa the box. Whereas Icon/Bilstein are Digressive. Is that accurate? If so, again, where does ADS fall?
    Edit: @tweakit88 I know nothing about Dobinsons MRR stuff. Do tell.
  8. Jan 31, 2019 at 9:49 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    ADS is equal to all others, the biggest difference between coilover companies will be customer service. Which i've never dealt with anyones.
    don't worry about the mumbo jumbo progressive/digressive. It's not a high performance truck, and I'd be willing to bet it's not that noticeable, similar to how clickers on an OEM replacement coilover is just a bling factor. My personal opinion.
    Leman likes this.
  9. Jan 31, 2019 at 9:53 AM
    backcountryj
    Jonathan
    GA
    To some level I think it’s noticeable. I’m running the Bilstein 2nd Gen Pro kit on my 3rd gen. It’s definitely a more firm ride than the Fox 3rd Gen Pro. I’m not a huge fan so I won’t be upset when it’s time to replace it. And I likely will be staying away from anything Digressive.
  10. Jan 31, 2019 at 9:59 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    If it’s done right and has no leaks, it won’t change anything about your exhaust other than clearance. I’d recommend an exhaust shop do it since they can make a mandrel bent tube specific to the reroute. I pieced mine together and it was a pain to weld due to all the pieces.
  11. Jan 31, 2019 at 10:54 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    On the flight to HSV, have the snowplows cleared the roads yet?
    :notsure:
    stronghammer likes this.
  12. Jan 31, 2019 at 10:56 AM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    It was 20° this morning. Better insulate your balls!
    rmepilot[QUOTED] likes this.
  13. Jan 31, 2019 at 11:20 AM
    tweakit88
    Leroy IL
    Only the best.
    Pm answered :thumbsup:
  14. Jan 31, 2019 at 12:21 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    I don’t have a reroute just the chop and it definitely is louder since it’s dumping under the bed and resonates. Mines more noticeable the. A stock muffler bc I have a magnaflow.
  15. Jan 31, 2019 at 12:28 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Yea and even my magnaflow still doesn’t wake up the whole neighborhood lol
  16. Jan 31, 2019 at 12:32 PM
    medic2230
    Murph
    Bama! Roll Tide
  17. Jan 31, 2019 at 12:34 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    So, if I get the Dakar heavy spring kit...and only have about 130-150lbs of extra weight in the rear (bumper, spare 285, hi lift) what is my ride quality gonna be like?
    I don’t wanna have a real still rear end while off-roading and be getting jarred around
  18. Jan 31, 2019 at 12:39 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    i have heavy rear spring kit and no extra weight added. I don't mind it.
    R4MBLN_YOTA[QUOTED] likes this.
  19. Jan 31, 2019 at 12:48 PM
    BamaTaco56
    Trey
  20. Jan 31, 2019 at 12:54 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Don’t forget the Kitchen shelving!
    :anonymous:
