Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jan 23, 2013 at 8:55 PM
    #9601
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    dang. everybody disappear?
  2. Jan 24, 2013 at 3:39 AM
    #9602
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Pretty much
  3. Jan 24, 2013 at 4:20 AM
    #9603
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    how is the truck coming along dave? any updates?
  4. Jan 24, 2013 at 4:29 AM
    #9604
    Davtopgun
    David
    Central Alabama
    Had it nearly done on Monday, but the outer tie rod end had some messed up threads and we couldn't get the nut back on. Bill ordered a new one. May have gotten it done Tuesday, but I haven't had a chance to contact him because I worked late yesterday.
    But other then that, just have to bleed the brakes and work on cosmetic stuff.
  5. Jan 24, 2013 at 11:04 AM
    #9605
    BamaToy1997
    Bill
    Navarre, FL
    Tie rod going in today. After that it will be time to begin the abuse...er...I mean time to go 4 wheeling!
  6. Jan 24, 2013 at 11:05 AM
    #9606
    TacoFMS
    Justin
    Louisa County, VA
    gotta make it to the trail first. lets all cross our fingers this time when he leaves the shop...... just in case.
  7. Jan 24, 2013 at 11:20 AM
    #9607
    Davtopgun
    David
    Central Alabama
    I don't abuse vehicles! :anonymous:
    There are only a few parts left under there that haven't been replaced, like the frame for instance. :laugh:
  8. Jan 24, 2013 at 11:23 AM
    #9608
    TacoFMS
    Justin
    Louisa County, VA
    oh no dave!!! you have gone and done it this time. the frame is gonna fall off the truck now when you leave the shop...... or a door might fall off???? still think there should be some fingers crossed.
  9. Jan 24, 2013 at 11:52 AM
    #9609
    Davtopgun
    David
    Central Alabama
  10. Jan 24, 2013 at 2:39 PM
    #9610
    BamaToy1997
    Bill
    Navarre, FL
    :violent::crapstorm::crapstorm::crapstorm:
  11. Jan 24, 2013 at 4:45 PM
    #9611
    mac424205
    Mathew
    Chelsea
    it's turning out like my old truck!!!! except not any engine problems.
  12. Jan 24, 2013 at 7:53 PM
    #9612
    Davtopgun
    David
    Central Alabama
    Sadly the driver door is a possibility. Will be hitting the local junk yard for a replacement soon.
  13. Jan 25, 2013 at 4:01 AM
    #9613
    TacoFMS
    Justin
    Louisa County, VA
    ftfy:D
  14. Jan 25, 2013 at 4:05 AM
    #9614
    Davtopgun
    David
    Central Alabama
    ^^^ My thoughts exactly when reading his post Lol
  15. Jan 25, 2013 at 4:31 AM
    #9615
    mac424205
    Mathew
    Chelsea
    ????? :notsure:
    EDIT: nvm I read what you put.......:lalala: :pout:
  16. Jan 25, 2013 at 4:33 AM
    #9616
    mac424205
    Mathew
    Chelsea
    I said no engine problems though. I meant that everytime something gets fixed on it something else needs to be replaced.
  17. Jan 25, 2013 at 4:41 AM
    #9617
    TacoFMS
    Justin
    Louisa County, VA
    lil slow this morning are we???? c'mon matt you gonna have to do a better job keepin up with the funnies! :p
  18. Jan 25, 2013 at 4:49 AM
    #9618
    mac424205
    Mathew
    Chelsea
    apparently! lol
  19. Jan 25, 2013 at 5:32 AM
    #9619
    BamaToy1997
    Bill
    Navarre, FL
    As Dave and I talked about it, we both knew that there were going to be things found as we went. They had the coils cranked all the way up, and this pressure was too much for the ball joints, bearings, and tie rods for that matter. That is why Dave cranked them down a bit before we got started. Most of the entire problem has been with the front end. Also, his truck is not in here as a customer's truck. Because of this I only am able to work on it every so often. With that, and my mom being in and out of the hospital, it has taken some time to get everything done, and done right. Don't worry Dave, when you get your truck, it will be ready for the trails and the road.
  20. Jan 25, 2013 at 6:03 AM
    #9620
    Davtopgun
    David
    Central Alabama
    :headbang:
