Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Feb 3, 2019 at 3:08 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    My shell is indispensable to protecting valuables from the two legged critters and keeping items safe from the weather. Some don't like the extra weight, my wife/son say it doesn't look like a truck with it on (traitors) but I really like mine. Only issue can be carrying oversized items in the truck but I have a trailer for that. Also not the best for carrying an RTT. I have rack on mine and did so a couple of times but did not like the top heavy feeling on the truck or if your truck is lifted almost needing a ladder to reach everything for setting it up. Issue with bed racks if they might weigh as much as the shell but they are the best thing for a RTT in most circumstances. I have mine on a trailer and only issue I have is when I want to leave it somewhere. That said my trailer has a special pivoting hitch that no one is likely to have to easily hook it up and haul it away.
    tweakit88 and Cred92 like this.
  2. Feb 3, 2019 at 3:16 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Fire (controlled burn) is the correct answer. Dealt with those before on my family property and only good way to get rid of them. After that you are going to be using a grub hoe or something that can dig out the roots to keep them from coming back. They truly suck trying to get rid of them but a controlled burn is best way. Forest Service is likely to come out for free to advise.
    baldridge likes this.
  3. Feb 3, 2019 at 3:35 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I don't doubt that's the best way, just a little more risk than I'm comfortable with. Since it's only a couple hundred feet, I may just try to tackle it with some yard tools and run over it a bunch with the Polaris. Will take forever, but that's my skill set/budget haha.
    I doubt this will be a cure all, unless I ride on it alot...alot alot. Still may not get all the roots though. Thanks to all for the advice. Will post some pics once it's Tacoma worthy.
  4. Feb 3, 2019 at 4:44 PM
    Cred92
    Cred92 PAID4MOD
    Caleb
    Jasper Al
    Indigo Ink Sport DCLB/White RC I4 5MT
    BLACK AND BLUE STUFF
    Yea my wife doesn’t like the idea, but I think she’d live. That’s also my plan is if it’s oversized just use my trailer, no plans for a rooftop tent just thinking it’d be nice to store hunting stuff/cooler rather than the back seat.
  5. Feb 3, 2019 at 4:51 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Anyone got any recommendations for body shops in Bham? Gotta get this dent pulled
    JKU3000 likes this.
  6. Feb 3, 2019 at 4:54 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
  7. Feb 3, 2019 at 5:08 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    No but my trailer will :D
    stronghammer[QUOTED] likes this.
  8. Feb 3, 2019 at 5:10 PM
    tweakit88
    Leroy IL
    Only the best.
    It wont support anything. But i never wanted it to. Its gunna get a solor panel and thats it.
  9. Feb 3, 2019 at 5:11 PM
    tweakit88
    Leroy IL
    Only the best.
    What hitch do you use?
  10. Feb 3, 2019 at 6:23 PM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    I need some help with my solenoid for my aux fuse panel. I’m using this solenoid.
    I need to know which fuse(s) under the hood are switched power. I’ve searched everywhere and can’t find an answer.
    Also I am pretty sure that the solenoid is crap. Even when I hold a wire from the battery to the solenoid switch I still don’t get power through it.
    HELP :annoyed::censored::censored:
    @JBTacoma
    @Thunder chicken
  11. Feb 3, 2019 at 7:33 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Is the relay case grounded?
  12. Feb 3, 2019 at 7:37 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    Not ground switched.
    Doesn’t seem to be a ground issue either. Even when we hold a wire on the negative battery post and solenoid body we get nothing.
  13. Feb 3, 2019 at 7:41 PM
    JBTacoma
    Jeff
    Cullman Alabama
    If the relay is grounded and you have 12v going to the small terminal it should be working.
  14. Feb 3, 2019 at 7:46 PM
    JBTacoma
    Jeff
    Cullman Alabama
    You should be able to hear the relay click when you power the small terminal
    TheTacoma likes this.
  15. Feb 4, 2019 at 2:15 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
  16. Feb 4, 2019 at 4:22 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Bart
    :wave: everybody else that's about to wake up
    baldridge[QUOTED] and pat's taco like this.
  17. Feb 4, 2019 at 4:23 AM
    T4golfR
    T4golfR Golf dad > Soccer mom
    Allen
    HSV, Alabama
    08 T4R
    Golf club accommodation mods
    Beautiful weekend where I should have been golfing and I was stuck inside doing finish work in my kitchen on a little breakfast nook. Fortunately, it'll get painted today and it'll be done. Also it helps with the resale value of the house so I'm good with that. If all goes as planned, I will be having a moving party in early fall:fingerscrossed:
    gixxerphil and stronghammer like this.
  18. Feb 4, 2019 at 4:28 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Where you moving to
    gixxerphil likes this.
  19. Feb 4, 2019 at 4:29 AM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    Staying over here where I am, just down the road a bit. We are actually looking to build in one of the new neighborhoods. But it's literally less than 2 miles down the road.
  20. Feb 4, 2019 at 4:39 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    gotcha, yeah I figured you were staying in HC just didn't know where. good deal man I hope it all works out!
